Hot Temps for 5800X3D
Morgoth
Fueled by Sapphire
4,253 (0.66/day)
Netherlands
Motherboard aorus x570 pro
Cooling air (GPU Liquid graphene) rad outside case mounted 120mm 68mm thick
Storage 300gb hdd OS backup. Crucial 500gb ssd OS. 6tb raid 1 hdd. 1.8tb pci-e nytro warp drive LSI
Display(s) AOC display 1080p
Case SilverStone SST-CS380 V2
Mouse corsair gaming mouse
Keyboard Microsoft brand
RESERVOIR > PUMP > GPU > RESERVOIR > CPU > RESERVOIR > TOP RAD > FRONT RAD > RESERVOIR > PUMP
by the looks of that the CPU gets cooled with warm water that went past the GPU.... put a rad between it... or seperate loop or back to air
168 (0.16/day)
System Name lawooder
Processor 5800x3D
Motherboard B550M Aorus Elite
Cooling Arctic Freezer 34 DUO
Memory 32GB 4000Mhz CL16 (2x16GB)
Video Card(s) RTX 3070 Ti
Storage SN770 250GB/SN750 500GB/SA510 1TB
Display(s) VG279QM 1080P 280hz + VG27AQ 1440P 165HZ
Case MSI MAG Something
Audio Device(s) fiiO EK10 + HD 599
Power Supply Focus GX 750 Watts
Mouse XM1r
Keyboard Xtrfy K4
Just got the x3d.
80c after 10 minutes on cinebench with -20.
Cooled by the artic freezer duo 34.
Without -20, its more like 85c.
It's pulling 110 watts more or less.
Does this seem ok?
EDIT: I tightened he cooler a bit more, temps dropped around 5c. This always happens when I get a new cpu. :laugh:
But prime small ffts is a no go, instant 90c.
freeagent
9,817 (4.18/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
She’s hot.
168 (0.16/day)
Processor 5800x3D
Mouse XM1r
Keyboard Xtrfy K4
Yeah, prime 95 is off limits with this chip lol
Now I'm trying to automate the pb2 tuner software.
I'm pretty amazed atm, i dialed in -30 on all cores and corecycler is stable for 5 interactions. I will be doing much more testing but this is a promising start.
119 (0.10/day)
System Name Phenomenal1
Processor Ryzen 7 5800x3d
Motherboard MSI X570 Gaming Plus
Cooling Noctua NH-D15s with added NF-A12x25 fan on front
Memory Predator Vesta 32GB (2 x 16GB) DDR4 3600 BL.9BWWR.300 B-Die @3733 CL14
Video Card(s) PNY XLR8 RTX 4090 VERTO EPIC-X Triple Fan
Storage Boot SSD: SATA 500GB - 1tb + 4tb pcie3 nvme / Spinning Drives: 2tb + 6 tb
Display(s) Gigabyte M27Q 27" 1440P 170 Hz IPS BGR monitor
Case Fractal Torrent - Black
Audio Device(s) Realtek ALC1220P
Power Supply Super Flower Leadex VII XG 1000W
Mouse Razer Viper
Keyboard Razer Huntsman V2 Optical
Benchmark Scores Time Spy - 28594 https://www.3dmark.com/spy/51010148
5800X was thermally the worst Zen 3 CPU.
5800X3D has even worse thermals. Expect straight to 90C for most all-core workloads. There is no comparing to other Ryzen 5000 CPUs (Ryzen 7000 maybe).
All of these people reporting 90c temps have something wrong with their cooling. I upgraded from a 5800x to a 5800x3d (a family member needed a cpu so I took the opportunity to upgrade) and if the x3d is hotter it isn't by much. With a noctua nh-d15s and CO -30 (kombo strike setting 3) I'm idling at 42c and I've never seen it go over 78c in multi core workloads like cinebench. In my hottest running game, battlefield 5, I'm running in the low 70's. I'm having zero problems with this cpu, and I'm running on air.
CamoGeko
5 (0.00/day)
Mine never breaks 75C with Deepcool AS500 + 2 Noctua NF-A15 HS fans and 75W PPT limit.
