Intel "Ice Lake" IPC Best-Case a Massive 40% Uplift Over "Skylake," 18% on Average
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 15.3.1
I need to see it to believe it. Let me guess; This is before all of the security vulnerability mitigations compared to a CPU with them enabled? :laugh:
3,950 (0.61/day)
Police/Nanny State of America
Processor OCed 5800X3D
Motherboard Asucks C6H
Cooling Air
Memory 32GB
Video Card(s) OCed 6800XT
Storage NVMees
Case Freebie glass idk
Audio Device(s) Sennheiser
So fake that CNN and Fox should be reporting it.
Nkd
364 (0.06/day)
Not reply to above:
Remember when ryzen scored crazy in cpu-z ?... yeah, was a bug in the benchmark :)
I think Ice lake should be Highly competetive in laptops but it's ipc should be marginally better than zen 2.
Reply to above:
7NM doesn't really help Intel with what they're struggling with, Performance.
It should be worse in fact...
This. It’s laughable when tech news sites forget that. Actually some people have already called this unrealistic. Otherwise intel would have been bragging left and right about it lol. Like they have been about everything.
3,986 (1.33/day)
Case Thermaltake Core P5
Keyboard Corsair K100 RGB
VR HMD HTC Vive Cosmos
So, what you are saying is that SPEC 2016, SPEC 2017, SYSmark 2014 SE, WebXPRT and Cinebench R15 are all bugged?
A big slide in their Computex presentation does not count as bragging?
For comparison, AMD had 2 numbers for Zen2 IPC increase for Computex - Cinebench (R20) 1T result was +13% and SPECint result that they eventually decided to use in the slide was +15%.
9,800 (3.24/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
But the benchmark used here isn't SPEC 2016, or 2017 or any of those. It's CPU-Z and it does not seem right to say the least, as I have said in another thread you can look at the changes in Sunny Cove, nothing there suggests 40% is possible, let alone achievable in real world scenarios. On the other had for Zen 2 13-15% seems at the very least possible and in accordance with what is known to have changed from Zen 1.
3,986 (1.33/day)
The chinese list is probably bullshit.
40% does come from Intel's slide. Apparently there is one (part of) benchmark that indeed does get 40%. Benchmarks run are listed underneath and there is a bunch of results averaged (well, geomeaned) to get that 18%.
Why exactly does Zen2 13-15% (based on 2 benchmarks) sound more possible than whatever Intel is claiming? Both are first party benchmarks more likely than not designed to show their own CPU in best possible light, both results come from benchmarks. AMD's results seem to be from a subset of the same benchmarks that Intel also ran.
9,800 (3.24/day)
Case Phanteks NV7
Then what's the point of even discussing this. He is right, if 40% IPC uplift was achievable in most scenarios it would have been plastered all over Intel's marketing material.
3,986 (1.33/day)
Because someone made a TPU news post out of this. Plus, the first half of the news post and first slide are based on information from Intel themselves.
4 (0.00/day)
Yeah, Intel's testing without security mitigations is shady.
On the other hand, these new cores definitely have fixes for Meltdown/L1TF in hardware and at least hardware-assisted mitigations for other Spectre-likes. And they are comparing these against Skylake which has none of that. When this is tested without security mitigations, Skylake should get a bigger boost than Ice Lake, making the uplift from new cores even bigger when taking security mitigations into account.
I don't know about that. On the other side 13-15% over 3 years is lauded as a great achievement.
Zen launched in 2017 so that makes it 2 years since then and AMD is comparing Zen2 to Zen+, not 1st gen Zen. The problem with Intel is that they are claiming 18% IPC improvement (which may be true), but they lost 1GHz in clock speed.
In an interview, people from AMD said that they were expecting a regression in clock speeds when moving to 7nm (because of high leakage and other problems associated with new node so small), but they managed to avoid this and actually gain a few 100MHz. From what we've seen so far, Intel has yet to fix their 10nm node and are having trouble scaling the clock speeds and core counts.
The 40% number is most likely from a workload that makes heavy use of AVX512.
4,933 (0.97/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
Some Intel CPU's will have lost more than 50% of their performance under some circumstances, so a poultry 18% (average) improvement on average is simply not enough.
I think you mean paltry, not
but I could be wrong...
Improving the size of poultry by 18% is no laughing matter, what has AMD ever done with domesticated fowl? Clearly AMD is trailing Intel in this department!
530 (0.11/day)
System Name As Himself
Processor 2700X
Motherboard Asrock 370X ThaiChi
Cooling Custom Liquid
Memory 4133MHz Team
Video Card(s) Radeon VII
Storage Samsung 512 SSD's
Display(s) Asus "24 144Hz
Case Tt P5
Audio Device(s) Asus Essence One Muses/Sparkos
Power Supply EVGA 1200
Mouse RAT ProX
Keyboard Drop CTRL
Software W10 steam futuremark
Why call it "per core performance" and not IPC???
That can NOT be a mistake!
3,092 (0.78/day)
Mouse Razer Abyssus
Software Ubuntu
I was fearing that this piece of "news" was going to be covered.
Now let's first check if it passes the smell test;
- The person making this have access to unreleased products from both AMD and Intel, including an early engineering sample of a 6 core Ice Lake, very unlikely.
- There is no CPU named "Sunny Cove", Sunny Cove is the core design, the first implementation is Ice Lake, so this is obviously wrong.
- Some of these clocks are fairly optimistic.
So most likely a fake.
And even if the benchmarks were accurate, >40% gain in a benchmark does not mean 40% higher "IPC". IPC should never be estimated based on a single workload, but a good selection of representative workloads. Even if Ice Lake truly yields 18% higher IPC, that doesn't mean every score will increase by 18% per clock, some may be only 5% while others are >40%, it all depends on which part of the CPU the benchmark stresses.
