Inconsistent POSTing on PC ( already replaced multiple parts)
302 (0.64/day)
System Name SYSTEM
Processor RYZEN 7 5700X
Motherboard TUF B550M GAMING PLUS
Cooling AG620 CPU COOLER
Memory 16GB RAM DUAL CHANNEL 3200MHZ STOCK
Video Card(s) RTX 4070 GIGABYTE 12GB WINDFORCE
Storage 1TB HDD 256GB SSD
Display(s) LG ULTRAGEAR 144HZ
Case AIGO DARK FLASH
Audio Device(s) MOTHERBOARD AUDIO
Power Supply XPG ADATA PYLON 650W
Mouse REDRAGON COBRA M711 V2
Software WINDOWS 11
You said randomly, so what does it do on the vga led? Ie, does it ever boot?
What are you doing to resolve it?
What were you doing before it happens?
when it gets stuck in the vga light it just stays there , have to reset the system then it posts
it doesn´t post and just gets a black screen
i´ve been using this keyboard , mouse , dongle , cpu and ram for a long time and it always worked
it is hard to tell since when the pc boots , everything is fine , no instability
112 (0.25/day)
System Name Home workhorse-gaming
Processor Intel 13600KF @ 5400/4300
Motherboard Asus ROG Strix Z790A Gaming WiFi
Cooling Arctic Freezer 2 rev.7 360mm
Memory 2x16 Kingston Fury Renegade Silver RGB DDR6400@XMP settings - 32-39-39-80
Video Card(s) Palit GamePro 3080Ti with Alphacool Eiswolf 2 360 mm
Storage NVME, WD 550 Blue 1 TB (gen.3), Samsung 980 1 TB (gen.3), Kingston KC3000 2 TB (gen.4)
Display(s) Samsung Odyssey G5 LS27AG500NUXEN (IPS, flat), @120Hz, 10 bit color (165Hz@8 bit)
Case Corsair 5000D Airflow, 4xArctic Bionix P120
Audio Device(s) Creative Sound BlasterX AE5 Plus, Creative P580 speakers, Sennheiser HD569
Power Supply Seasonic Focus GX 850W Gold
Mouse Razer Basilisk V3 Chroma
Keyboard Asus TUF Gaming K3
VR HMD none
Software W11 pro
Benchmark Scores https://hwbot.org/xtu2/analyze/5404795?recalculate=true
"i´ve been using this keyboard , mouse , dongle , cpu and ram for a long time and it always worked"
Irrelevant, could just take the plunge and sing the song because whatever.
ir_cow
4,712 (0.79/day)
USA
So this is from a off state? Not restarting or sleep?
302 (0.64/day)
System Name SYSTEM
Software WINDOWS 11
i highly doubt it is the cpu and ram , the only thing that is left
yes , but that would point to a PSU problem which i recently swapped as well ( got a core reactor 650w)
my bios is set to supply power to usb ports when the pc is off , could it cause some glitch to the dongles and post maybe?
ir_cow
4,712 (0.79/day)
USA
Well it only happens once in a while and restarting make its work again. You says everything is stable once it boots. Id say ignore it and move on.
All the times I've had that VGA light it's either because I forgot to plug something in, or the motherboard was upset at the video card.
For example, I had a RX 5800XT that did the same thing. Turned out when I finally checked GPUz, it was only running in 8x. 16x when enforced would always fail to boot.
I've had dead GPUs with the light on, but that was easy solve.
112 (0.25/day)
VR HMD none
Software W11 pro
And you know that because? Highly doubt what? Unless you have some spares it doesn't matter.
Again, it's the PSU or worst case the CPU.
302 (0.64/day)
System Name SYSTEM
Software WINDOWS 11
i just think it doesn´t make sense , the motherboard light would be stuck at cpu , dram if it were the issue
5,286 (3.73/day)
Colorado, U.S.A.
Software Windows 11 Home
Latest BIOS?
302 (0.64/day)
System Name SYSTEM
Software WINDOWS 11
Latest BIOS?
yes
i don´t mean to sound rude but it is just unbelievable the same problem in 2 different psus , mobos and gpus
the only thing left is cpu , ram
can my case cause it ? note that it always get power when pressing the button but sometimes get stuck at vga light
729 (1.14/day)
Processor Ryzen 5700x
Motherboard Gigabyte Auros Elite AX V2
Cooling Thermalright Peerless Assassin SE White
Memory TeamGroup T-Force Delta RGB 32GB 3600Mhz
Video Card(s) PowerColor Red Dragon Rx 6800
Storage Fanxiang S660 1TB, Fanxiang S500 Pro 1TB, BraveEagle 240GB SSD, 2TB Seagate HDD
Case Corsair 4000D White
Power Supply Corsair RM750x SHIFT
RX 5800XT
Some special GPU that 5800 XT lol do you mean 5700 XT?
yes
No there are other variables that have been mentioned to you in this thread multiple times that you keep ignorning, but please replace CPU and RAM throwing more money at a problem you want to go away, I'll sit and wait....