Something is wrong with your cooling if you're reaching 90C.
tabascosauz
8,226 (2.33/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
  • People have different ambient temps - a bunch of these threads in the past year have been with 30C+ ambients.
  • Different boards and even different BIOSes on same boards perform wildly differently as to Vcore and core power. 4303 BIOS on the Impact requires a very hefty -0.075V Vcore offset just to get to the same Vcore as 4006 BIOS, and still runs up to 5 degrees hotter at higher power.
It's already well-known that temp variances between CPU samples are not good. @ 2:40
Stock 5800X3D is around 110-120W. If you're already hitting 75C at 75W then I hate to break it to you but cooling needs work (assuming a sane 20-25C ambient). AS500 is a reasonably strong cooler. Most of it comes down to cooler contact and mounting.
119 (0.10/day)
Mouse Razer Viper
In that video he says with normal cooling you probably wouldn't notice a difference between the two cpu's and that he's going to look into it some more probably in another video. I mean, look at that pc, it's as small as possible with everything packed in so tight you couldn't slip a piece of paper between components. There's no way these cpu's should be hitting 90c with adequate cooling unless the voltage is too high, and if you're running in a very hot environment you need the best possible cooling at the lowest possible voltage no matter what cpu you're running. It sounds to me like motherboad makers are just kind of doing whatever they want when it comes to voltage. The fastest cpu's run hot, they just do. And for people to just plug it in without any thought to taking precautions for heat seems disingenuous to me.
H1o84
1 (0.00/day)
Hello,
5800X3D aircooled (Be Quiet Dark Rock Pro 3) with -25 on all Cores (no other changes).
When i stress (CPU-Z all Cores) the CPU for about 15 minutes, i maximum get to 75,3 °C (highest Value i ever had with this CPU / System).
[The AMD 1600X i had before was max ~ 66°C in the same System but with stock settings]
Motherboard: Asus CH VI (x370)
Power: 850 Watt be quiet! Dark Power 13
Case: Thermaltake Core X 5 (all sides mesh / Motherboard Horzontal - i hate this Vertical Mounting especially with the big CPU air Cooler and the heavy air cooled Graphic Cards).
The Deepcool AS500 is smaller then my Cooler, but with 75W PPT you should get better Temperatures i think.
How is the airflow in your System? Maybe you have additional °C by using a closed, small or full packed Case?
ZShinko
1 (0.00/day)
I don't know why it happens but my temps also maxed out at 90C when playing and only small random peaks that rarely occurs, If I stress test my CPU with benchmarks or stress tests I just can't get past 76C Max temp (pulling around 110 to 120W). All test done while benching the GPU aswell, to get a more accurate result.
Ambient temp: ~29/31C
Mobo: Asus PrimeX570-P
Case: LianLi O11 XL
Everything in a Custom loop with:
60mm thick 360 bottom rad (intake fans pull config) (EK)
30mm thick 360 top rad (exhaust push config) (Bykski)
3 more fans on the side as intake
1 fan exhaust on the back
PNY 4090 XLR8 with an alphacool waterblock (usually tops at 57C (never seen it higher) iddles aroun 31 and 35C)
Bykski CPU for the 5800X3D waterblock (iddles at 41C and tops at 90C randomly and 76C with benchmarks and stress test)
Loop is going: res/pump -> 60mm rad -> GPU -> CPU -> 30mm rad -> back to the res
Running just destilled water with an avarage temp of 36 to 38C
All fans are Artic P12 and running only at 25% to 50% for temps under 80C and 50% to 100% between 80C and MAX temp
Pump always at 25% and 50% from 80C to 100C
AlvaBravo
4 (0.01/day)
Bengkulu, Indonesia
5800X3D is weird and hot, just like my Ex.
But still manageable for me, using 2x240 rads, and bykski cpu and gpu water block.
