Intel "Ice Lake" IPC Best-Case a Massive 40% Uplift Over "Skylake," 18% on Average
258 (0.09/day)
behind you
Processor Threadripper 1950X
Motherboard ASRock X399 Professional Gaming
Cooling IceGiant ProSiphon Elite
Memory 48GB DDR4 2934MHz
Video Card(s) MSI GTX 1080
Storage 4TB Crucial P3 Plus NVMe, 1TB Samsung 980 NVMe, 1TB Inland NVMe, 2TB Western Digital HDD
Display(s) 2x 4K60
Power Supply Cooler Master Silent Pro M (1000W)
Mouse Corsair Ironclaw Wireless
Keyboard Corsair K70 MK.2
VR HMD HTC Vive Pro
Software Windows 10, QubesOS
I am not sure that's the case , new revamped architectures usually have to coincide with new nodes.
No they don't. Intel's tick-tock scheme alternated between new architecture and new process.
23,682 (6.14/day)
That was one thing, but before that, Intel did this
Seriously if you analyze what they say and dissect it...
- We will give you "filter bubble" performance. If you use lots of Chrome, you get superb Chrome performance. In other words, the less common tasks are the ones they won't optimize much for? Or at least at the expense of the higher percentages? That is a painful departure from having the optimal CPU for every use case... wait... that is probably why I've bought Intel CPUs for performance rigs the past decade. Righto!
- What have they been doing stuffing IGPs in CPUs and taking up valuable real estate on the die for a piece that especially power users will NEVER look at? Hmmmmm. As far as I can tell, all we got was the same slab of silicon in twenty flavours every odd year. And it just so happened to do all the things better than the competition.
- Is the new Intel optimization process a trial and error run now? Some hardware mitigation here, some Chrome optimization there, oh people do streaming let's use the solid hardware we already had for years... what else? Higher clocks so they can surpass their own TDP rating within two seconds of load? Ooh shit this node doesn't work right, let's skip it after all. Oh no, wait, we'll do some 10nm anyway. Maybe. Someday.
Utterly
pathetic.
Get back in your corner, we don't want to play with you anymore. Oh and another thing, I use Firefox.
125210
9,788 (3.25/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
A monolithic 16 core from AMD would fall in the 250 mm^2 region on 7nm. An Intel equivalent would need 400+ on 14nm, they needed 10nm to make competitive products. Tick-tock worked up until now because they always had the leading node, now they don't.
Developing an architecture without a new node isn't ideal.
258 (0.09/day)
behind you
Display(s) 2x 4K60
VR HMD HTC Vive Pro
You're talking about frequency and number of cores not the IPC of each. IPC increases don't usually require huge increases in die size (though cache increases can), hyper-threading only increased the Pentium 4's die by 5%.
Obviously it'd be nice if each new architecture had a new node to go with it, but it's hardly necessary.
17,777 (4.65/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710
Intel has other plans. At least thats what it told its investors this year.
Intel will be using Arizona and Ireland for 7nm. Expansion at those fabs is expected to be completed late 2021 for Arizona, Ireland est sometime in 2022.
looks like I am rolling 12 core 3900x until 2022/2023 then.
I have no idea, but your reading comprehension clearly needs to improve.
The first image is from an Intel presentation, using only synthetic benchmarks, whereas when AMD used them during their presentation at Computex, Intel went out and said that from now, we should only use real world benchmarks. Yet Intel clearly seems more than happy to use synthetic benchmarks when it suits them. As such, this is irrelevant even by Intel's "new" standards, no?
AMD uses synthetic too, this is just part of the industry... don't forget Navi unviel, they only showed Strange Brigade and nothing else... sad... this is just part of business marketing... get over it?
362 (0.10/day)
I need to see it to believe it. Let me guess; This is before all of the security vulnerability mitigations compared to a CPU with them enabled? :laugh:
Apparently we're supposed to believe that all of the vulnerabilities and regressions from mitigations will be fixed. I'll believe it when I see it.
