Guide to running multiple GPU work units
[Ion]
WCG Team Assistant
13,391 (2.38/day)
Raleigh, North Carolina, United States
System Name Niedersachsen / Ribe / Minsk
Processor i3 3240 / i7-3520M / 4x Opteron 6376 @ 2.86GHz
Motherboard BIOSTAR H61M / HP Q77 / Supermicro H8QG7
Cooling Stock / Stock / 4x 1U G34
Memory 1x8GB / 2x4GB / 4x4GB
Video Card(s) GTX260 / Intel HD 4000 / nVidia GT310
Storage 80GB Intel SSD / 256GB Intel SSD / 2x 60GB SSD (RAID1)
Display(s) Dell 3007 + HP 2245w / 12.1" 1366x768 / None
Case Antec NSK3480 / HP / Supermicro 1U
Power Supply Enermax 500W / HP 130W / Supermicro Gold 1400W
Keyboard IBM Model M
Software Windows 7 (Niedersachsen/Ribe) / Linux Mint 17.2 (Minsk)
Going by this guide it appears that it would be better to run two GTX 460 SE's over two GTX 295's...is that correct? Would it be possible or beneficial to slip another card in with them?
At the very least, the GTX460SEs will use far, far less power than the GTX295s. I'd imagine the two GTX460SEs would probably get 12k PPD together--not bad. You could certainly slip in another card--what do you have?
Deleted member 74752
I was thinking one of the GTX 295's if it came to that configuration. What kind of performance does a 295 give?
[Ion]
WCG Team Assistant
13,391 (2.38/day)
To be honest, I'm not sure. I don't know of anyone on the Team who is running the older GTX2xx cards.
I have two GTX 560 Ti's in the gamer I could swap around...I don't see that much difference between those and the 460's for gaming, but I understand the 560 Ti is much better at this game. I do hate the 295's sitting here not doing a thing tho. I suppose I could just set them up and try it to see what gives.
Ok - I have the two GTX 295's running now with four gpu's loaded around 95% each...I guess they will only pull one at a time. When I first began only the cpu was getting work, but now the gpu's have taken over. How do I determine what the ppd is for each gpu? Each one is polishing one off at 15 minute intervals.
[Ion]
WCG Team Assistant
13,391 (2.38/day)
A WU every fifteen minutes means about 4 points/minute per GPU core--or about 16 points/minute total with the two GTX295s. Or ~22k PPD--better than I would have thought :toast:
Now, should I leave it as is or try the GTX 460 SE's for effect? Maybe I should Fold with the cpu at the same time since the gpu's have taken over? When will my badge re-appear? So many questions lol...:p
[Ion]
WCG Team Assistant
13,391 (2.38/day)
Now, should I leave it as is or try the GTX 460 SE's for effect? When will my badge re-appear? :p
Not sure about the badge TBH.
If you're running both of the GTX295s, that's higher output than I got from a pair of GTX460s, so you might as well stay with that. Unless power usage is a concern, and the two-GPU solution would be better.
28,883 (4.59/day)
Miami, Florida
Motherboard ASUS ROG Crosshair X670E Hero
Cooling ARCTIC Liquid Freezer III 360 A-RGB // X12 Phanteks D30-120 D-RGB Fans
Memory G.SKILL Trident Z5 Neo RGB Series (AMD Expo) DDR5 RAM 32GB (2x16GB) 6000MT/s CL30
Video Card(s) ZOTAC Gaming GeForce RTX 4090 AMP Extreme AIRO
Storage Samsung Pro 980 2TB NVMe (OS and Games) // WD Black 10TB HDD (Storage)
Display(s) SAMSUNG 34-Inch Ultrawide 75Hz (Desk Games) // SAMSUNG 49-Inch Ultrawide 144Hz (Sim Racing Rig)
Case Phanteks NV7
Power Supply Seasonic Vertex GX-1200, 1200W 80+ Gold, ATX 3.0
Alright guys, how do I verify if this is working correctly? I used the auto utility and put the XML file in the folder where it goes. I put it to run 2 WU's on my 6850 for now. This is what my tasks look like at the moment, just started BOINC up. I also installed the latest version.
[Ion]
WCG Team Assistant
13,391 (2.38/day)
It's not working--if it was, it would say that it was running two WUs, each using .5 AMD GPU(s).
Can you paste the Event Log here and the contents of your cc_config.xml file?
