Guide to running multiple GPU work units
[Ion]
WCG Team Assistant
13,391 (2.38/day)
Raleigh, North Carolina, United States
System Name Niedersachsen / Ribe / Minsk
Processor i3 3240 / i7-3520M / 4x Opteron 6376 @ 2.86GHz
Motherboard BIOSTAR H61M / HP Q77 / Supermicro H8QG7
Cooling Stock / Stock / 4x 1U G34
Memory 1x8GB / 2x4GB / 4x4GB
Video Card(s) GTX260 / Intel HD 4000 / nVidia GT310
Storage 80GB Intel SSD / 256GB Intel SSD / 2x 60GB SSD (RAID1)
Display(s) Dell 3007 + HP 2245w / 12.1" 1366x768 / None
Case Antec NSK3480 / HP / Supermicro 1U
Power Supply Enermax 500W / HP 130W / Supermicro Gold 1400W
Keyboard IBM Model M
Software Windows 7 (Niedersachsen/Ribe) / Linux Mint 17.2 (Minsk)
How would I set that up with the Utility? Would I put it to run 5 WU's per card, but how many threads so I specify the PC has? I still say eight or...?
Personally, I'd manually edit the app_config.xml file
Tell it to have a maximum of five HCC WUs, each getting .2 GPUs and .6 CPUs:
Code:
- <app_config>
<app>
<name>hcc1</name>
<max_concurrent>5</max_concurrent>
<gpu_versions>
<gpu_usage>.200</gpu_usage>
<cpu_usage>.6</cpu_usage>
</gpu_versions>
</app>
</app_config>
(this for the HD7770, not the HD6870)
28,883 (4.59/day)
Miami, Florida
Motherboard ASUS ROG Crosshair X670E Hero
Cooling ARCTIC Liquid Freezer III 360 A-RGB // X12 Phanteks D30-120 D-RGB Fans
Memory G.SKILL Trident Z5 Neo RGB Series (AMD Expo) DDR5 RAM 32GB (2x16GB) 6000MT/s CL30
Video Card(s) ZOTAC Gaming GeForce RTX 4090 AMP Extreme AIRO
Storage Samsung Pro 980 2TB NVMe (OS and Games) // WD Black 10TB HDD (Storage)
Display(s) SAMSUNG 34-Inch Ultrawide 75Hz (Desk Games) // SAMSUNG 49-Inch Ultrawide 144Hz (Sim Racing Rig)
Case Phanteks NV7
Power Supply Seasonic Vertex GX-1200, 1200W 80+ Gold, ATX 3.0
With the utility you have to put 10 WU at a time, 5 per card and 6 threads.
Thank you. How do I determine these #'s? Just trying to understand the utility better so in the future if I have to make changes I'd know what I'm doing. Thanks. :toast:
Norton
Moderator - Returning from the Darkness
14,104 (2.93/day)
Northeast USA
System Name Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs
Processor Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc...
Motherboard Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc...
Cooling Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc...
Memory 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc..
Video Card(s) MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc...
Storage Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc...
Display(s) Main PC (2x24" Dell UltraSharp U2414H)
Case Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc...
Audio Device(s) Logitech Z625 THX 2.1 speakers
Power Supply EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc...
Mouse G300s
Keyboard Corsair K65
VR HMD N/A
Software Windows 10 Pro or Ubuntu
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
The utility is pretty straight forward- you'll get it after a few changes (I still do mine manually most of the time) :)
Output is basically T&E with your results- add wu's until the ppd is max'd out. Too few and you have lower than ideal results/too many and the time to complete a wu gets too long and ppd drops off.
gpu usage over 95% continuously is about max for the card ;)
119 (0.03/day)
System Name Aki
Processor Intel Core i5-3570
Motherboard Gigabyte GA-H77M-D3H
Cooling CM 212 Evo
Memory Corsair Vengeance 8 GB DDR3-1600
Video Card(s) Sapphire HD7850 2GB
Storage INTEL SSD 520 120 GB, WD Green 2TB, WD Black 2TB, WD Blue 4TB
Display(s) AOC 2353 [23" LCD]
Case Corsair 400R
Power Supply Seasonic 520W S12II
Keyboard Corsair K70
Software Windows 8.1 64 bit
My HD7850 works @96 % continuosly in 4 WU's + 1 WU (CPU only).
I dont want to put more pressure as i have stock fan only . Big corsair 400R with open holes . :p
28,883 (4.59/day)
Miami, Florida
Case Phanteks NV7
For now the settings I'm using are doing pretty good. over 28K so far and the day is young. :)
We'll see how it does.
[Ion]
WCG Team Assistant
13,391 (2.38/day)
You're doing great Captain! :toast: :rockout:
28,883 (4.59/day)
Miami, Florida
Case Phanteks NV7
Thank you sir, looking forward to seeing how much it'll put out by the end of the day. :D
stinger608
11,248 (1.89/day)
Wyoming
System Name 2023 Ryzenfall
Processor AMD Ryzen 5800X
Cooling SilverStone AH240 AIO
Case Corsair Air 540
Audio Device(s) On board
Quick question, and it has probably been answered a few times LOL
How many wu's can a person run with a 7770 GHZ edition card and still have the system usable?