The reasoning goes that Intel has plenty of time to fix the plethora of vulnerabilities and rectify the regressions. At the pace new Intel-only vulnerabilities have been popping up I don't think it's that outlandish to expect new ones in relatively short order either.
One might quip that Intel's best hope is to find devastating vulnerabilities in AMD's CPUs, along the lines of having to completely disable hyperthreading. :rolleyes:
It's a bit mind-boggling that so many seem to so blithely accept such massive defects in Intel's CPUs. The mentality is "just go and buy another one", as if there is unlimited money. Planned obsolescence at its most inglorious?
18,350 (2.46/day)
I never said they didn't, my point was that Intel now says we should only use real world benchmarks. How do you benchmark steam or VLC?
4,501 (1.39/day)
Currently Norway
System Name Bro2
Processor Ryzen 5800X
Cooling Corsair h115i pro rgb
Case Fractal Design G
Audio Device(s) Realtec 5.1
Mouse Logitech G402
Keyboard Logitech slim
Software Windows 10 64 bit
I'd bet Intel would come up with an idea of how to do it and of course Intel's CPUs would be the fastest.
3,973 (1.33/day)
Case Thermaltake Core P5
Keyboard Corsair K100 RGB
VR HMD HTC Vive Cosmos
Considering 8-core die in 9900K is 175mm^2 with iGPU, Intel could do a 16-core at around 350mm^2 and probably less than that.
I am willing to bet AMD can do a monolithic 16 core at around 200mm^2 on 7nm. 8-core chiplets are 75-80mm^2 and 12/14nm IO Die is 120mm^2. There are a lot of extra things in IO Die that are not strictly required.
We will probably get a good idea about what AMD can do with 7nm in terms of cores and die size when APUs come out. Intel is still betting on 4-core mobile CPUs (which is probably not a bad idea) and AMDs current response is 12nm Zen+ APUs but 7nm APUs should replace these within a years time.
9,788 (3.25/day)
Case Phanteks NV7
Not with Sunny Cove and whatever next generation integrated graphics they made.
3,973 (1.33/day)
Integrated graphics wouldn't play much of a part in 16-core CPU. 64 EU or even 48 EU iGPUs would not make much sense. A minimal 8 EU or lack of iGPU would be OK.
You are right about Sunny Cove though, doubled caches will increase the size notably.
2,650 (0.80/day)
I have to wonder if AMD might integrate a dual/quad core CPU/APU into the I/O Die with a node shrink and split in half some of the I/O die logic that it can serve and use more than one I/O die. That could be a good way of getting around some of the issues surrounding system interrupts under heavy stress loads. If one I/O die is heavily loaded it wouldn't bog down the the other. So if one I/O die with some storage devices/USB devices is heavily strained the I/O die could be functioning at top speed and load balance the overall system more effectively. I'm just speculating on a possibility of a direction it might move toward with a bit more revision.
I tend to think at 5nm we'll see a pair CPU core/thread die's and pair of I/O die's with about half the logic split between the two which will bring down the temperatures of them a bit. The chipset could be a multi chip solution as well might as well if made sense for the CPU probably does for the chipset as well.
47 (0.02/day)
AMD doubled the vector floating-point muscle of the upcoming generation of Ryzen chips. To me, that's the biggest news about them, and likely the main reason they can be considered to have caught up with Intel.
But Intel was about to double theirs as well, putting AMD back where it was. Although they have some 10nm parts in volume production, the desktop chips that were going to bring AVX-512 support to the mainstream aren't here yet.
So, while Intel and AMD have made comparable IPC improvements, it seems to me that AMD has not done everything it should have done to obtain a solid lead over Intel, and their current lead is simply a result of Intel having some unexpected further delays with its 10nm lineup. So, while I still feel pretty excited over the new Ryzens, I take a somewhat cautious view.
