- Jul 25, 2006
- 13,899 (2.03/day)
- Nebraska, USA
System Name | Brightworks Systems BWS-6 E-IV |
Processor | Intel Core i5-6600 @ 3.9GHz |
Motherboard | Gigabyte GA-Z170-HD3 Rev 1.0 |
Cooling | Quality Fractal Design Define R4 case, 2 x FD 140mm fans, CM Hyper 212 EVO HSF |
Memory | 32GB (4 x 8GB) DDR4 3000 Corsair Vengeance |
Video Card(s) | EVGA GEForce GTX 1050Ti 4Gb GDDR5 |
Storage | Samsung 850 Pro 256GB SSD, Samsung 860 Evo 500GB SSD |
Display(s) | Samsung S24E650BW LED x 2 |
Case | Fractal Design Define R4 |
Power Supply | EVGA Supernova 550W G2 Gold |
Mouse | Logitech M190 |
Keyboard | Microsoft Wireless Comfort 5050 |
Software | W10 Pro 64-bit |
Actually it is - when the only reason to do so is to make your product proprietary, forcing buyers of those products to buy only your proprietary replacement parts and upgrades from you, and at a higher cost.gezz switching two wires is sooooo bad
Yes, it may have only been 2 wires, but that's all it takes to make a product proprietary and noncompliant with industry standards. And to the point here, for 99.9% of the users out there, that was more than enough to stop them from buying [better!] 3rd party replacement (or upgrade) parts.
Yes, it was two wires from the PSU, but also the circuit traces leading to the motherboard's main power connector were switched too. What may seem simple to an enthusiast or certainly a technician was an unsurmountable obstacle to millions and millions of other buyers whose proprietary OEM PSU failed, or who wanted to upgrade their graphics solution.
Adapters are fine - as long as they are included and not something extra consumers are required to buy. Adapters are common during transitional periods and are typically included until "the new standard" is widely implemented. History has shown this repeatedly. Keyboards used to come with USB to PS/2 adapters until USB became the standard. VGA to DVI adapters were common, then DVI to HDMI. MOLEX power to SATA power. Drives used to come with bay adapters when drives started becoming smaller. Ect., ect.
And the fact an adapter was included clearly indicates they didn't ignore the standard. The point all along - thank you once again for proving my point.
So history totally agrees. Are there exceptions? Of course! But exceptions don't make the rule or make moot the entire point - in spite of your made up, bogus and totally inaccurate "golden rule of statistics".
we are done here.
That is good.
Maybe. If sales increase, I am not sure the increase will be due to the new standard - at least not to a significant degree. Who, at least at first, will be buying these more power hungry cards? I think mostly serious gamers and other enthusiasts wanting the latest and greatest to boost their graphics performance, right? And a larger PSU is commonly required anyway when upgrading graphics just for the greater power demands - not for a new standard. So yes, PSU sales my go up, but I think mostly just to support a more hungry card - something needed regardless the new standard.The new standard will certainly sell more PSU's.
I guess we will have to wait and see on that one.
