How much power does your PC use?
277 (0.07/day)
System Name IVY BRIDGE
Processor i7 3770K
Motherboard ASUS P8Z77-V PRO
Cooling PHANTEKS TC14PE
Memory GSKILL ARES DDR3-1600
Video Card(s) GIGABYTE GTX 770 WF OC
Storage SAMSUNG 830 / GSKILL PHOENIX / SAMSUNG F4 / SEAGATE MOMENTUS / SEAGATE HDD 1.5
Display(s) ASUS 24" / DELL 20"
Case CORSAIR AIR 540
Audio Device(s) ASUS XONAR DG
Power Supply COOLERMASTER V700
Software WINDOWS 7 ULTIMATE x64
nice idea, i'll test once my GPU arrives in the mail
HammerON
The Watchful Moderator
8,400 (1.44/day)
Up North
System Name Aki
Processor AMD 7800X3D
Motherboard ASUS ROG STRIX X670E-A
Cooling MSI MAG CoreLiquid E360
Memory Patriot Viper Elite 5 32GB 6200
Video Card(s) PNY RTX 4090 XLR8
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard ASUS ROG Strix Scope II Wireless
Software Win 11 Pro
added your stock and max GPU OC, didnt think three entries for the one PC was needed.
Cool. I did all three as I was interested to see what load the GTX 780's put on the PSU at diferent over clocks. What I did find interesting is the Wprime watts went down from 205 to 191 when I had the GPU's at a pretty high over clock...
AsRock
TPU addict
19,177 (2.97/day)
UK\USA
Cooling D15
Mussells, thats pretty awesome power efficiency for a 7970 and a powerful cpu! Just shows modern cpu/gpu scalability. If I still had my xeon I'd probably wreck you guys, 3.5 ghz at .8v full load! Don't have a wall meter though :(
Buy one there about $20 for a cheap Kill A Watt, then you can see how much your words are really worth..
I hope your mobo is not like my old ASUS MAX mobo which i had a E8400 in it which due to the mobo idled 200w and not the typical 100w..
Morgoth
Fueled by Sapphire
4,253 (0.66/day)
Netherlands
Motherboard aorus x570 pro
Cooling air (GPU Liquid graphene) rad outside case mounted 120mm 68mm thick
Storage 300gb hdd OS backup. Crucial 500gb ssd OS. 6tb raid 1 hdd. 1.8tb pci-e nytro warp drive LSI
Display(s) AOC display 1080p
Case SilverStone SST-CS380 V2
Mouse corsair gaming mouse
Keyboard Microsoft brand
so what kind of power meter should be used?
oh and im getting unsuspected error "quitting"from Wprime
409 (0.08/day)
Processor 5900x
Motherboard MSI B550 Gaming Carbon
Cooling Artic freezer 280mm
Memory 32GB @ 3800Mhz
Video Card(s) RTX 3080 FE
Finners | Coolermaster silent pro gold 800w | i7 2600k @ 4.4GHz + GTX 680 SLI | 121w idle | 228w | P15942 526W | 30.31 points per watt
Mussels
Freshwater Moderator
58,413 (7.85/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
an accurate one. run it as admin, never had any problems here.
Mussels
58,413 (7.85/day)
Oystralia
can someone confirm my math here is correct, been a long time since i learned this electrical stuff:
lets say we do the WPRIME 1024M test, and measure the wattage.
we then go time (that wprime gives as a score) multiplied by wattage and get the joules of energy used (probably round it to kilojoules considering the numbers we'll be dealing with)
we can then rank the systems in order of least KJ used to finish the test.
sound correct?
