Guide to running multiple GPU work units
Norton
Moderator - Returning from the Darkness
14,104 (2.93/day)
Northeast USA
System Name Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs
Processor Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc...
Motherboard Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc...
Cooling Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc...
Memory 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc..
Video Card(s) MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc...
Storage Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc...
Display(s) Main PC (2x24" Dell UltraSharp U2414H)
Case Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc...
Audio Device(s) Logitech Z625 THX 2.1 speakers
Power Supply EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc...
Mouse G300s
Keyboard Corsair K65
VR HMD N/A
Software Windows 10 Pro or Ubuntu
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
It's working, and its amazing lol...
thanks for your help man!
With 4WU's on the GPU each 20% max load, MSI AB reports 95% GPU constant usage.
The most amazing part is that the "Help Conquer Cancer 7.05" takes 4 and a half minutes to finish with 4 of those running at same time.!!!
Awesome!!! :rockout:
Glad it worked out for you! :)
Bow
3,066 (0.51/day)
South of Planet Earth
System Name SLOW-MO-SHUN III
Processor AMD RYZEN 9 7950X 4.5ghz 16 Core
Motherboard MSI MPG X670E Carbon wifi
Cooling Quench 360 Liquid Cooler
Memory 2x 16GB Kingston Fury Beast DDR 5-5200
Video Card(s) NVidia GeForce RTX 3090 24 GB GDDR6X
Storage 1TB Kingston NV2 M.2 SSD 2TB 2.5 SanDisk SSD Plus
Display(s) Asus 28" VP28UQG 4K 3840x2160
Case Athena M1, 6 Chassis Fans
Power Supply EVGA Super Nova 1000W
Mouse Razer Deathadder
Keyboard Razer Ornata
Software Windows 11 Home 64-Bit
Once I run the auto set up and hit enter is that it? I updated, ran the setp. I set it up to run 1 per card. Now I have lots of tasks ready to report and my running tasks are blinking?
whats up with that?
Norton
14,104 (2.93/day)
Northeast USA
Mouse G300s
VR HMD N/A
whats up with that?
Not sure? Did you do a manual update to get the ready to report units reported?
Also, after you ran the utility did you restart BOINC and/or reboot?
Bow
3,066 (0.51/day)
yes to both, and ready to report tasks were sent, but the running ones are still flashing a little, not sure just keep an eye on it.
156 (0.03/day)
Kingdom of Lost Heaven
System Name Date: 2013 Nov
Processor INTEL i7-950 @ 3.2GHz + Corsair H50
Motherboard EVGA X58 SLI LE
Memory CORSAIR Vengeance 16GB (4x4GB) 1600MHz 9-9-9-24
Video Card(s) EVGA GeForce GTX580
Storage SAMSUNG 830 Series 256GB, SEAGATE 4TB
Display(s) ACHIEVA Shiman 27" LED IPS 2560x1440
Case DIY 4.1 Master BenchTable
Audio Device(s) Logitech G19, G700, SteelSeries QcK
Power Supply Enermax Platimax 1350W
Software Windows 8 Pro with Media Center 64-bit
my pc become very laggy while gpu wu running
i cant watch video (1fps)
can anyone advice me for app_config
<app_config>
<app>
<name>hcc1</name>
<max_concurrent>4</max_concurrent>
<gpu_versions>
<gpu_usage>0.5</gpu_usage>
<cpu_usage>1</cpu_usage>
</gpu_versions>
</app>
</app_config>
setup spec in my System Specs
[Ion]
WCG Team Assistant
13,391 (2.38/day)
Raleigh, North Carolina, United States
System Name Niedersachsen / Ribe / Minsk
Processor i3 3240 / i7-3520M / 4x Opteron 6376 @ 2.86GHz
Motherboard BIOSTAR H61M / HP Q77 / Supermicro H8QG7
Cooling Stock / Stock / 4x 1U G34
Memory 1x8GB / 2x4GB / 4x4GB
Video Card(s) GTX260 / Intel HD 4000 / nVidia GT310
Storage 80GB Intel SSD / 256GB Intel SSD / 2x 60GB SSD (RAID1)
Display(s) Dell 3007 + HP 2245w / 12.1" 1366x768 / None
Case Antec NSK3480 / HP / Supermicro 1U
Power Supply Enermax 500W / HP 130W / Supermicro Gold 1400W
Keyboard IBM Model M
Software Windows 7 (Niedersachsen/Ribe) / Linux Mint 17.2 (Minsk)
Unfortunately, particularly for nVidia GPUs, this is just a fact of life. So I'd suggest you set it to run the GPU app only when the computer isn't in use.