Reason I ask, is I am pretty sure I have my 6870 traded for the above mentioned card. I know the 7770 will crunch much better than the 6870 but it will still need to be usable as it is the wife's system.
Thanks in advance guys.
Norton
14,104 (2.93/day)
Northeast USA
Mouse G300s
VR HMD N/A
Start with 3 and if all is OK then go up to 4 or 5... 4 is generally the best but if you're using the rig I don't know how the lag will be on it? ;)
You can also bump the clock up at least 50Ghz w/o too much trouble
stinger608
11,248 (1.89/day)
Wyoming
Thanks Norton! I was thinking that most were running 4 threads with them. I will give 4 a try and see how much lag if any there is.
With the 6870 I can only run 1 thread otherwise it lags bad.
28,883 (4.59/day)
Miami, Florida
Case Phanteks NV7
I'm running five WU's on mine and it's pretty freaking laggy, but the CPU crunching as well.
t_ski
Former Staff
11,941 (1.73/day)
System Name My i7 Beast
Processor Intel Core i7 6800K
Motherboard Asus X99-A II
Cooling Nickel-plated EK Supremacy EVO, D5 with XSPC Bayres & BIX Quad Radiator
Memory 4 x 8GB EVGA SuperSC DDR4-3200
Video Card(s) EVGA 1080 SuperClocked
Storage Samsung 950 Pro 256GB m.2 SSD + 480GB Sandisk storage SSD
Display(s) Three Asus 24" VW246H LCD's
Case Silverstone TJ07
Power Supply Corsair AX1200
Keyboard Corsair K95
Software Windows 10 x64 Pro
Part of it depends on the system and the CPU I guess. I can run eight on each of the 7770's and everything is fine except videos.
[Ion]
WCG Team Assistant
13,391 (2.38/day)
Yes, it will be laggy--I've found that over two WUs on cards tends to do that (unfortunately). Hence why I suggest (if possible) a different system for daily use (or suspending GPU computing while you're using the computer)
28,883 (4.59/day)
Miami, Florida
Case Phanteks NV7
I just suspended when in use, have no choice really. :( Oh well, it does spend a lot of time idle, and that's when the magic happens. :D
topry
8 (0.00/day)
Question for those running multiple GPUs - do you notice any performance difference based on the PCI slot? For example if you have 3 identical cards in a mobo with x16, x8, x4 is there any demonstrable difference due to the number of channels or are the data transfer requirements for the GPU tasks such that this metric isn't relevant?
Norton
14,104 (2.93/day)
Northeast USA
Mouse G300s
VR HMD N/A
I had 2x 7770's running in a AMD 970 chipset board (x16/x4) and didn't notice any difference in output.... The difference between a 16X and a 4X slot shouldn't be more than 10% imo
[Ion]
WCG Team Assistant
13,391 (2.38/day)
I know that even an x2 slot is plenty for FAH, so I doubt that x4 is an issue. At least it doesn't seem to be with my i7-920 system.
topry
8 (0.00/day)
Norton/Ion - thanks for the input. I did not expect it would be relevant (assuming there wasn't a bottleneck elsewhere). I tried to perform some anecdotal tests, but with WU's of varying sizes and the inability to re-run the same WU's for comparisons, it wasn't possible to get any meaningful datapoints.
Deleted member 74752
Does anyone know what the average completion time should be for a WU on a 7970 running say 8 WU's concurrently? I'm showing around 9 minutes to completion and was wondering if all is well.
HammerON
The Watchful Moderator
8,400 (1.44/day)
Up North
System Name Aki
Processor AMD 7800X3D
Motherboard ASUS ROG STRIX X670E-A
Cooling MSI MAG CoreLiquid E360
Memory Patriot Viper Elite 5 32GB 6200
Video Card(s) PNY RTX 4090 XLR8
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard ASUS ROG Strix Scope II Wireless
Software Win 11 Pro
That sounds about right:)
Revised - It's about 7 minutes now...I should probably add more WU's to the card?
Changed to 12 WU's and it's back to around 9 minutes...
t_ski
Former Staff
11,941 (1.73/day)
When you change you have to let it settle a little. If you have several WU's trying to complete all at the same time they are fighting for CPU time, and it slows them down. As they settle, they start to stagger more and finish one after another instead of all at the same time.
topry
8 (0.00/day)
Anyone successful in running NVidia and AMD/ATI GPU in same rig - either same project or different? I have not tried it yet and while both cards with current drivers 'should' run under windows 7 independently, I don't currently have an AMD card to test with.
I have done it recently with one 5850 and two GTX 295's...worked great for a spell, but the 295's quit receiving WU's after a re-boot.
stinger608
11,248 (1.89/day)
Wyoming
I have been wondering the same thing. I am currently running a single 7870 but also have a GTX560 that is sitting doing nothing.
Not sure how that would work LOL. Would I install the card and Nvidia driver and try it? :laugh:
