How much power does your PC use?
jAh76
2 (0.00/day)
Add my results
jAh76 | Seasonic 300W | i5-2500K @ 4000 MHz GTX 670 @ 1267/1802 MHz | 55W | 115W | P9241 295W | 31.32 ppw | by EnergyCheck3000 230V
38 (0.01/day)
Deutschland
System Name Ghetto Cluster
Processor 12x Intel Celeron @ 2,4GHz
Motherboard Foxconn
Cooling 1 Fan/CPU, nothing else
Memory 48x 256MB DDR2 Sticks
Video Card(s) None
Storage 24x 120GB HDD + 1x 64GB SSD (Controller) + 4x 500GB HDD (Controller)
Display(s) 2x Old TFT Panel (for debugging)
Case Very old Gigabyte Reference Cases
Audio Device(s) Hah
Power Supply 12x 235W NoName
Software minx7 (smaller than Tiny7, faster for Cluster Solutions)
I guess my system isn't aimed to be in this list. I work part time (beside school) in the University. My "System" is a bunch of old PCs linked together. They all run a heavily modified version of Kolibri OS (in Dual-Boot with Tiny7 for Diagnosis) and they are constantly analyzing huge sets of genomes to calculate various probabilities for the binding of certain transcription factors (boring, I know ;-) )
Anyway. There are currently 12 Machines (constantly) running plus 1 to 4 additional (more powerful) machines. The most PCs feature a Intel Celeron which runs usually OCed (except for 2 to 3 machines). The TDP for one machine is 235W, but considering they run OCed and constantly under full load, they still do not consume more than 187W/machine. This sums up to ca. 2.244 kW. I'm glad I don't have to pay for the power :D . The power outlets in my lab can take about 3.2 kW before they emergency shutdown. (The seams to be space, but consider diagnosis monitors and switches/routers/etc running, too).
One value which is totally missing in the chart is the loudness. From just the network running at +42dB the system under full load with everything turned on scores +62dB :D .
[Currently I work on a new Cluster-Controller to take network managing tasks almost completely away from the single machine. For this purpose, a Intel Xeon Server is added next week]
12,333 (2.24/day)
Oregon
Keyboard EVGA / Logitech K400
Add my results
So I'm not a "buy a big PSU for no reason" kind of guy. But a 300w PSU? The GTX 670 uses 170w at full load and the i5 2500K is 125W at load. And if I remember correctly Seasonic does not make a high efficient 300w PSU. So how you doing this ?
6,782 (1.36/day)
Processor 7800x3d
Cooling Custom Water
Case ThermalTake P3
Software Windows 11 64 Bit
Must be undervolted pretty heavily on the cpu. That 670 is overclocked and I doubt it is undervolted. Not to mention the drives and everything either.
manofthem
WCG-TPU Team All-Star!
10,960 (2.13/day)
Florida
Processor 3900X @ 4.0
Cooling DeepCool Castle 360EX
Storage Sabrent Rocket Q 1TB
Display(s) LG 34UC88
Case Thermaltake P3
Mouse Logitech G900
When I swap my stuff around and changing psus, I'm going to be redoing my results, and I'll be adding in my other pc, though it's not too grand at all.
Glad to see so many people adding in their results; we've seen a real assortment of all kinds of hardware.
954 (0.23/day)
Cumberland Plateau
System Name EVGA-FX | Lenny (Lenovo Y480)
Processor AMD FX-8320 @ 4.5GHz 1.416v | i7 3610qm
Motherboard Asus M5A99FX Pro R2.0
Cooling Phanteks PH-TC14PE
Memory 2x4GB Corsair Vengeance @ 1600 | 8gb DDR3 @ 1600
Video Card(s) EVGA GTX780 Classified @ 1228MHz 1.615v | GT640m LE
Storage Crucial M500 480GB, WD Caviar Blue 500GB, WD Scorpio Blue 750GB | Samsung 250GB 840
Display(s) Qnix QX2710 1440p | 42" Vizio 3D LCD TV 1080p
Case CoolerMaster HAF XB Evo
Power Supply Seasonic G-650
Software Windows 6.3.9600
repost it in the correct format. I aint going hunting back through for edited posts.
Mussels | Corsair HX1000 | i5 2400 @ 3.7GHz + 7970 | 89w idle | 134w | P9193 301W | 30.54 points per watt | i'm the bestest
I seriously don't know what you're on about. I posted the same thing in post #92 and #97 and it looks the same as yours.... If it truly is wrong at least give me a hint.