18% over four years is pretty terrible, especially if you consider how much performance was lost because of security mitigations.
~18% would be comparable to Sandy Bridge -> Skylake, which is no small achievement.
Performance loss from security mitigations are negligible for Skylake with later patches.
There have been rumors in the past that Intel will skip to 7nm for high end desktops. I hope it is true.
7nm in large volumes will probably not ship until late 2021 or 2022.
Xeons based on Ice Lake-SP(10nm+) will ship in Q2 2020. HEDT have traditionally been based on the server platforms, and considering HEDT is low volume compared to mainstream, Intel could choose to release HEDT based on 10nm+, but nothing is confirmed so far.
Intel does not need help with performance. Skylake (and all the minor modifications to it) are competitive if not faster than Zen.<snip>
What Intel needs help with is power efficiency that 10nm/7nm does bring to the table. Smaller dies may be helpful or harmful but we do not know that yet for sure.
Skylake have no problem with core speed vs. Zen 2. Zen 2's advantage will be energy efficiency and density allowing for more cores, which is where Intel will be limited by their 14nm node. Intel's 6- and 8-cores will consume more energy than their Zen 2 counterparts, but will have no issues competing in other regards. It's when you go past 8-10 cores that Intel will face problems, which means they will have no direct competitor to 12-/16-core "mainstream" parts.
Even if 10nm was less troubled, they would probably still struggle to achieve higher clock speeds. The long-term expectations is actually lower clock speeds for upcoming nodes, so future progress will depend on IPC gains.
My biggest complaint about Intel's situation is the lack of a proper backup plan. If they had only backported Synny Cove to 14nm, they would have had a good performance gain and lead for the next two years in the mainstream segment.
1,227 (0.48/day)
Processor AMD Ryzen 9 5950X
Case Cooler Master Cosmos
Power Supply Corsair HX850i
Keyboard Cherry MX
It's fine the way it is... Spade a spade, chicken a chicken and all that...
299 (0.12/day)
Of course the 40% will be in a very specific workload, just like the 29% more IPC that AMD reported for Zen 2 in a presentation a few months ago.
19,379 (3.46/day)
I have no idea, but your reading comprehension clearly needs to improve.
The first image is from an Intel presentation, using only synthetic benchmarks, whereas when AMD used them during their presentation at Computex, Intel went out and said that from now, we should only use real world benchmarks. Yet Intel clearly seems more than happy to use synthetic benchmarks when it suits them. As such, this is irrelevant even by Intel's "new" standards, no?
Didnt Intel simply challenge amd in real world benchmarks? Like a 'hey those are great but...how about real world benchmarks'? I didnt know they specifically mentioned to only use real world benchmarks and this was the (only) way forward.
.....actually... that was "real world gaming". Intel was responding to AMD's 'gaming CPUs' and challenged them on that front.
258 (0.09/day)
behind you
Processor Threadripper 1950X
Motherboard ASRock X399 Professional Gaming
Cooling IceGiant ProSiphon Elite
Memory 48GB DDR4 2934MHz
Video Card(s) MSI GTX 1080
Storage 4TB Crucial P3 Plus NVMe, 1TB Samsung 980 NVMe, 1TB Inland NVMe, 2TB Western Digital HDD
Display(s) 2x 4K60
Power Supply Cooler Master Silent Pro M (1000W)
Mouse Corsair Ironclaw Wireless
Keyboard Corsair K70 MK.2
VR HMD HTC Vive Pro
Software Windows 10, QubesOS
This may well be genuine. I've suspected for a while that Intel has known all along how to drastically increase their IPC but hasn't done so because once they weren't able to go smaller they'd need some way to improve new CPUs.
23,832 (6.15/day)
I'm sure there is an IPC boost in Ice Lake. Too bad it won't clock that well ey :) But 40%? Not in your baddest dreams, Intel.
9,800 (3.24/day)
Case Phanteks NV7
I am not sure that's the case , new revamped architectures usually have to coincide with new nodes. I doubt Sunny Cove was in the pipeline for a lot of time.
1,605 (0.63/day)
London, UK
Typical Intel, "Do not buy Ryzen, we have something better in few months".
19,379 (3.46/day)
Lol, what from 13 years ago when this last was the case? Intel didnt do this with zen or zen+ as there wasn't a need. Now that IPC is there AMD clockspeeds are up... they do.
4,933 (0.97/day)
Intel threw down the gauntlet and we are going to have an old fashion Sims 4 showdown! Two CPUs enter, one CPU leaves! Hopefully none of the CPUs bottleneck the GTX1050 used for the test....
1,086 (0.17/day)
Montreal
Mouse G700 / none / G602
Keyboard G910
Software w11 64
Can we agree the "benchmark" is clearly fudged?
18,450 (2.47/day)
That was one thing, but before that, Intel did this
480 (0.07/day)
USA
System Name Eric's Battlestation
Processor Core i7 6700k
Motherboard GIGABYTE G1 Gaming GA-Z170X-Gaming 7
Cooling Fractal Design Celsius S24
Memory Patriot Viper Steel Series DDR4 32GB 3200MHz
Video Card(s) MSI Mech 6750 XT
Storage Samsung 850 EVO 1TB, Crucial MX500 1TB, Intel 660p 2TB
Display(s) Gigabyte M27Q
Case Fractal Design Define R5
Power Supply EVGA G2-XR 80 Plus Gold 750W
Mouse Steelseries Rival 3
Keyboard Logitech G810
Software Microsoft Windows 10 Home
I'll believe it when I see it. I refuse to count chickens before they hatch...
19,379 (3.46/day)
