- Dec 3, 2009
- 1,301 (0.23/day)
- The Netherlands
System Name | PC ||Zephyrus G14 2023 |
Processor | Ryzen 9 5900x || R9 7940HS @ 55W |
Motherboard | MAG B550M MORTAR WIFI || default |
Cooling | 1x Corsair XR5 360mm Rad|| |
Memory | 2x16GB HyperX 3600 @ 3800 || 32GB DDR5 @ 4800MTs |
Video Card(s) | MSI RTX 2080Ti Sea Hawk EK X || RTX 4060 OC |
Storage | Samsung 9801TB x2 + Striped Tiered Storage Space (2x 128Gb SSD + 2x 1TB HDD) || 1TB NVME |
Display(s) | Iiyama PL2770QS + Samsung U28E590, || 14' 2560x1600 165Hz IPS |
Case | SilverStone Alta G1M || |
Audio Device(s) | Asus Xonar DX |
Power Supply | Cooler Master V850 SFX || 240W |
Mouse | ROG Pugio II |
Software | Win 11 64bit || Win 11 64bit |
Add my results
Mathragh| Corsair AX860i | FX-8120 @ 4603 7950 stock | 151w idle | 345w | P7314 413W | 17.71 points per watt | Stock GPU
Mathragh | Corsair AX860i | FX-8120 @ 4603 7950 @1150/6300 1,26v | 124w idle 1 monitor | 484w prime95 | P9259 468W | 19.78 points per watt | prime95 instead of wprime, GPU OC, Idle Single monitor
measured with my 860i using corsair link, will do a wall measurement later if I've got time.
Slightly surprising to see my PC getting more efficient when I overclock my GPU, but I suppose with a cpu that can use over 300watts the GPU matters less for total power consumption compared to the average PC.
CPU currently at 4603MHz with a bus speed of 249, multiplier of 18.5, and a voltage of 1.43V
Edit: efficiency seems to adhere very closely to the graphs on the review page.