EDIT: Just read that again. This is my only edited post in this thread that contains scores.
Mussels Please Add my Result
FX-GMC | Seasonic G-650 | FX-8320 @ 4.6GHz + GTX760 | 97w idle | 249w | P8757 405W | 21.62 points per watt |
Mussels
Freshwater Moderator
58,413 (7.86/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
third from the bottom, been in there for a while. i may have quoted an older post, my browser takes me to old pages sometimes when i click the email links,
jAh76
2 (0.00/day)
So I'm not a "buy a big PSU for no reason" kind of guy. But a 300w PSU?...
Yes, 1267 Mhz @ 1.150 uses full 100% of TDP. This just for the test.
and under volt 1137 Mhz @ 1.037 uses only 65% of TDP.
Cpu load is 65% of TDP in Wprime test. 4000 @ 1.15V. Other parts 2.5"hdds+ssd
753 (0.17/day)
System Name Chaos
Processor Intel Core i5 4590K @ 4.0 GHz
Motherboard MSI Z97 MPower MAX AC
Cooling Arctic Cooling Freezer i30 + MX4
Memory 4x4 GB Kingston HyperX Beast 2400 GT/s CL11
Video Card(s) Palit GTX 1070 Dual @ stock
Storage 256GB Samsung 840 Pro SSD + 1 TB WD Green (Idle timer off) + 320 GB WD Blue
Display(s) Dell U2515H
Case Fractal Design Define R3
Power Supply Corsair HX750 Platinum
Mouse CM Storm Recon
Keyboard CM Storm Quickfire Pro (MX Red)
Yes they do. In some non-ATX formats.
Also, look at my rig. I think some of the people on the forums would have their heads explode when they see I'm not running a 600+W PSU. Such is the way of the uninformed.
12,333 (2.24/day)
Oregon
Mussels
58,413 (7.86/day)
Oystralia
Did you look at mine? I use 405w at full load
or even my results, the very reason i started this thread. sure i have a 1KW PSU - because i got it second hand for $100. if i was buying new i'd grab a corsair (or equivalent good brand) 450W and be quite happy.
753 (0.17/day)
System Name Chaos
Actually, I support this thread, especially as it combats exactly the kind of wrong thinking that gets people to buy a 750W PSU for a system barely touching 200W at full blast.
And I didn't say YOU aren't aware of real-world power consumption numbers, I said that some of the people on this forum are. I'm never afraid of saying things directly to people, so if I meant you specifically, I'd say so openly ;)
At any rate, I cannot contribute to the thread because my power meter fell victim to a very bad generic "500"W PSU that died under load, and I haven't bothered with getting a new one...
Should that change in the near future, I'll bring something useful to the table :)
3,539 (0.67/day)
Netherlands
System Name AP201 | N2Plus | NUC
Processor AMD Ryzen 5 3600 | Amlogic S922X | Intel Core i5-7260
Motherboard Gigabyte B550M DS3H |Odroid N2+ | NUC Board 7
Cooling Inter-Tech Argus SU-200, 3x Arctic P12 & 1x Corsair 140mm case fan | stock heatsink+fan | stock HSF
Memory Gskill Aegis DDR4 32GB | 4 GB DDR4 | 16 GB DDR4
Video Card(s) Sapphire Pulse RX 6600 (8GB) | Arm Mali G52 | Iris Plus 640
Storage SK Hynix 240GB, Sam. 840 + 850 EVO (2x (250 GB)| Samsung 850 Evo 500GB | WD Green 240 GB
Display(s) AOC G2260VWQ6 | LG 24MT57D |
Case Asus Prime 201 | Stock case (black version) | Stock case
Audio Device(s) integrated
Power Supply BeQuiet! Pure Power 11 400W | 12v barrel jack | 19V laptop brick (Asus)
Mouse Logitech G500 |(runs mostly headless) | no-name ergo mouse
Keyboard Qpad MK-50 (Cherry MX brown)| (runs mostly headless) | Blaze Keyboard
Software Fedora, Windows 10 | Gentoo Linux | EndeavourOS
Mine idles at ~45w and under semi-maximum load (4 cores BOINC and Furmark) somewhat below 140w. Typical load lies between 45 and 65 watts but I did not do thorough enough testing.
manofthem
10,960 (2.13/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
It's been awhile since this thread has seen any action :p
I just switched out my HX1000 for an AX1200, so I'l be rerunning the benches to see if there's any difference.
manofthem
10,960 (2.13/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
Come back alive, PC-Power Thread!
