How much power does your PC use?
12,333 (2.24/day)
Oregon
Keyboard EVGA / Logitech K400
This thread is a great reference for how much power systems use. It should be a sticky thread.
AsRock
TPU addict
19,176 (2.98/day)
UK\USA
Cooling D15
1,301 (0.23/day)
The Netherlands
System Name PC ||Zephyrus G14 2023
Processor Ryzen 9 5900x || R9 7940HS @ 55W
Motherboard MAG B550M MORTAR WIFI || default
Cooling 1x Corsair XR5 360mm Rad||
Memory 2x16GB HyperX 3600 @ 3800 || 32GB DDR5 @ 4800MTs
Video Card(s) MSI RTX 2080Ti Sea Hawk EK X || RTX 4060 OC
Storage Samsung 9801TB x2 + Striped Tiered Storage Space (2x 128Gb SSD + 2x 1TB HDD) || 1TB NVME
Display(s) Iiyama PL2770QS + Samsung U28E590, || 14' 2560x1600 165Hz IPS
Case SilverStone Alta G1M ||
Audio Device(s) Asus Xonar DX
Power Supply Cooler Master V850 SFX || 240W
Mouse ROG Pugio II
Software Win 11 64bit || Win 11 64bit
It appear Intel is much more efficient
To be fair, my CPU overclock is quite crazy, and this CPU is probably the worst one ever made when it comes to powerdraw. I know of no other (consumer) CPU that has the potential for so much power use when overclocked. Aquinus shows high end Intel CPU's can also still gobble up loads of watts btw as hes fairly close to me(albeit with higher idle power). I wonder how much those 6core i7s will pull max overclocked.
616 (0.13/day)
Nebulas
System Name X99
Processor 5930K @ 4.7GHz @ 1.323v
Motherboard Rampage V Edition 10
Cooling EK
Memory Dominator Platinum 32GB
Video Card(s) 2x Gigabyte xtreme gaming 980ti
Storage Samsung 950 Pro M.2, 850 Pro & WD320
Display(s) Tempest X270OC @100Hz
Case Thermaltake Core P5
Audio Device(s) On-board
Power Supply 120-G2-1600-X1
Mouse Mamba 2012
Keyboard K70
Software Win10
Benchmark Scores http://www.3dmark.com/fs/6823139
10 cents Kw/hr @ 1250 watts is $3.00 a day. That is mostly GPUs computing.
Mussels
Freshwater Moderator
58,413 (7.86/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
6,782 (1.36/day)
Processor 7800x3d
Cooling Custom Water
Case ThermalTake P3
Software Windows 11 64 Bit
.0877 kw/h. I see why your so power conscious mussels at that price.
415 (0.09/day)
An update to my post.
My 3970X is now overclocked to 4.1Ghz on all cores with only 1.175V. Same voltage as before, just higher frequency.
Too bad offset wont work with such a high voltage drop at load, so the idle consumption went up about ~7W
Nokiron | Corsair AX1200i | i7 3970X@4.1Ghz 1.175V - Asus GTX 780 1202/7208 | 121W idle | 226W | P13597 398W | 34.16 points per watt
Total gained, 1 point per watt.
http://valid.canardpc.com/y8cx5i
4,357 (0.88/day)
Mexico
System Name Dell-y Driver
Processor Core i5-10400
Motherboard Asrock H410M-HVS
Cooling Intel 95w stock cooler
Memory 2x8 A-DATA 2999Mhz DDR4
Video Card(s) UHD 630
Storage 1TB WD Green M.2 - 4TB Seagate Barracuda
Display(s) Asus PA248 1920x1200 IPS
Case Dell Vostro 270S case
Power Supply Dell 220w
Software Windows 10 64bit
Add my result
TRWOV | Seasonic S12D 80+ Silver | i7 3770K @ 3.9GHz + 7970 OC Boost bios #1 | 105w | 169w | P9423 306W | 30.79 | www.3dmark.com/3dm11/7853488
4,357 (0.88/day)
Mexico
Since it can't run 3d11 these results won't go into the table:
Silverstone SFX 450w 80+ Bronze
QX6800 @ 3Ghz
HD 4670 AGP 825/1100
Asrock Conroe865PE
4GB DDR400
Ageia Physx PPU
Audigy 2 ZS
Idle: 132w
wprime 1024: 213w
3dmark06 demo: 227w
tried running 3d06 and Vantage but I got a higher reading with the 06 demo :ohwell:
The first test was the one that gave me the highest reading. I did the whole test ;) All the rest of the benchmark was under 360w
Same for me, I'd think the combined test would give the highest reading.
415 (0.09/day)
Got hold of an Gigabyte GTX 780 Ti, overclocked to 1262 / 7500
Nokiron | Corsair AX1200i | i7 3970X@4.1Ghz 1.175V - Gigabyte GTX 780 Ti 1262/7500 | 121W idle | 226W | P14705 415W | 35.43 points per watt
manofthem's 37.29 PPW is quite hard to get to :D need to test with an R9 290(X).