Thanks! :toast:
28,883 (4.59/day)
Miami, Florida
Case Phanteks NV7
Event Log:
2/28/2013 1:14:27 PM | | Starting BOINC client version 7.0.52 for windows_x86_64
2/28/2013 1:14:27 PM | | log flags: file_xfer, sched_ops, task
2/28/2013 1:14:27 PM | | Libraries: libcurl/7.25.0 OpenSSL/1.0.1 zlib/1.2.6
2/28/2013 1:14:27 PM | | Data directory: E:\ProgramData\BOINC
2/28/2013 1:14:27 PM | | Running under account 2600K
2/28/2013 1:14:27 PM | | Processor: 8 GenuineIntel Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz [Family 6 Model 42 Stepping 7]
2/28/2013 1:14:27 PM | | Processor: 256.00 KB cache
2/28/2013 1:14:27 PM | | Processor features: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss htt tm pni ssse3 cx16 sse4_1 sse4_2 popcnt aes syscall nx lm vmx tm2 pbe
2/28/2013 1:14:27 PM | | OS: Microsoft Windows 7: Ultimate x64 Edition, Service Pack 1, (06.01.7601.00)
2/28/2013 1:14:27 PM | | Memory: 7.98 GB physical, 15.95 GB virtual
2/28/2013 1:14:27 PM | | Disk: 465.66 GB total, 439.24 GB free
2/28/2013 1:14:27 PM | | Local time is UTC -5 hours
2/28/2013 1:14:27 PM | | CAL: ATI GPU 0: AMD Radeon HD 6800 series (Barts) (CAL version 1.4.1741, 1024MB, 991MB available, 2976 GFLOPS peak)
2/28/2013 1:14:27 PM | | OpenCL: AMD/ATI GPU 0: AMD Radeon HD 6800 series (Barts) (driver version 1016.4 (VM), device version OpenCL 1.2 AMD-APP (1016.4), 1024MB, 991MB available, 2976 GFLOPS peak)
2/28/2013 1:14:27 PM | | Config: report completed tasks immediately
2/28/2013 1:14:27 PM | | Config: don't compute while iw5mp_server.exe is running
2/28/2013 1:14:27 PM | | Config: don't compute while iw5sp.exe is running
2/28/2013 1:14:27 PM | | Version change (7.0.28 -> 7.0.52)
2/28/2013 1:14:27 PM | World Community Grid | URL http://www.worldcommunitygrid.org/; Computer ID 2233200; resource share 100
2/28/2013 1:14:27 PM | World Community Grid | General prefs: from World Community Grid (last modified 01-Feb-2012 18:25:12)
2/28/2013 1:14:27 PM | World Community Grid | Computer location: home
2/28/2013 1:14:27 PM | | General prefs: using separate prefs for home
2/28/2013 1:14:27 PM | | Reading preferences override file
2/28/2013 1:14:27 PM | | Preferences:
2/28/2013 1:14:27 PM | | max memory usage when active: 4084.39MB
2/28/2013 1:14:27 PM | | max memory usage when idle: 7351.90MB
2/28/2013 1:14:27 PM | | max disk usage: 10.00GB
2/28/2013 1:14:27 PM | | suspend work if non-BOINC CPU load exceeds 25 %
2/28/2013 1:14:27 PM | | (to change preferences, visit a project web site or select Preferences in the Manager)
2/28/2013 1:14:27 PM | | Not using a proxy
2/28/2013 1:14:28 PM | | Running CPU benchmarks
2/28/2013 1:14:28 PM | | Suspending computation - CPU benchmarks in progress
2/28/2013 1:15:00 PM | | Benchmark results:
2/28/2013 1:15:00 PM | | Number of CPUs: 8
2/28/2013 1:15:00 PM | | 3647 floating point MIPS (Whetstone) per CPU
2/28/2013 1:15:00 PM | | 11801 integer MIPS (Dhrystone) per CPU
2/28/2013 1:15:01 PM | World Community Grid | Restarting task faah38233_ZINC13095685_xPR_wC6_11_1ref9_01_1 using faah version 715 in slot 1
2/28/2013 1:15:01 PM | World Community Grid | Restarting task faah38234_ZINC08393620_xPR_wC6_11_1ref9_00_1 using faah version 715 in slot 2
2/28/2013 1:15:01 PM | World Community Grid | Restarting task qn253_00085_17 using hpf2 version 640 in slot 3
2/28/2013 1:15:01 PM | World Community Grid | Restarting task faah38235_ZINC40506264_xPR_wC6_11_1ref9_02_1 using faah version 715 in slot 6
2/28/2013 1:15:01 PM | World Community Grid | Restarting task SN2S_CAK32514_0000130_1063_0 using sn2s version 620 in slot 5
2/28/2013 1:15:01 PM | World Community Grid | Restarting task faah38242_ZINC40154149_xPR_wC6_11_1ref9_00_1 using faah version 715 in slot 7
2/28/2013 1:15:01 PM | World Community Grid | Restarting task faah38242_ZINC40033886_xPR_wC6_11_1ref9_00_1 using faah version 715 in slot 4
2/28/2013 1:15:01 PM | World Community Grid | Restarting task X0960116400661200912151102_1 using hcc1 version 705 (ati_hcc1) in slot 0
2/28/2013 1:15:24 PM | | Re-reading cc_config.xml
2/28/2013 1:15:24 PM | | Not using a proxy
2/28/2013 1:15:24 PM | | Config: report completed tasks immediately
