Furmark+IntelBurnTest (simultaneously) fail (always furmark crash)
Status
Not open for further replies.
78 (0.02/day)
System Name BUILD
Processor INTEL® CORE™ i7-13700K
Motherboard MSI MPG Z790 CARBON WIFI
Cooling NOCTUA NH-D15 chromax.black
Memory 32GB G.SKILL 5600 MHz
Video Card(s) MSI RTX 4070 Ti GAMING X TRIO
Storage 2TB SAMSUNG 990 PRO
Display(s) GIGABYTE M27Q 1440p 170Hz IPS
Case PHANTEKS ECLIPSE P500A DRGB
Power Supply ORSAIR RM1000x SHIFT
Mouse COOLER MASTER MM711
Keyboard CORSAIR K70 RGB TKL OPX
Runnig Intel Burn Test + Furmark (both last version) simultaneously, it crashing the furmark software, but Intel Burn still running. Tested with all bios on stock, also my graphic card its a stock version, so didnt has any oc. It fail after like 15-20 minutes. Tested several times and always happaing, with same order of events logs.
1) id 1 nvidia opengl driver
2) id 1000 app error
"Nombre de la aplicación con errores: FurMark.exe, versión: 1.20.4.0, marca de tiempo: 0x5c3f0381
Nombre del módulo con errores: nvoglv32.dll, versión: 25.21.14.1891, marca de tiempo: 0x5c5b2fcf"
3) id 4101 display driver stopped workign and recovered
So this mean something wrong with the graphic card ? It can be a hardware failure ¿ Sould I do RMA ?
i7 4770k @ stock
rtx 2060 @ stock
16GB TridentX 2400 @ but running at stock
Gigabyte G1 Sniper 5
Corsair HX850W
42,984 (6.72/day)
Stop running both at the same time, let alone stop running furmark completely
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
OneMoar
There is Always Moar
8,800 (1.63/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
Ruru
S.T.A.R.S.
13,129 (2.98/day)
Jyväskylä, Finland
Processor AMD Ryzen 7 5800X / Intel Core i7-8600K
VR HMD Oculus Rift CV1
I have to ask, why Furmark? It's not good for even as a synthetic test, it just heats heats your card to unrealistic temps.
good way to melt some vrms
Exactly. It's just so useless.
Low quality post by jaggerwild
1,901 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
Keep running them also run MEMTEST2011 lolz!
1,042 (0.33/day)
Pristina
System Name My PC
Processor 4670K@4.4GHz
Motherboard Gryphon Z87
Cooling CM 212
Memory 2x8GB+2x4GB @2400GHz
Display(s) HP envy 32 1440p
Case CM Mastercase 5
Audio Device(s) Sbz ZXR
Power Supply Antec 620W
Mouse G502
Keyboard G910
Software Win 10 pro
Use 1st intelburn on high 30 cycles then use unigine heaven on extreme for 1-2 hours for gpu and that's it.
78 (0.02/day)
System Name BUILD
Ok so the fact that Furmark fail running simultaneously with IBT it does not mean the video card is defective ? I just want to be sure. I mean it can be posible to fail because when the GPU need to process something with the CPU, it jsut going on fail because the CPU already have full load 100% from the IntelBurn ¿
I don't mean to be rude but that's a Noob thing.
I was trying to simulate the real game experience, where the games of today are using compeltly all of you cores and GPU at the same time. I was just wanted to test the video card.
the54thvoid
Super Intoxicated Moderator
13,151 (2.39/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
What your doing does not simulate real game performance. You'll not find many (any) games that run your CPU at 100% and your GPU maxed out.
Apart from Furmark being useless, the CPU at 100% will probably mean any other software will be unstable. If your CPU is completely maxed out on one application, how is it meant to work on another?
Ruru
S.T.A.R.S.
13,129 (2.98/day)
Jyväskylä, Finland
Run 3DMark and/or internal benchmarks of games instead of that "power virus" Furmark.