2,597 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 4X D5T Vario, 2X HK Res, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01
Video Card(s) MSI 4070 Ti Super w/Alphacool Eisblock Aurora RTX 4070TI Ventus with Backplate :13724
Storage Samsung 990 PRO 1TB M.2
Display(s) LG 32GK650F
Case Custom open frame chassis
Mouse Logitech MX700
Keyboard Logitech LX700
Software Win11PRO
Arctucas | Corsair AX1200 | i7 950 @ 4273MHz + SLi 560Ti @ 875/2050 | 268W idle | 365W | P9015 615W | 14.66 points per watt | Meh...
Of course, with a D5 Vario, 4xSSD, 7x140mm and 1x120mm fans, MOSFET cooling fan, RAM cooler, soundcard, TV card my result may not be perfect.
Mussels
58,413 (7.86/day)
Oystralia
we have a booby prize winnnnnneerrrrr!
2,597 (0.38/day)
Software Win11PRO
Heh...
And yet, with the extraneous hardware, I am not on the bottom of the 3DMark points per watt list, slightly edging out your second entry.
When may I expect to receive my glorious reward?
6,782 (1.36/day)
Processor 7800x3d
Case ThermalTake P3
He would give it to you but its NSFW so he can't post it here...
Aquinus
Resident Wat-man
13,175 (2.76/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
If I knew there was a prize involved, I would have OC'ed my GPUs as well and my CPU more. :p
954 (0.23/day)
Cumberland Plateau
System Name EVGA-FX | Lenny (Lenovo Y480)
Processor AMD FX-8320 @ 4.5GHz 1.416v | i7 3610qm
Motherboard Asus M5A99FX Pro R2.0
Cooling Phanteks PH-TC14PE
Memory 2x4GB Corsair Vengeance @ 1600 | 8gb DDR3 @ 1600
Video Card(s) EVGA GTX780 Classified @ 1228MHz 1.615v | GT640m LE
Storage Crucial M500 480GB, WD Caviar Blue 500GB, WD Scorpio Blue 750GB | Samsung 250GB 840
Display(s) Qnix QX2710 1440p | 42" Vizio 3D LCD TV 1080p
Case CoolerMaster HAF XB Evo
Power Supply Seasonic G-650
Software Windows 6.3.9600
FX-GMC | Seasonic G-650 | FX-8320 @ 4.6GHz + GTX760 | 97w idle | 249w | P8757 405W | 21.62 points per watt |
its a multi threaded CPU benchmark. for now its just 'how much power does your CPU use' as opposed to 3dmarks 'cpu and gpu' result. i'll end up adding something like watts over time (300 seconds + 200W = 60,000 joules of energy used) to determine who has the most power efficient CPU, but i'll have to double check my math on that one after work before i add it in.
Too bad you didn't go IntelBurnTest. My proc uses 365w in it compared to 249w for wPrime.
Mussels
58,413 (7.86/day)
Oystralia
i'm happy to add more tests to the table, we can even come up with a V2 if we re-do it all with new tests. i'd like a CPU test that gives us a points score, so we get points per watt there as well.
954 (0.23/day)
Cumberland Plateau
Cinebench R15 Maybe? My points per watt is 2.42 to give an idea, although that'll be close to the bottom of the scale.
EDIT: When do I get to be in the chart? :ohwell:
webguy09
24 (0.01/day)
My 750W PSU is surprisingly efficient, actually. For normal usage. I think it was the Corsair 750 something. It's been awhile, I'll have to look it up. Enthusiast series, I remember. Also I try to turn it off at night now to save power.
HammerON
The Watchful Moderator
8,400 (1.44/day)
Up North
System Name Aki
Processor AMD 7800X3D
Motherboard ASUS ROG STRIX X670E-A
Cooling MSI MAG CoreLiquid E360
Memory Patriot Viper Elite 5 32GB 6200
Video Card(s) PNY RTX 4090 XLR8
Case Corsair 5000D Airflow
Mouse Roccat Kone Pure
Keyboard ASUS ROG Strix Scope II Wireless
Software Win 11 Pro
Bump for a good thread:toast:
Let's see some more power usage!!!
954 (0.23/day)
Cumberland Plateau
Add my result
12,333 (2.24/day)
Oregon
I know, I love this thread
954 (0.23/day)
Cumberland Plateau
I gave up on this thread when my score was never added. Then I realized I never explicitly said "add my result"(DOH...my fault). If my old results get added I'll do a retest with my new gfx card.
12,333 (2.24/day)
Oregon
He'll get to it . Probably on vacation. This thread is a good reference.
Mussels
58,413 (7.86/day)
Oystralia
repost it in the correct format. I aint going hunting back through for edited posts.
