Jonbee.603
- May 20, 2023
- 7 (0.01/day)
After curing and reassembly, I can confirm that I cannot hear the noise unless I remove the PC door and put my ear directly up to the GPU. I would say this was a raging success!
And obviously avoid gluing over stuff that comes in contact with thermal pads; super glue is not a conductor, but it would insulate your chip from the heat transferrance of the thermal pad.
System Name | Work Computer | Unfinished Computer |
Processor | Core i7-6700 | Ryzen 5 5600X |
Motherboard | Dell Q170 | Gigabyte Aorus Elite Wi-Fi |
Cooling | A fan? | Truly Custom Loop |
Memory | 4x4GB Crucial 2133 C17 | 4x8GB Corsair Vengeance RGB 3600 C26 |
Video Card(s) | Dell Radeon R7 450 | RTX 2080 Ti FE |
Storage | Crucial BX500 2TB | TBD |
Display(s) | 3x LG QHD 32" GSM5B96 | TBD |
Case | Dell | Heavily Modified Phanteks P400 |
Power Supply | Dell TFX Non-standard | EVGA BQ 650W |
Mouse | Monster No-Name $7 Gaming Mouse| TBD |
Doubt it would work. Even gel-type super glue is said to be too thick (viscous) for the application, let alone RTV.Apply RTV low viscosity silicone to the inductors (all). Like this: https://www.aliexpress.com/item/100...order_list.order_list_main.290.21ef1802T9JEa8
Could work, maybe not. I suspect the casing of the inductor is used as part of the "core" and grinding on it would change the induction characteristics. It might help, it might hurt, but I personally wouldn't do it.Perhaps I can attempt to grind the top of the inductor and then apply the silicone. I have ordered some sample inductors on the internet where I can practice. However, this is VERY risky, and I am hesitant to proceed with this method.
Some here have had a lot of luck with that. I would say it is a good first step, unless your card is already denuded, then try the super glue first as it would be cheaper.Add ferrite beads to the PCI-E power cable???
The bottoms are generally open. However, putting it in a full vacuum chamber would only tend to harden most silicone based RTV, as it would evaporate off the acetic acid much quicker. I doubt it would help draw into the inductor as there is no suction up into it, just general low pressures.Put the PCB into a vacuum chamber (I created one) so that the silicone can potentially penetrate the inductor. However, I am unsure whether the bottom of the inductor is open or not....
Could work, but I don't think I would be able to help you find the right ones. From what I see, it tends to be the random combination of PSU and GPU that causes coil whine. New inductors may or may not help with that.Solder out the inductors and replace it with a quality ones. However, I can't download the datasheet for the current ones, so I don't know which inductors I can replace them with.
Would help with the whole inductors vibrating, but if the coil is hitting the core it won't help much. It would of course absorb some vibration.Also put thermal pads on top of the inductors so they will be attached to the GPU water-cooling block and reduce the vibrations.
OMG!Doubt it would work. Even gel-type super glue is said to be too thick (viscous) for the application, let alone RTV.
I'm about to try this myself on my whiny 4070 - got some ultra-low-viscosity CA and a set of syringes; I would rather inject than squeeze, as the control is better.A forum user recently asked about Coil Whine, which is the noise a choke coil sometimes makes as it operates. This is almost always a video card problem, but can happen on any other computer or electronics components employing a choke in it's circuitry, including motherboards & power supplies.
I have for decades been using a very easy, quick and, most importantly, permanent fix. This fix works 95% of the time to quiet the noise to the point that it is not audible more than 8inches/20cm away. The rest of the time, the noise is barely audible.
A word of caution! If your part is under warranty, you may wish to consider doing an RMA. Many(not all) manufacturers actually want the noisy part back so they can test and analyze it for re-engineering to improve future designs. If your part is NOT under warranty, read on...
What you need:
Any tools required to disassemble the part to access the choke coils in question.
One or more containers of thin liquid cyanoacrylate based glue, commonly known as "Super Glue".
The brand of super glue you choose is not important. The type is. The type must be of low viscosity so it can quickly wick into the empty spaces between the choke coil and the board it's soldered to. The applicator having a narrow tip nozzle is important as it will make applying the glue more precise. See below.
