Guide to running multiple GPU work units
28,883 (4.59/day)
Miami, Florida
Motherboard ASUS ROG Crosshair X670E Hero
Cooling ARCTIC Liquid Freezer III 360 A-RGB // X12 Phanteks D30-120 D-RGB Fans
Memory G.SKILL Trident Z5 Neo RGB Series (AMD Expo) DDR5 RAM 32GB (2x16GB) 6000MT/s CL30
Video Card(s) ZOTAC Gaming GeForce RTX 4090 AMP Extreme AIRO
Storage Samsung Pro 980 2TB NVMe (OS and Games) // WD Black 10TB HDD (Storage)
Display(s) SAMSUNG 34-Inch Ultrawide 75Hz (Desk Games) // SAMSUNG 49-Inch Ultrawide 144Hz (Sim Racing Rig)
Case Phanteks NV7
Power Supply Seasonic Vertex GX-1200, 1200W 80+ Gold, ATX 3.0
Any idea what the settings have to be set at on the utility to run four WU's on two 7770's?
Also, do i run a C/F bridge or not? :confused:
Norton
Moderator - Returning from the Darkness
14,104 (2.93/day)
Northeast USA
System Name Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs
Processor Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc...
Motherboard Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc...
Cooling Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc...
Memory 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc..
Video Card(s) MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc...
Storage Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc...
Display(s) Main PC (2x24" Dell UltraSharp U2414H)
Case Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc...
Audio Device(s) Logitech Z625 THX 2.1 speakers
Power Supply EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc...
Mouse G300s
Keyboard Corsair K65
VR HMD N/A
Software Windows 10 Pro or Ubuntu
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
Bridge isn't needed
Do the following:
add the use all gpus line to cc_config file
in the app_config
use 0.25 on the gpu line (8 total wu's)
use 0.5 or less for the cpu line (depends on cpu)
See code below ;)
cc_confg
Code:
cc_config>
<options>
<report_results_immediately>1</report_results_immediately>
<use_all_gpus>1</use_all_gpus>
</options>
</cc_config>
app_config
Code:
<app_config>
   <app>
      <name>hcc1</name>
      <max_concurrent>8</max_concurrent>
      <gpu_versions>
          <gpu_usage>0.25</gpu_usage>
          <cpu_usage>0.50</cpu_usage>
      </gpu_versions>
   </app>
</app_config>
28,883 (4.59/day)
Miami, Florida
Case Phanteks NV7
Bridge isn't needed
Do the following:
in the app_config
See code below ;)
cc_confg
Code:
cc_config>
<options>
</options>
</cc_config>
app_config
Code:
<app_config>
   <app>
      <name>hcc1</name>
      <gpu_versions>
      </gpu_versions>
   </app>
</app_config>
I'm getting this now...
Norton
14,104 (2.93/day)
Northeast USA
Mouse G300s
VR HMD N/A
28,883 (4.59/day)
Miami, Florida
Case Phanteks NV7
Looks like they are getting loaded up fine. What are max safe temps for these cards? Seen the one that is getting little air is running much hotter.
Yep, seems like it is...
Norton
14,104 (2.93/day)
Northeast USA
Mouse G300s
VR HMD N/A
http://img.techpowerup.org/130318/Capture035.jpg
http://img.techpowerup.org/130318/Capture036949.jpg
The top card tends to get starved of cool air/pick up heat from the lower card- If you can get a fan in front of the cards it will help a lot
My top card ran in the 70's until I added a fan. It runs around 60 now... :)
28,883 (4.59/day)
Miami, Florida
Case Phanteks NV7
694 (0.11/day)
Barcelona, Catalonia, Spain
System Name Woody
Processor AMD Ryzen 7 9700X
Motherboard Gigabyte B650M Aorus Elite AX ICE
Cooling MSI MAG A13 CoreLiquid 360
Memory 32GB (2x16) Corsair Vengeance 6000MHz (CL30)
Video Card(s) Sapphire Pulse RX 7800 XT
Storage WD_BLACK SN850x (2x1TB) + Sandisk Ultra 2TB
Display(s) LG 34WNC80B (3440x1440 @ 75 Hz)
Case Lian Li A3 (Black-Wood)
Audio Device(s) Logitech Pro X & Scarlett 2i4 w/M-AUDIO BX5-D2
Power Supply Corsair RM750 (ver. 2019)
Mouse Logitech MX Master 3
Keyboard Keychron Q1 Pro (Akko Cream Blue Pro V3 switches)
And suddenly tonight w/o knowing why, my BOINC for MacOS X 10.7.5 started to accept work for my ATI GPU. Strange world cause i investigated quite a bit about it two months ago but found no answer ... and a few minutes ago, watching a youtube video i saw how it was getting slower ... same symptom as it happens on Windows when it's GPU crunching.