Got OK score I guess on cinebench R23 15125, max temp on cineR23 is 79~80°c, using ROG b550f, -30, offset - 0.0626v
iGigaFlop2
9 (0.01/day)
It runs hot i was using pbo2 tuner -30
on all the cores on a 5800x3d with a kracken x72 pretty much fans and pump maxed out and i would hit 80c maybe a little higher in cinebench. On my 7950x3d i moved to a arctic freezer ii 420 and it does really well the offset mounting seems to help ryzen cpu’s. When I moved from my 5950x to the 5800x3d i was very surprised how much hotter it ran. But I was surprised i did a tinker build with my old parts 5800x3d and 3080ti and I decided to air cool I hadn’t build a rig with air cooling in awhile and I didn’t want to spend much and picked up a thermalright peerless assassin 120 and i was surprised how good it does on the x3d.
17,671 (4.68/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Display(s) 27" QD-OLED Glossy 240hz 1440p
Case NZXT H710 (Red/Black)
Case: LianLi O11 XL
ambient is 29-31 celsius? wow. I honestly don't know how people like yourself can enjoy gaming in such hot conditions. that 87 faren for us Americans... yeah no way I am enjoying a game if my bedroom was that hot.
iGigaFlop2
9 (0.01/day)
I have a 1300watts psu, 7950x3d and a 4090 on my main build with 10 case fans and man it heats up my room my house has central ac but i had to put a window unit in my game room. Hell even the ps5 or series x can heat up the room though. Im still getting used to these new cpu temps what used to be crazy hot is now the norm
Deleted member 230939
My 5800x3D behaves ok, though it has a -72mv undervolt on the Thermalright 120 SE, it will rech 86c rendering with Handbrake.
CamoGeko
5 (0.00/day)
This is with me streaming and gaming on my 5800X3D for almost 9 hours straight in a 23C room. Cooled by a new Kraken 280 AIO with 2 Arctic P14 fans in front intake cooling setup, and 100W PPT in BIOS/-30 CO.
I wanted to go back to a dual air 120 fan air cooled setup but I have doubts that it would be able to cool my 5800X3D.
Mussels
Freshwater Moderator
58,412 (7.85/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Heat density is the issue. Bigger coolers dont help, it's 100% about the contact between the CPU die, the IHS, and your heatsinks base.
They're around the 120W mark, so bigger coolers dont help - but small changes to how the cooler is mounted or thermal paste is done, will.
Lower EDC or TDC can reduce the low core count spikes without harming the all core benches - you'd have to find a way match up the EDC and TDC values and see what they are at the moment the temps spike up (1-2 core benchmarks or something)
This matches my setup very closely, same offset and everything.
Camogecko: that image is useless with it cropped off and no explanation for what the values are. Use HWinfo64 and the windows snipping too.
AlvaBravo
4 (0.01/day)
Bengkulu, Indonesia
Yea, did anyone has tried to delid this chip??
Cause I cant find anything, other than one video on youtube, showing already delided chip, but no bechmark or whatsoever.
OR SHOULD I????
CamoGeko
5 (0.00/day)
What values are you looking for exactly??
I literally mentioned everything important in the text below the image.
Mussels
58,412 (7.85/day)
Oystralia
I'm not looking for anything from them - I'm just letting you know that image holds zero meaning since you cropped everything out.
Without the names of the values and categories, none of it is useful.