This is what I plan to do in addition to gluing the internals.Also put thermal pads on top of the inductors so they will be attached to the GPU water-cooling block and reduce the vibrations.
I bought a selection of pad thicknesses from eBay for this very reason - I will start with the thinnest ones, tighten the block down, and check for indent, increasing thickness each time until I see some contact.@Arcsaber Please be very careful with thermal pads thickness and if they don't match don't allow PCB to bend or otherwise You will kill Your GPU. Learned that hard and expensive way ;/
Also from my, failed, experiments with thermal pads above inductors - didn't noticed any difference, it doesn't matter, with or without it did coil whined.
NOTE: alpha cool replied to Me that on their water blocks they don't use thermal pads for inductors as they are not needed.
You're welcome! Sorry I didn't respond sooner, took a break from TPU for a few months.Hi
@lexluthermiester Thank you for this great thread!
If you're still wanting to give it a go, it's worth a try.I have an Asus TUF RTX 2080 Super with coil whine.
The coils in this card look like this:
Anyone had success with those types? They look like closed casings.
Otherwise I might just have to try it.
Nice! Out of curiosity, which card do you have?I'm about to try this myself on my whiny 4070 - got some ultra-low-viscosity CA and a set of syringes; I would rather inject than squeeze, as the control is better.
Will record a before and after and take pics of the process.
System Name | EventHorizon |
Processor | Intel® Core™ Processor i9-13900KF 8P/16 + 16E 3.00GHz [Turbo 5.7GHz] 36MB Cache LGA1700 |
Motherboard | ASUS PRIME Z790-P |
Cooling | CyberpowerPC MasterLiquid Lite 240mm ARGB CPU Liquid Cooler |
Memory | 32GB (16GBx2) DDR5/6000MHz Dual Channel Memory (KINGSTON FURY BEAST RGB) |
Video Card(s) | GeForce RTX™ 4080 16GB |
Storage | 2TB WD BLACK SN850X (PCIe Gen4) NVMe M.2 SSD - Seq R/W: Up to 7300/6600 MB/s, Rnd R/W up to 1200/110 |
Display(s) | LG 34'' |
Case | CyberPowerPC HYTE Y60 Dual Chamber Mid-Tower Gaming Case w/ Panoramic View Tempered Glass + 2x120mm |
Audio Device(s) | Asus Strix w/Alan Finote mod for Windows 11 |
Power Supply | High Power 1300W 80+ GOLD Full Modular w/ PCIE 12+4Pins Connector for PCIe 5.0 graphics cards |
Mouse | Steelseries Rival 600 wired |
Keyboard | Steelseries Apex 7 TKL red Switch |
Software | Win 11 Pro |
YW!Thanks Lex, nice tutorial. I'm glad it got resurrected.
Ah! Thank You for that link. I want to try that stuff!I have one that is really thin that would work well with this.
There is a noticeable smell while it's curing. Once it's fully cured, you're right, there shouldn't be any smell as the chemical reactions are complete.I saw one post way back that was poopooing the Super Glue heat up and smell afterwards. This should not be an issue. Cyanoacrylate has a moisture cure process and once it's done, it's done. Nothing to evaporate (smell).
4070 Ventus - not many chokesNice! Out of curiosity, which card do you have?
System Name | Brightworks Systems BWS-6 E-IV |
Processor | Intel Core i5-6600 @ 3.9GHz |
Motherboard | Gigabyte GA-Z170-HD3 Rev 1.0 |
Cooling | Quality case, 2 x Fractal Design 140mm fans, stock CPU HSF |
Memory | 32GB (4 x 8GB) DDR4 3000 Corsair Vengeance |
Video Card(s) | EVGA GEForce GTX 1050Ti 4Gb GDDR5 |
Storage | Samsung 850 Pro 256GB SSD, Samsung 860 Evo 500GB SSD |
Display(s) | Samsung S24E650BW LED x 2 |
Case | Fractal Design Define R4 |
Power Supply | EVGA Supernova 550W G2 Gold |
Mouse | Logitech M190 |
Keyboard | Microsoft Wireless Comfort 5050 |
Software | W10 Pro 64-bit |
I too am very interested in this product based entirely on your comment, "The bottles don't dry out". That has always been my complaint about super glue. I have never, as in NEVER EVER used up an entire bottle or tube of any cyanoacrylate based glue. They have always dried/hardened soon after opening. I say "soon" but frankly, I have no clue how "soon" they dried - I only know the next time I needed it, it was dry and I had to buy more.I have one that is really thin that would work well with this. The bottles don't dry out.