2/28/2013 1:15:24 PM | | Config: don't compute while iw5mp_server.exe is running
2/28/2013 1:15:24 PM | | Config: don't compute while iw5sp.exe is running
2/28/2013 1:15:24 PM | | log flags: file_xfer, sched_ops, task
2/28/2013 1:15:52 PM | | [task] Suspending computation - user request
2/28/2013 1:17:16 PM | | [task] Resuming computation
2/28/2013 1:17:56 PM | | [task] Suspending computation - user request
CC config file:
- <cc_config>
- <log_flags>
<file_xfer>1</file_xfer>
<sched_ops>1</sched_ops>
<task>1</task>
<app_msg_receive>0</app_msg_receive>
<app_msg_send>0</app_msg_send>
<async_file_debug>0</async_file_debug>
<benchmark_debug>0</benchmark_debug>
<checkpoint_debug>0</checkpoint_debug>
<coproc_debug>0</coproc_debug>
<cpu_sched>0</cpu_sched>
<cpu_sched_debug>0</cpu_sched_debug>
<cpu_sched_status>0</cpu_sched_status>
<dcf_debug>0</dcf_debug>
<disk_usage_debug>0</disk_usage_debug>
<priority_debug>0</priority_debug>
<file_xfer_debug>0</file_xfer_debug>
<gui_rpc_debug>0</gui_rpc_debug>
<heartbeat_debug>0</heartbeat_debug>
<http_debug>0</http_debug>
<http_xfer_debug>0</http_xfer_debug>
<mem_usage_debug>0</mem_usage_debug>
<network_status_debug>0</network_status_debug>
<poll_debug>0</poll_debug>
<proxy_debug>0</proxy_debug>
<rr_simulation>0</rr_simulation>
<rrsim_detail>0</rrsim_detail>
<sched_op_debug>0</sched_op_debug>
<scrsave_debug>0</scrsave_debug>
<slot_debug>0</slot_debug>
<state_debug>0</state_debug>
<statefile_debug>0</statefile_debug>
<suspend_debug>0</suspend_debug>
<task_debug>0</task_debug>
<time_debug>0</time_debug>
<trickle_debug>0</trickle_debug>
<unparsed_xml>0</unparsed_xml>
<work_fetch_debug>0</work_fetch_debug>
<notice_debug>0</notice_debug>
</log_flags>
- <options>
<abort_jobs_on_exit>0</abort_jobs_on_exit>
<allow_multiple_clients>0</allow_multiple_clients>
<allow_remote_gui_rpc>0</allow_remote_gui_rpc>
<client_version_check_url>http://boinc.berkeley.edu/download.php?xml=1</client_version_check_url>
<client_download_url>http://boinc.berkeley.edu/download.php</client_download_url>
<disallow_attach>0</disallow_attach>
<dont_check_file_sizes>0</dont_check_file_sizes>
<dont_contact_ref_site>0</dont_contact_ref_site>
<exclusive_app>iw5mp_server.exe</exclusive_app>
<exclusive_app>iw5sp.exe</exclusive_app>
<exit_after_finish>0</exit_after_finish>
<exit_before_start>0</exit_before_start>
<exit_when_idle>0</exit_when_idle>
<fetch_minimal_work>0</fetch_minimal_work>
<force_auth>default</force_auth>
<http_1_0>0</http_1_0>
<http_transfer_timeout>300</http_transfer_timeout>
<http_transfer_timeout_bps>10</http_transfer_timeout_bps>
<max_file_xfers>8</max_file_xfers>
<max_file_xfers_per_project>2</max_file_xfers_per_project>
<max_stderr_file_size>0</max_stderr_file_size>
<max_stdout_file_size>0</max_stdout_file_size>
<max_tasks_reported>0</max_tasks_reported>
<ncpus>-1</ncpus>
<network_test_url>http://www.google.com/</network_test_url>
<no_alt_platform>0</no_alt_platform>
<no_gpus>0</no_gpus>
<no_info_fetch>0</no_info_fetch>
<no_priority_change>0</no_priority_change>
<os_random_only>0</os_random_only>
- <proxy_info>
<socks_server_name />
<socks_server_port>80</socks_server_port>
<http_server_name />
<http_server_port>80</http_server_port>
<socks5_user_name />
<socks5_user_passwd />
<http_user_name />
<http_user_passwd />
<no_proxy />
</proxy_info>
<rec_half_life_days>10.000000</rec_half_life_days>
<report_results_immediately>1</report_results_immediately>
<run_apps_manually>0</run_apps_manually>
<save_stats_days>30</save_stats_days>
<skip_cpu_benchmarks>0</skip_cpu_benchmarks>
<simple_gui_only>0</simple_gui_only>
<start_delay>0</start_delay>
<stderr_head>0</stderr_head>
<suppress_net_info>0</suppress_net_info>
<unsigned_apps_ok>0</unsigned_apps_ok>
<use_all_gpus>0</use_all_gpus>
<use_certs>0</use_certs>
<use_certs_only>0</use_certs_only>
</options>
</cc_config>
[Ion]
WCG Team Assistant
13,391 (2.38/day)
Sorry, I asked for the wrong file--I mean to ask for app_config.xml (in the ProgramData\projectw\www.worldcommunitygrid.org\ folder). You may also wish to make sure that the file doesn't have the .txt extension.