17 (0.03/day)
System Name Windows 10 pro
Processor AMD Ryzen 7 5800X3D
Motherboard Gigabyte B450 AORUS PRO
Cooling SilentiumPC Fera 3 HE1224 v2
Memory Corsair Vengeance LPX, DDR4, 32 GB, 3600MHz, CL16
Storage SSD Intel 660P 1TB M.2 2280 PCI-E x4 Gen3 NVMe
Display(s) iiyama G-Master GB2470HSU-B1 Red Eagle 165hz
Power Supply SilentiumPC Vero M2 Bronze 600W
Mouse Razer Orochi V2
Keyboard Klawiatura A4Tech Bloody B120
This processor simply by its construction is like that and so everyone has, no matter what cooling you have. I have Fera 3 and it's enough. This processor is hot for everyone and everyone. This is my third Ryzen and Ryzen, and this one is outstanding, they have temperature jumps, voltage spikes, clock spikes and it does not affect their lifespan at all. I will not do any undervolting, in load tests in OCCT, but in normal mode, max 84-85 degrees, in extreme mode it takes a minute and it is also around 90 degrees. And so does everyone, unless you have billion-dollar cooling. It doesn't matter if you have Fera 3 or 5 or you have Fortis 3 or 5, the processor will still be hot under full load, and the difference can be 2-3 degrees. This is a gaming processor if you knew you wanted to process VIDEO or work on it and constantly load it 100% and to the max then you should get a different processor. This processor is hot as long as it is 85 degrees, there is absolutely nothing to worry about and I think that AMD itself writes that this processor can work at 90 degrees all the time and so it will be and AMD knows very well that this processor can safely and work at 90 degrees all the time.
Mussels
58,412 (7.85/day)
Oystralia
It's definitely possible to run them cooler without needing bigger coolers - the biggest problem is motherboards sending higher voltages than they need and this definitely varies a lot between boards.
Undervolting helps, but ensuring PBO is set within the correct limits and not unlimited is all that's required to keep the temps controlled. Heck you can just alter the maximum temp in the BIOS directly, at the risk of performance loss on weaker cooling (80c for example, may last longer or be more stable since it's cooler for nearby components like VRM's and RAM)
I had to look up those coolers, if they've all got baseplates like this fortis 3 they're a bad choice for ryzen, since those gaps between the heatpipes can line up over your CPU dies and result in hotspots
direct
AMF
708 (0.51/day)
USA
System Name MR T System price $2464
Processor Ryzen 9 3900x 325 $4.7Ghz boost pbo +50 +50 enhance - offset auto voltage -.1875 offset soc
Motherboard ROG STRIX X570-E Gaming $ 125 open box
Cooling 280mm ARCTIC FREEZER II idle temps 25c cpu 28c cpu diode 20c vrm 25c motherboard b stock 60$
Memory 2x 16GB Dual rank G Skill Trident Z Neo F4-3600C16-16GTZNC @3800 1.415v 16-19-16-20-38-58-1T $96
Video Card(s) Asrock RX 6950XT Oc formula 705$ pcie4x16 2490 2735 boost 1110v 2388mhz mem 19GB/s
Storage 500 GB WD SN850 PCI-E 4.0x4 85$ pcie 4.0x4
Display(s) Vizio M50QXM-K01 4k@120hz 2.5k 120hz 2k@240hz $448
Case Cougar Panzer Max G Full Tower Tempered Glass 150$
Audio Device(s) Vzio M51a 5.1 Soundbar Dolby Atmos goodwill 45$!!!!
Power Supply Seasonic SS-1250XM2 Bought in 2013 350$ 11 y/o hasnt lost any voltage or watts
Mouse Perixx eRGO wireless Trackball 25$ 2000dpi
Keyboard Corsair K57 50$
VR HMD Dont give a damn about vr
Software win 11 pro modded by me no ai no remote connections free hehe
Benchmark Scores 8188 multi 540 single cinebench r20
this is what having a cool room will do
17 (0.03/day)
@Mussels This is probably the underside of Fery 5. I can assure you that this photo is just a false optical illusion. Although I also have such an interlacing of copper with some kind of steel, it is a surface that must be perfectly smooth and it is. I know what I'm saying because 3 days ago I was just cleaning the heatsink foot from 10 minutes of old paste, it's perfectly even. What you think it looks like, that there are some micro fissures, would have no right to exist. Believe me, this photo is an optical illusion. In games, the max is 84-85 and for a short time, in a normal stress test it is sometimes 77-83 and sometimes higher around 85. The worst thing is when I turn on the extreme mode in OCCT, then it really quickly reaches 90 degrees. For now, I will not do anything with it, these processors already have it, you have to learn to live with it and not worry about it.
freeagent
9,817 (4.18/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
My X3D runs nice and cool. I can run it semi passively and still retain full performance.. just a heatsink.