I got this one:I too am very interested in this product based entirely on your comment, "The bottles don't dry out". That has always been my complaint about super glue. I have never, as in NEVER EVER used up an entire bottle or tube of any cyanoacrylate based glue. They have always dried/hardened soon after opening. I say "soon" but frankly, I have no clue how "soon" they dried - I only know the next time I needed it, it was dry and I had to buy more.This drying is also why I always buy the smallest size tube/bottle available, even though cost per gr/oz will be higher. I would rather throw out half a 2oz bottle than 3/4 of a 4oz bottle.
So, when you say they don't dry out, what sort of time period are you talking?
This Gorilla Super Glue with 3gr packs is less wasteful (for me) but it is not super thin.
I have 2 bottles. One of the thin and one that is thicker, the same brand as I linked.I too am very interested in this product based entirely on your comment, "The bottles don't dry out". That has always been my complaint about super glue. I have never, as in NEVER EVER used up an entire bottle or tube of any cyanoacrylate based glue. They have always dried/hardened soon after opening. I say "soon" but frankly, I have no clue how "soon" they dried - I only know the next time I needed it, it was dry and I had to buy more.This drying is also why I always buy the smallest size tube/bottle available, even though cost per gr/oz will be higher. I would rather throw out half a 2oz bottle than 3/4 of a 4oz bottle.
System Name | CyberPowerPC ET8070 |
Processor | Intel Core i5-10400F |
Motherboard | Gigabyte B460M DS3H AC-Y1 |
Memory | 2 x Crucial Ballistix 8GB DDR4-3000 |
Video Card(s) | MSI Nvidia GeForce GTX 1660 Super |
Storage | Boot: Intel OPTANE SSD P1600X Series 118GB M.2 PCIE |
Display(s) | Dell P2416D (2560 x 1440) |
Power Supply | EVGA 500W1 (modified to have two bridge rectifiers) |
Software | Windows 11 Home |
I've never tried that. Does cooling them preserve them?I actually keep my glues in the fridge (not freezer), which the wife allows; but that means letting the epoxy warm up each time.
System Name | Space Station |
Processor | Intel 13700K |
Motherboard | ASRock Z790 PG Riptide |
Cooling | Arctic Liquid Freezer II 420 |
Memory | Corsair Vengeance 6400 2x16GB @ CL34 |
Video Card(s) | PNY RTX 4080 |
Storage | SSDs - Nextorage 4TB, Samsung EVO 970 500GB, Plextor M5Pro 128GB, HDDs - WD Black 6TB, 2x 1TB |
Display(s) | LG C3 OLED 42" |
Case | Corsair 7000D Airflow |
Audio Device(s) | Yamaha RX-V371 |
Power Supply | SeaSonic Vertex 1200w Gold |
Mouse | Razer Basilisk V3 |
Keyboard | Bloody B840-LK |
Software | Windows 11 Pro 23H2 |
I know this is off topic, but I've been thinking of doing a CA injection to solve the one flaw in the best on-bike chain cleaning tool for my mt bike, which is made by Park Tool. It won a shootout test, but it's brush bristles can fall out here and there and get stuck in your chain.My kit arrived - glue and syringes/needles
View attachment 350781View attachment 350782
The whole bag of syringes was less than a fiver on eBay - I plan to hit each choke near one leg, so the glue is drawn up through the hole; when it starts leaking out from underneath, I'll know it's done.
Can you post a link to those syringes though?
Yes, it does - it's how Loctite stores, them, as far as I know.I've never tried that. Does cooling them preserve them?