Please add my result :)
manofthem | Corsair AX1200 | i7 4770k @ 4.4Ghz + R9 290 1050/1350 | 73w | 185w | p13737 353w | 38.92 points per watt | BOINC 192w / 3DMark13 382w
Reran this since I changed my HX1000 out for an AX1200. Obviously the higher efficiency of the AX works out well, as all my power dropped a little bit.
Mussels
58,413 (7.86/day)
Oystralia
added. one day i look forward to a new PSU and silly low wattages...
HammerON
The Watchful Moderator
8,400 (1.44/day)
Up North
System Name Aki
Processor AMD 7800X3D
Motherboard ASUS ROG STRIX X670E-A
Cooling MSI MAG CoreLiquid E360
Memory Patriot Viper Elite 5 32GB 6200
Video Card(s) PNY RTX 4090 XLR8
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard ASUS ROG Strix Scope II Wireless
Software Win 11 Pro
Bump for an interesting thread:)
FreedomEclipse
~Technological Technocrat~
24,446 (3.76/day)
Hong Kong
System Name WorkInProgress
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
I hope this is all correct - I read the instructions on how to do this correctly but my brain just said NOPE when it came to the division part and I was like "divide by what exactly? this shit doesnt make sense, say wuuuuuuuuuuut??!!" and i got mad about it and i said i was done with this shit cuz i didnt understand the question and i was gonna throw some results up for somebody to arrange and calculate it but when I was making this post it all just finally made sense what i needed to do so....
FreedomEclipse | Corsair AX860 80Plus Platinum (94% Efficiency@50%) | i7-3930k @4600MHz + Nvidia GTX 680 SLI | 130W | 338W | P17864 566W | 31.56 ppw | Stock GPU + Belkin Conserve Insight power meter
I ran the 3D11 test twice and i did notice the power consumption shoot to 570w a few times but it dropped back to 566w in a matter of seconds and 566w turned out to be the average consumption even though the numbers bounced in between 560w & 566w so my results arent 100% accurate but they are most likely within margin of error (being anywhere between 3-8% off target)
Been meaning to do with for a while but since my HX1050 started croaking and got replaced I decided to get this out the way.
Mussels
58,413 (7.86/day)
Oystralia
added. im interested to see how the performance per watt scales in future generations, if it gets better or maintains the status quo
manofthem
10,960 (2.13/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
Soon I will be adding my i3 with a 290 (550 bronze), then probably the i3 with a 7770 (again 550 bronze); then my i7 with 290 crossfire (1200 gold); it should be interesting. :)
i'm going out of town for a bit, but when I get back, i'll add the pcs ;)
Ruru
S.T.A.R.S.
13,347 (3.00/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
Dunno, don't have a meter, but I suppose it's about 400 watts in load? 2500K @ 4.5GHz 1,45V, 8GB 1600MHz, GTX470 @ 800/1800 1.125V
Mussels
58,413 (7.86/day)
Oystralia
:slap:
3,015 (0.52/day)
MN
System Name Personal / HTPC
neatfeatguy | CoolerMaster Silent Pro 1000W (85% efficiency) | i5 4670K @ 3.6GHz + GTX 570 SLI | 115W | 158W |P9612 520W | 18.48 | 3 monitors setup, 5040x1050
My PSU is a bit of an overkill, but came in handy when I had the Phenom II x4 940 OC'ed to 3.7, I was hitting upwards of 680W). When I threw a decent OC on the 570s I was hitting around 750W. It sure is nice to have a better CPU that uses a lot less power and provides a lot more performance.
Mussels
58,413 (7.86/day)
Oystralia
oh yeah, going from my thuban x6 to this i5 was a crazy difference. faster, cooler, lower wattage.
19,376 (3.51/day)
A couple of things...
1. 2500K is a 95W chip at WORST with it and its iGPU at 100%.
2. 670 TDP is 170W, however at stock speeds, you wont reach that... not close, actually.
3. Seasonic makes a 'high efficiency' 300W PSU (bronze). But I am not sure what efficiency has to do with his load (I know the thread title, but the way your statement was written it seemed to mean it would affect the output?). There is also a 380W standard ATX PSU as well. ;)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151090