Thought it couldn't be that on Mac (it has been running since the beginning of January and the GPU was detected but no available work for it ever) ... but i gave it a try, i just looked at the Manager to double check and found that it was really crunching!!! So excellent news, i don't have to reboot anymore to do GPU crunching on my main rig :D
It's running multi WU's as well :toast:
PS: Any MacOS user who had that issue as well?
stinger608
11,248 (1.89/day)
Wyoming
System Name 2023 Ryzenfall
Processor AMD Ryzen 5800X
Cooling SilverStone AH240 AIO
Case Corsair Air 540
Audio Device(s) On board
Bridge isn't needed
Do the following:
in the app_config
See code below ;)
cc_confg
Code:
cc_config>
<options>
</options>
</cc_config>
app_config
Code:
<app_config>
   <app>
      <name>hcc1</name>
      <gpu_versions>
      </gpu_versions>
   </app>
</app_config>
With all this talk about using multiple cards, I am wondering if I couldn't put my GTX560 in my rig as a secondary card behind the current hd7870 to help in GPU work units. Hmm, not sure how well it would run though.
Not even sure what type of config I would have to set up to make it work correctly.
t_ski
Former Staff
11,941 (1.73/day)
System Name My i7 Beast
Processor Intel Core i7 6800K
Motherboard Asus X99-A II
Cooling Nickel-plated EK Supremacy EVO, D5 with XSPC Bayres & BIX Quad Radiator
Memory 4 x 8GB EVGA SuperSC DDR4-3200
Video Card(s) EVGA 1080 SuperClocked
Storage Samsung 950 Pro 256GB m.2 SSD + 480GB Sandisk storage SSD
Display(s) Three Asus 24" VW246H LCD's
Case Silverstone TJ07
Power Supply Corsair AX1200
Keyboard Corsair K95
Software Windows 10 x64 Pro
Probably not worth it, as the Nvidia don't net as much as AMD. Red = crunch, green = fold.
[Ion]
WCG Team Assistant
13,391 (2.38/day)
Raleigh, North Carolina, United States
System Name Niedersachsen / Ribe / Minsk
Processor i3 3240 / i7-3520M / 4x Opteron 6376 @ 2.86GHz
Motherboard BIOSTAR H61M / HP Q77 / Supermicro H8QG7
Cooling Stock / Stock / 4x 1U G34
Memory 1x8GB / 2x4GB / 4x4GB
Video Card(s) GTX260 / Intel HD 4000 / nVidia GT310
Storage 80GB Intel SSD / 256GB Intel SSD / 2x 60GB SSD (RAID1)
Display(s) Dell 3007 + HP 2245w / 12.1" 1366x768 / None
Case Antec NSK3480 / HP / Supermicro 1U
Power Supply Enermax 500W / HP 130W / Supermicro Gold 1400W
Keyboard IBM Model M
Software Windows 7 (Niedersachsen/Ribe) / Linux Mint 17.2 (Minsk)
My GTX470s get about 16-17k PPD each and the GTX460s each got ~8-9k. Not terrible, by any stretch of the imagination, but it would probably just confuse the HD7870 more than it did good.