1,051 (0.16/day)
Port Fairy, Victoria, Australia
System Name Rampage 3.0
Processor i7 3770K 4.2Ghz
Motherboard ASRock Z77 Extreme 4
Cooling Corsair 110 (280mm rad)
Memory 16GB G.Skill Sniper F3-1866 10-11-10 CR1
Video Card(s) 2 X gigabyte 7970 ghz edition @1100mhz / 6000mhz
Storage samsung 500 GB + 128GM crucial M4 ssd
Display(s) LG IPS235P 23in IPS 1080p
Case corsair vengance c70 - white
Audio Device(s) On Board
Power Supply Corsair HX-750w
Software Windows 7 Ultimate 64 bit
Add my result
Rampage | Corsair HX750 | i7 3770k @ 4.2GHz + 7970 X-Fire | 64w idle | 144w w prime | P16835 590W | 28.56 points per watt | daily settings x-fire
Rampage | Corsair HX750 | i7 3770k @ 4.2GHz + 7970 | 64w idle | 144w w prime | P10901 378W | 28.83 points per watt | daily settings single card
AsRock
TPU addict
19,177 (2.97/day)
UK\USA
Cooling D15
Add my result
Love to know how you got 64w idle.. Odd that you have the same idle with a single too
Mussels
58,413 (7.85/day)
Oystralia
AsRock
TPU addict
19,177 (2.97/day)
UK\USA
Cooling D15
hehe, tried it i have underclocked lowered the voltage as low as it can go got the system boot of one SSD with no video card installed although still booted in to windows and still not that low.
EDIT: on about how low they say on that site just to be clear.
1,051 (0.16/day)
as mussels has said the main reason for my lower idle wattage is my mobo, it was one of the key reasons i decided on the mobo in the first place.
also if i have worked out my KJ usage for wprime correctly i come out at 28.9 KJ (200.827 * 144 = 28919.088 (28.9 KJ )).
AsRock
TPU addict
19,177 (2.97/day)
UK\USA
Cooling D15
his second card powers down completely, he hasnt disabled ULPS.
his mobo accounts for most of the low wattage, its just a low powered board. he's my brother so i've looked into it before.
http://www.hardwareluxx.com/index.p...s/21959-test-asrock-z77-extreme4.html?start=5
yeah all so down to the gfx card too ( with 2 fans but no gfx).. Dunno why i could not get mine that low before but i just tried it again and got it down to what that review said, maybe i had a HHD plugged in and did not realize at the time.
Part of the reason i got mine as i got sick of the Maximus running 200w idle which was all so due to motherboard.
EDIT: it's the 8w difference with the cards.. Sorry i was just curious how you got it so low..
19,376 (3.51/day)
Just a note, power consumption in 11 will vary with the card used. For example, budget to low midrange will show more power use in the combined test than in any others while high end cards will be in the first four (likely test 3 iirc)
277 (0.07/day)
Processor i7 3770K
DF is BUSY
ANTEC 550w BP+ (80+ bronze)
i7 3770K @ 4.2GHz + GTX 760 @ stock
desktop idle = 135w
wprime 1024 watts = 206w
3dmark11 watts = 326w
3dmark PPW = 25.5
comment = daily settings, had all my fans running max though
5,459 (0.88/day)
Australia
What do you use to test your watts then Mussels?
Solaris17
Super Dainty Moderator
27,277 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
On my rig in specs on wprime I maxed at 350watts
Mussels
58,413 (7.85/day)
Oystralia
http://www.amazon.co_uk/dp/B000Q7PJGW/?tag=tec053-21
i have this with a converter to use aussie plugs (same voltage, just a socket change)
6,782 (1.36/day)
Processor 7800x3d
Cooling Custom Water
Case ThermalTake P3
Software Windows 11 64 Bit
James888 | XFX pro 850w | I7-4770k@ 4.375ghz +7970@ 1050/1850 | 95w idle | 210w wprime | P10923+ 360w | 30.34 PPW | Daily gamer, 213w boinc
http://www.3dmark.com/3dm11/7759198
I need crossfire to compete with some of the big boys here in benchmarks, but I am happy with gaming performance. My cpu is overclocked with high volts because I want a higher clock. If I went down to 4ghz and lower volts I bet PPW would be far greater.