7,412 (2.73/day)
Poland
System Name Purple rain
Cooling Noctua D15S
Benchmark Scores A LOT
well,then play those games for heaven's sake
866 (0.23/day)
Processor ryzen 5 5600x
Motherboard AB350m Pro4
Cooling custom loop
Memory TEAMGROUP T-Force TXKD416G3600HC18ADC01 16gbs XMP
Video Card(s) HP GTX1650 super 4gb
Storage MZVLB256HBHQ-000H1 PM981a (256GB)/3TB HDD
Display(s) Nitro XF243Y Pbmiiprx
Case Rosewill CULLINAN
Power Supply Corsair 750w
Mouse Best Buy Insignia
Keyboard Best Buy Insignia
Software Win 10 pro
likely that the software could be having a conflict.
if you want to test for stability run prime95 for 30 minutes, this is usually enough to see if something is wrong with your cpu. then run memtest for around an hour. this checks to see if the memory has any issues. next run a couple of benchmarks like metro's built in one, or just play the games to see if you have any problems. running multiple benchmarks wont crash the pc if the software isnt conflicting with one another but in this case im sure there is.
good luck.
965 (0.25/day)
System Name Sham Pc
Processor i5-2500k @ 4.33
Motherboard INTEL DZ77SL 50K
Cooling 2 bay res. "2L of fluid in loop" 1x480 2x360
Memory 16gb 4x4 kingstone 1600 hyper x fury black
Video Card(s) hfa2 gtx 780 @ 1306/1768 (xspc bloc)
Storage 1tb wd red 120gb kingston on the way os, 1.5Tb wd black, 3tb random WD rebrand
Display(s) cibox something or other 23" 1080p " 23 inch downstairs. 52 inch plasma downstairs 15" tft kitchen
Case 900D
Audio Device(s) on board
Power Supply xion gaming seriese 1000W (non modular) 80+ bronze
Software windows 10 pro x64
IBT + fur mark?
What are you trying to do, cook your self?
5,571 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
There's no such game that uses 100% of both CPU & GPU and all your going to do is end up cooking something completely. Like others have said here just run 3DMark and or IBT separately or just use in game benchmarks to simulate gaming
78 (0.02/day)
System Name BUILD
All right so I have the last question:
"Timeout Detection and Recovery" it can happen because of bad/unstable CPU overclock ?
Two days ago I had freeze on chome for like few seconds than my screen goes black, and back again with a notification of Driver stopped working and recovered
"id event 14 - The description of event 14 is not found on the origin nvlddmkm
id event 4101 - nvlddmkm stopped working and has recovered"
Actually I was trying to get some overclock on my CPU and well...just had this issue
rtwjunkie
PC Gaming Enthusiast
14,022 (2.33/day)
Louisiana
Processor Core i9-9900k
I will offer my opinion. If you want to test out your computer’s ability to handle a tough game experience, then test it by playing games. Doing what you want it to without error is a pretty good judge of its ability.
19,374 (3.53/day)
As we told you at ocf....stop running furmark.
Just an fyi, he cross forum posted. So you guys dont spin your tires here... I linked his threads from ocf where we went over these things and shared the same advice. :)
https://www.overclockers.com/forums/showthread.php/793790-CPU-overclock-can-make-graphics-card-fail
https://www.overclockers.com/forums/showthread.php/793775-Half-FPS-in-all-games-with-default-bios
run unigine heaven or 3dmark fire strike extreme on loop... running ibt and furmark at the same time isnt remotely a realistic load. Very few games use all cores and threads and when they do, they arent as stressful as stress tests...
1,811 (0.60/day)
BGD
System Name Minotaur
Processor Intel I9 7940X
Motherboard Asus Strix Rog Gaming E X299
Cooling BeQuiet/ double-Fan
Memory 192Gb of RAM DDR4 2400Mhz
Video Card(s) 1)RX 6900XT BIOSTAR 16Gb***2)MATROX M9120LP
Storage 2 x ssd-Kingston 240Gb A400 + HDD 500Gb+2xSSD Kinston 480Gb+5Tb Seagate+512Gb NVME SGI
Case NZXT H5 Flow
Mouse Asus TUF-GAMING M3
VR HMD Oculus Rift DK2
Software Win 11
Benchmark Scores Fire Strike=23905,Cinebench R15=3167,Cinebench R20=7490.Passmark=30689,Geekbench4=32885
Try to reinstall your GPU drivers,first wipe them totally with DDU and then install new....If the problem persist then there is a possibility that is something wrong with your GPU....
P.S. STOP USING FURMARK!!!
78 (0.02/day)
System Name BUILD
I apreciate that you are active on my issues and you help, but you dont need to manipulate me or the others people . So im in my rights to come and ask for the help on others forums. You should edit you post and remove the part of telling people from here to not focus on my issues. Education is everything
19,374 (3.53/day)
Nobody is manipulating anything...nor did I say/allude to you not having a right to do this. I shared with others that you have gone over a lot of this at a different site and shared the links so those who may run across it won't waste their time (nor yours) going over information that has already been provided. ;)
Education IS everything (not changing my post - I didn't ask anyone not to help, WTH??), but let's not waste time of those who are helping you for free, by going over things that were covered previously. This is common forum etiquette that if you cross post, at least link threads so people can see what has been done already.
From another site........(reasons)
Please don't cross-post questions on multiple forums at the same time (whether on multiple threads here, or on other forums). If you post on another forum and don't get the answer you need, please feel free to post it here after a reasonable length of time, or better still, post here first and then try elsewhere if we can't help.
If we recognize a thread from another forum, we'll post a link to the other thread so that those reading are aware of the other thread. Why? 2 reasons:
1. It can create a far bigger mess for you!
Conflicting troubleshooting steps from different forums create confusion and could even make things worse. If we're trying to help you untangle a mess, someone else from another forum changing things at the same time can really create chaos!
2. It wastes the time of those trying to help.
Imagine you ask a question on 2 different forums (i.e. here and the Adobe forums). Person A finds it on Forum A, stops what they're doing, spends a little time checking a few things in order to answer. But while they've been doing that, Persons B&C find it on Forum B, who also stop what they're doing and spend a little time checking a few things in order to answer. Eventually Person A comes back and whoever gets to them first gives them the answer. The issue? The other 2 people who were so willing to help have wasted their time. Or you get 2 conflicting answers!! And then if the same people are frequenting both forums, which is often the case is such a specific area of discussion such as Lightroom, then they're also wasting their time reading it in both locations, and the conversations in both locations become disjointed.
I hope you are now able to understand why I posted those links. :)
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
You should try running IBT at lower CPU priority with task manager so that it leaves some cpu cycles to furmark and the nvidia driver,
Really?
Your post is the #20 did you read the other 19? i guess you didn't:shadedshu:
Sad to say but you were doing it completely wrong and more than testing your GPU you were cooking it, however i don't know where you get that information from but IBT and Furmark doesn't have anything to do with simulating real Game Experience, instead use Fire Strike or Heaven Benchmark.
P.s Take in consideration @EarthDog advice:toast: i am sure he didn't mean it in a bad way;)
78 (0.02/day)
System Name BUILD
Ok thank all for the help
19,374 (3.53/day)
The thing is, bench, I can only think of ONE game that uses 'all' threads. Games typically only use a few cores and threads at most. Also the difference between gaming loads and stress test loads are huge. There isnt anything wrong with testing both at the same time, but furmark is a terrible test for the GPU.:)
3,847 (1.33/day)
Case Thermaltake Core P5
Keyboard Corsair K100 RGB
VR HMD HTC Vive Cosmos
Does Furmark fail when not running simultaneously with IBT?
ppn
1,231 (0.36/day)
Really?
I missed that part, i thought you were total denialists of this test combination so was less inclined to read. but i See now.
Status