Pop Corn GIF by WWE
302 (0.64/day)
System Name SYSTEM
Software WINDOWS 11
Pop Corn GIF by WWE
i´m not ignoring ,i´ve just listed the major components
i will start with the usb bluetooth dongle
455 (0.50/day)
Some Where On Earth
System Name Spam
Processor i9-12900K PL1=125 TA=56 PL2=288
Motherboard MSI MAG B660M Mortar WiFi DDR4
Cooling Scythe Kaze Flex 120mm ARGB Fans x1 / Alphacool Eisbaer 360
Memory Mushkin Red Line DDR4 4000 16Gb x2 18-22-22-42 1T
Video Card(s) Sapphire Pulse RX 7900 XT
Storage Team Group MP33 512Mb / 1Tb
Display(s) SAMSUNG Odyssey G50A (LS27AG500PNXZA) (2560x1440)
Case Lan-Li A3
Audio Device(s) Real Tek on Board Audio
Power Supply EVGA SuperNOVA 850 GM
Mouse M910-K
Keyboard K636CLO
Software WIN 11 Pro
I wonder if you have a mother board standoff installed in the chassis that is causing your issue and shorting out something that is causing the POST issue. Or one of the tabs in the IO sheild is shorting to one of the connectors, like USB.
729 (1.14/day)
Doesn't matter, he's gonna buy a new CPU and RAM, should solve that issue :roll:
302 (0.64/day)
System Name SYSTEM
Software WINDOWS 11
sad to hear , just asked for help , i don´t know why i´m getting answers like this
also , is there the possibility of the USB hub from the case to cause this?
ir_cow
4,712 (0.79/day)
USA
We have you lots of suggestions. Nothing else we can do for ya. Try a few of the suggestions and report back
302 (0.64/day)
System Name SYSTEM
Software WINDOWS 11
I will test and report because the issue is so hard to reproduce
i think the issue lies at the vga maybe ( not a problem with the card ) but it could point the cables being bad
i have a very old 90 degrees adapter ( my dp cable wasn´t 90 at the time )
is there a good model of 90 degrees dp cable that i can get ?
so far removed the bluetooth dongle and booting times seemed a bit faster than before but too early to say
thanks
13,633 (2.01/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Debugs lights rarely lie.
I should have been more clear. I said above, "LED indicators only provide clues and they are not always right." I still say they only provide clues but I should have then said they don't always indicate the actual cause of the problem.
For example, while they may report a problem with the GPU, it could be power to the GPU is the problem. Or they may report a RAM problem, but it could be a bad socket. So again, they provide clues, but may not provide all the information needed to pinpoint the actual fault.
522 (0.13/day)
You sure it's not training? Even changes to power plans, power curves etc can trigger retraining.
23,146 (6.10/day)
As crazy as it would sound, detach that HDD and see what's happening without it. Been there, done that, no joking.
This is definitely worth checking.
I've had failed Post from a bad SATA cable too. Those flatcables aren't very sturdy. Just swapping a different SATA cable to feed your OS disk drive with is an easy thing to check.
Start with minimum setup. Connect a mouse and keyboard by USB 2.0 slots in the top of the rear IO shield and nothing else.
Then replace/add one device at a time.
5,286 (3.73/day)
Colorado, U.S.A.
THIS^
will save you a lot of time and trouble
475 (2.78/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
Absolutely remove the bluetooth just to eliminate it as possibility.
Video card on a riser card or a riser cable?
ir_cow
4,712 (0.79/day)
USA
This is very true. VGA light doesn't mean bad GPU, just means it stopped on that step for whatever reason. That's what I mean by it doesn't lie. That is the stopping point on the boot sequence.
23,146 (6.10/day)
Isn't it going to try to boot after VGA?
That would point to HDD
ir_cow
4,712 (0.79/day)
USA
It would got to BIOS if no HDD is detected. Or give you that message saying no boot drive. But the ops says it's just a black screen with the light.