t_ski
Former Staff
11,941 (1.73/day)
System Name My i7 Beast
Processor Intel Core i7 6800K
Motherboard Asus X99-A II
Cooling Nickel-plated EK Supremacy EVO, D5 with XSPC Bayres & BIX Quad Radiator
Memory 4 x 8GB EVGA SuperSC DDR4-3200
Video Card(s) EVGA 1080 SuperClocked
Storage Samsung 950 Pro 256GB m.2 SSD + 480GB Sandisk storage SSD
Display(s) Three Asus 24" VW246H LCD's
Case Silverstone TJ07
Power Supply Corsair AX1200
Keyboard Corsair K95
Software Windows 10 x64 Pro
Yep, this is about your only option with Nvidia and crunching.
156 (0.03/day)
is there have any way to run video player on IGP (like nvidia optimus)
or lucid virtu mvp possible to solve this?
t_ski
Former Staff
11,941 (1.73/day)
If you had two video cards you can crunch on one of them and use the second for the system & display (I think), but I'm not familiar with doing something like this. However, I know you have to tell BOINC to use more than one card, so it should default to one card if you don't. I guess the trick is telling it the correct card to crunch on so the system can use the other.
[Ion]
WCG Team Assistant
13,391 (2.38/day)
I did this when I still had a GTX460--I'd put the GTX460 in the first slot and an 8400GS in the second slot. Then I just told BOINC to only use one GPU (in the cc_config.xml file) and it only ran tasks on the GTX460. I then drove the display with the 8400GS, and it was perfectly snappy for everyday use.
830 (0.18/day)
Sydney, Australia
System Name The White Breeze||Medion Akoya Ultrabook
Processor i7-3770k||Core i5-3317U
Motherboard MSI Z77 MPOWER||Laptop?
Cooling Custom TEC waterloop||Laptop?
Memory 16GB Kingston HyperX @ 2133MHz||8GB SDRAM
Video Card(s) 2X SLI MSI GeForce GTX 680 Lightning||Intel 4000
Storage Corsair GT 120GB, WD Caviar Black 1TB||500GB HDD with 32gb MSATA cache
Display(s) Samsung U28D590D 4k||14" LED
Case NZXT Switch 810||Laptop shell?
Audio Device(s) Creative Sound Blaster X-Fi surround pro 5.1||Dolby Home Theatre V4
Power Supply Seasonic XP-860 Platinum||Laptop Power Brick
Software Windows 7||Windows 8
Just a quick question, I just tried to run 3 WU's on my 680, it ran one task that I already had downloaded fine, but now I cannot get any more task's. Whenever I press the update button, I get this error in the event log, "Server error: feeder not running"
Norton
14,104 (2.93/day)
Northeast USA
Mouse G300s
VR HMD N/A
WCG is in a brief shutdown for maintenance- give it a few more hours and try again...
830 (0.18/day)
Sydney, Australia
Oh ok, That's what I thought, though usually there is a message in the event log about that.
830 (0.18/day)
Sydney, Australia
Is there any way to only allow it to use 50% of my GPU? I've set it to only do 2 work units and 0.25, but My GPU still runs at full load.