James888 | Cougar SX 750w | Celeron G1620 @ 2.80GHz +7870 Tahiti @ 975/1500| 58w idle | 65w wprime | P5649 + 260 | 22.59 PPW | Cruncher/Miner, 65w boinc
http://www.3dmark.com/3dm11/7759306
The cpu is weak but sips power. Look at the idle vs WPRIME. I honestly think the cpu is holding back the gpu.
James888 | Cougar SX 850w | 2500k@ 4.4GHz + Intel HD3000 | 60w idle | 150w wprime | --- | --- | Dedicated cruncher, 130w boinc
A 3dmark score would of been too sad.
974 (0.17/day)
System Name Grond
Processor Ryen 5 3600x PBO ~ 4.4GHz / fabric at 1900
Motherboard MSI b550 Tomahawk
Cooling XSPC Raystorm CPU w/ am4 mounting bracket+ 2 RX360 radiator + xspc Razor R9-290 w/ backplate
Memory 32gb Crucial Ballistix @ 3800
Video Card(s) XFX R9 290 w/ XSPC Razor full cover block and backplate
Storage WD SN850 1tb-OS, SN750 1tb, Samsung 860 Evo 1tb, WD blue hdd 4tb
Display(s) Samsung 23" 120hz 3d LCD w/ 3d glasses, using 'lightboost' trick
Case NZXT H630 white watercooling case
Audio Device(s) Onboard realtek ALC 1200+ Sennheiser HD 598
Power Supply XFX Pro 850 XXX semi-modular
Mouse Logitech G703 Wireless
Keyboard Steelseries 6 v2
Software Windows 10 Pro (Had some mystery error on Win7 and decided to go W10)
I think my FX rig uses almost as much power @ load as a meth lab.
I don't have the equipment to measure thew power usage at the moment, but this thread has piqued my curiosity.
Aquinus
Resident Wat-man
13,177 (2.76/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
I have some numbers for the rig in my specs. GPU's are at stock speeds and voltages with my 24/7 OC on my 3820.
Aquinus | Seasonic X1000 Platinum | i7 3820 @ 4.5Ghz + 2x 6870 (Crossfire) | 217w | 340w | P8224 (400w avg/ 445w peek) | 18.4 points per watt @ peek | Stock GPU volts + freq.
I should note that the only time it ever hits peek is when it does the combined physics and graphics test. The rest of the time it's between 390 and 400. I used my UPS to measure power draw with only my tower on the battery backup.
187 (0.04/day)
Processor Intel® Celeron® Processor G1101
Motherboard Supermicro® MBD-C7SIM-Q-B
Memory 8 GB Silicon Power SP004GBLTU133N02/W02
Video Card(s) Sapphire FirePro™ 2270 + AMD Radeon™ HD 8740
Storage 1000 GB Toshiba P300 HDWD110UZSVA
Display(s) 29" LG 29UM57-P
Case Chieftec LBX-02B-U3
Power Supply 650W XFX XXX Edition (P1-650X-XXB9)
Software Windows Server 2016
WOW. 800 mV under full load? Isn't that something nearly impossible, or am I just unfamiliar with all this undervolting stuff?
6,782 (1.36/day)
Processor 7800x3d
Case ThermalTake P3
Take my 2500k, I have it overclocked to 4.5ghz at 1.35v. He had his xeon clocked at 3.5ghz at .8v.
187 (0.04/day)
Not trying to be offensive, but 1.35 V is not as impressive as 0.80 when we're talking about full load.
Haswell ULV can undervolt itself only into 0.730 V (1 core active, 800 MHz), and that's the most energy efficient platform ATM.
1.35 V still sounds pretty awesome for 4.5 GHz.
12,333 (2.24/day)
Oregon
Keyboard EVGA / Logitech K400
I have my scores soon. Im borrowing a meter