If you want it put to use, my i7 folding system still has an empty slot; it could go right next to the GTX550TI ;)
1,464 (0.23/day)
Oakland, CA
System Name Rex
Processor Ryzen 2600
Motherboard GigaByte B450M DS3H
Cooling Wraith
Memory 16 GB Corsair Vengence 3000
Video Card(s) Evga GTX 1660 SC
Storage XPG M.2, Samsung 860 SSD, WD Black 1 TB
Display(s) ASUS VG248
Case Corsair mATX cube. (Alas they don't make it anymore)
Power Supply Corsair HX 600 Watt
Mouse Microsoft
Keyboard Logitech
Software Windows 10 64 ibit
Computation Error
I'm having trouble getting BOINC to run multiple GPU WUs on my 7850. I'm getting a "Computation Error" in 2 seconds or less on each WU. All clocks are stock. The CPU runs fine. I'm using 7.0.59(x64) on an i3. Here's my app_config.xml (it's in the right place too). I need a clue.
<app_config>
<app>
<name>hcc1</name>
<max_concurrent>4</max_concurrent>
<gpu_versions>
<gpu_usage>.25</gpu_usage>
<cpu_usage>1</cpu_usage>
</gpu_versions>
</app>
</app_config>
Here's the errors
t_ski
Former Staff
11,941 (1.73/day)
7.0.44 is known to be stable. Try the older client. Also, what GPU drivers are you using?
1,464 (0.23/day)
Oakland, CA
System Name Rex
Cooling Wraith
Mouse Microsoft
Keyboard Logitech
1,464 (0.23/day)
Oakland, CA
System Name Rex
Cooling Wraith
Mouse Microsoft
Keyboard Logitech
t_ski
Former Staff
11,941 (1.73/day)
Norton
14,104 (2.93/day)
Northeast USA
Mouse G300s
VR HMD N/A
You might try the 12.11 beta 4's (or 6 or whatever the last one was) or the latest betas.
12.6 runs great on all of my crunchers.... check with manofthem if you happen to be using Win8
t_ski
Former Staff
11,941 (1.73/day)
Was there a certain required driver version for the GPU units, or what that a certain driver version for the 7770?
Norton
14,104 (2.93/day)
Northeast USA
Mouse G300s
VR HMD N/A
iirc manofthem needed to use 13.2 beta's? to keep his driver from crashing while crunching on his 7970's with Win8
I use 12.6's for all of my crunching rigs.... they do the job w/o errors and I use engineering rule #1- If It Ain't Broke Don't Fix It ;)
manofthem
WCG-TPU Team All-Star!
10,960 (2.13/day)
Florida
Processor 3900X @ 4.0
Cooling DeepCool Castle 360EX
Storage Sabrent Rocket Q 1TB
Display(s) LG 34UC88
Case Thermaltake P3
Mouse Logitech G900
Yes, first one I tried that worked was the 13.2b4. I just updated to 13.3b (due to Crysis 3), and everything has been going smoothly :)
t_ski
Former Staff
11,941 (1.73/day)
Yes, same driver has been working much better on Win8. I even can watch videos again while crunching (had green playback before).
hat
Enthusiast
21,750 (3.26/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Still only good for HCC? Has anyone found any way to allow a single GPU to process multiple WUs at a time while crunching for all projects?
Ah, nevermind. I see with this new method I can run every single project and still process multiple GPU WUs with a single card. Good, good...
966 (0.17/day)
Currently somewhere around NSW, Australia
System Name hmmm...
Processor 9800X3D
Motherboard X670E-I
Cooling PA120SE
Memory 2x16gb 6400 C32
Video Card(s) EVGA GTX 1080 TI FTW3
Storage T500 1tb
Display(s) 4K 120hz
Case Jonsplus Z20
Power Supply SF-1000
Mouse Logitech
Keyboard Corsair K70 LUX RGB
Good day! My PC won't run GPU work units. I tried using the Auto-setup utility and I tried doing it manually but the BOINC Manager is showing a notice saying "app hcc1 not found in app_config.xml". I have a screenshot below of the notice and of the xml file created. The file is saved in C:\ProgramData\BOINC\projects\www.worldcommunitygrid.org and I am tried using 7.0.44 and 7.0.64. :confused:
manofthem
10,960 (2.13/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
HCC GPU units are gone, no more, adios, so long :(