28,883 (4.59/day)
Miami, Florida
Case Phanteks NV7
Don't think it does, here is what it looks like in the folder:
and the contents of the file:
- <app_config>
- <app>
<name>hcc1</name>
<max_concurrent>2</max_concurrent>
- <gpu_versions>
<gpu_usage>.500</gpu_usage>
<cpu_usage>1.000</cpu_usage>
</gpu_versions>
</app>
</app_config>
[Ion]
WCG Team Assistant
13,391 (2.38/day)
28,883 (4.59/day)
Miami, Florida
Case Phanteks NV7
brandonwh64
19,542 (3.46/day)
You may be better off just doing 4WU on the 7770 and none on the CPU
Norton
Moderator - Returning from the Darkness
14,104 (2.93/day)
Northeast USA
System Name Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs
Processor Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc...
Motherboard Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc...
Cooling Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc...
Memory 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc..
Video Card(s) MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc...
Storage Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc...
Display(s) Main PC (2x24" Dell UltraSharp U2414H)
Case Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc...
Audio Device(s) Logitech Z625 THX 2.1 speakers
Power Supply EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc...
Mouse G300s
Keyboard Corsair K65
VR HMD N/A
Software Windows 10 Pro or Ubuntu
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
Done deal, let's see now.
If it doesn't grab 2 gpu wu's right away don't worry too much about it. If it doesn't you can try:
- wait until one of the cpu jobs is done
- abort a cpu job
- restart the BOINC manager or restart the PC
Check the event log when BOINC starts- if it sees the file it will acknowledge it in the log and you're pretty much good to go from there ;)
EDIT- nvm you're all set :toast:
[Ion]
WCG Team Assistant
13,391 (2.38/day)
Well, that's a HD6870, and the CPU is an i7-2600k, so I'm not sure I follow your logic...
28,883 (4.59/day)
Miami, Florida
Case Phanteks NV7
Well the 7770 I'm setting up now and that's paired to a i7-950.
28,883 (4.59/day)
Miami, Florida
Case Phanteks NV7
I thought this was for his 7770..... My bad :rolleyes:
I just set up the 7770 to run four WU's. Loading it up about 95%. Going to give that a shot and see how it goes.
[Ion]
WCG Team Assistant
13,391 (2.38/day)
My suggestion for that would be five GPU WUs spread across three threads, with the rest of the CPU doing standard tasks :toast:
28,883 (4.59/day)
Miami, Florida
Case Phanteks NV7
How would I set that up with the Utility? Would I put it to run 5 WU's per card, but how many threads so I specify the PC has? I still say eight or...?
702 (0.14/day)
Where the hand of man has never set foot
Processor AMD Ryzen 5 3600X
Motherboard ASUS TUF GAMING X570-PLUS
Cooling Noctua NH-D15 SE-AM4
Memory 2x8GB G.SKILL Ripjaws V DDR4-3200MHz CL16 1.35V
Video Card(s) MSI Radeon RX 6600 XT Gaming X 8G
Storage Crucial MX100 512GB + Samsung 870 EVO 2TB
Display(s) MSI Optix MAG24C
Power Supply Seasonic FOCUS GX-550
Mouse Razer Viper Ultimate
Keyboard Corsair K60
With the utility you have to put 10 WU at a time, 5 per card and 6 threads.