[Ion]
WCG Team Assistant
13,391 (2.38/day)
My understanding is no--the GPU doesn't have the ability to be fine-grain controlled like CPUs do :ohwell:
156 (0.03/day)
my pc have two (gtx 680 (device 0), gtx 580 (device 1)) gpus
how to configure hcc1 run only device 1 (gtx 580) while i use PC
2,406 (0.43/day)
London, UK
System Name Slick
Processor Intel i5 2467M
Motherboard Samsung Series 5 Ultrabook
Memory 8GB Corsair Value
Storage Crucial M4 7mm 256GB
Display(s) 13"
Software Windows 8 Pro x64
From what I understand, BOINC isn't able to suspend GPU's individually based on different parameters. Either both are running or both are suspended.
If you want to have just the 580 crunching to free up the 680 for other things, you can edit the cc_config file to include this:
Code:
<exclude_gpu>
   <url>http://www.worldcommunitygrid.org/</url>
   <device_num>1</device_num>
   <type>NVIDIA</type>
   <app>HCC1</app>
</exclude_gpu>
Didn't get a chance to test that code, but if you want to read up more you can try this page with all configuration options explained: http://boinc.berkeley.edu/wiki/Client_configuration
156 (0.03/day)
thanks, now it's working
i tried this before, but i was wrote url wrong (project_www.worldcommunitygrid.org or www.worldcommunitygrid.org)
i changed HCC1 to hcc1 (boinc shows error)
since it's exclude i need to exclude my primary gpu it's GTX 680 (device 0)
now everything works what i want
s@h and gpugrid for device 0 (GTX 680)
hcc for device 1 (GTX 580)
and i enabled Use GPU always (instead of Use GPU based on preferences)
2,406 (0.43/day)
London, UK
System Name Slick
Display(s) 13"
Glad that's sorted :)
4,357 (0.88/day)
Mexico
System Name Dell-y Driver
Processor Core i5-10400
Motherboard Asrock H410M-HVS
Cooling Intel 95w stock cooler
Memory 2x8 A-DATA 2999Mhz DDR4
Video Card(s) UHD 630
Storage 1TB WD Green M.2 - 4TB Seagate Barracuda
Display(s) Asus PA248 1920x1200 IPS
Case Dell Vostro 270S case
Power Supply Dell 220w
Software Windows 10 64bit
Trying to get my GT430 to work. It's NOT on the unsupported GPU list: https://secure.worldcommunitygrid.org/help/viewTopic.do?shortName=GPU#610
but I can't make it work with boinc. GPU-Z reports 0Mhz as current speed, DC, Physx and OpenCL are uncheck. Used 310.9 drivers.
edit: seems to be a problem on my end. Device manager shows an exclamation point. *sigh* let's dive in...............
Norton
14,104 (2.93/day)
Northeast USA
Mouse G300s
VR HMD N/A
Here's a list of supported gpu's (GT 430 is near the bottom of the list)
http://www.worldcommunitygrid.org/forums/wcg/viewpostinthread?post=396388
I did a quick search on the WCG forum and found a few posts for the GT 430 using "430" as the search term. I didn't find anything helpful yet but you can always try there :eek:
4,357 (0.88/day)
Mexico
What would be the optimal number of WUs for a 6570? 2? 1?
480 shaders, 650 Mhz.
527 (0.11/day)
somewhere in Eastern Europe
System Name Cruncher
Processor AMD FX-8370
Motherboard Asus Crosshair V Formula
Cooling Thermalright Silver Arrow SB-E
Memory 2x4 GB Corsair XMS3 2000
Video Card(s) Sapphire HD7870+Powercolor HD7850 CrossFire
Storage Corsair ForceGT 90 SSD,WD Black 500
Display(s) Acer 24'' 2ms
Case Cooler Master HAF 932
Power Supply Thermaltake Grand 1050w 80+Gold
Software Win 7 SP1 Ult x64
I see no point to run 2 WU on 6570.
My HD6570 (670 MHz) completes 1 WU in ~15 min.
HD6670 (900 MHz) -:- ~12 min.
[Ion]
WCG Team Assistant
13,391 (2.38/day)
I'd agree, that's a slow enough card that two WUs will probably just be a waste of CPU power :ohwell:
Deleted member 74752
Going by this guide it appears that it would be better to run two GTX 460 SE's over two GTX 295's...is that correct? Would it be possible or beneficial to slip another card in with them?