98 (0.02/day)
This feels like Intel releasing some BS numbers about a product on a process Intel can't do right before Ryzen comes out just to try to get people not to switch teams.
2,650 (0.80/day)
Real world I don't always single task, I tend to care about safety and security, windows updates when it chooses, steam downloads in the background, people download in the background, people install stuff in the background, and in the only time I play games in 1080p is never or when the game runs as badly as RTX and I want to prematurely ||||||||||||| over how much better old graphics could have looked with better hardware or with wooden screws added.
3,152 (0.91/day)
Argentina
System Name Ciel / Akane
Keyboard VSG Alnilam / Dell
If this is true, why didn't Intel do it sooner? 10nm is not an IPC changer, their design is.
We were recieving 5% IPC increases or even less for 10 years and suddenly, boom, 18%, just when AMD seems to get the lead.
3,077 (0.78/day)
Mouse Razer Abyssus
Software Ubuntu
We know why; Ice Lake has been ready for nearly two years, just waiting for a suitable node.
AMD has nothing to do with it.
324 (0.14/day)
Intel will put big effort in the HPC GPU area since for each Xeon they can sell more then 4 HPC GPUs that cost upto $20K each, it's a big money.
3,381 (1.14/day)
North East Ohio, USA
System Name My Ryzen 7 7700X Super Computer
Processor AMD Ryzen 7 7700X
Cooling DeepCool AK620 with Arctic Silver 5
Memory 2x16GB G.Skill Trident Z5 NEO DDR5 EXPO (CL30)
Video Card(s) XFX AMD Radeon RX 7900 GRE
Storage Samsung 980 EVO 1 TB NVMe SSD (System Drive), Samsung 970 EVO 500 GB NVMe SSD (Game Drive)
Display(s) Acer Nitro XV272U (DisplayPort) and Acer Nitro XV270U (DisplayPort)
Case Lian Li LANCOOL II MESH C
Audio Device(s) On-Board Sound / Sony WH-XB910N Bluetooth Headphones
Power Supply MSI A850GF
Mouse Logitech M705
Keyboard Steelseries
Benchmark Scores https://valid.x86.fr/liwjs3
The question of course is... Are there any applications in play that use AVX-512 extensions outside of custom scientific applications?
I've done some research into this and it seems that most programs in use by regular people (programs like Firefox, Google Chrome, 7-ZIP, Photoshop, etc.) are using AVX2 (that's AVX-256) which is what is now supported by Zen 2 or Ryzen 3000. AVX-512 may be the newest kind of AVX instructions but it seems that it's still only used in limited and very custom workloads, not in general use.
And besides, for most Intel chips in use today whenever they start executing AVX-256 bit instructions they tend to clock down via the AVX-offset generally because to execute AVX instructions it requires more power thus more heat and thus they can't run at their regular clock speed. AMD's new Zen 2 architecture appears (or at least what AMD has said) doesn't require some kind of AVX-offset while executing AVX-256 bit instructions which the way I see it is that the new Ryzen 3000 series of chips won't downclock while executing AVX-256 bit instructions as their Intel counterparts do thus we'll see better performance from AMD chips than Intel chips while performing AVX-256 bit workloads.
3,077 (0.78/day)
Mouse Razer Abyssus
Software Ubuntu
Yes, so far.
But you got to start somewhere, hardware support usually have to come first.
9,788 (3.25/day)
Case Phanteks NV7
Nope. Whats worse is that AVX 512 workloads don't scale as well as AVX1/2 which in turn scaled worse than SSE. Increasing AVX2 throughput is more useful as far as I am concerned.
350 (0.08/day)
What about this benchmark? https://www.notebookcheck.net/Intel...s-new-Picasso-Ryzen-7-3750H-APU.424636.0.html
This is Passmark. Single thread score at ~4.8 Ghz (short test, might actually run at 4.8Ghz) of 8665U is 2400 points. 1065G7 gets 2625 points, at 3.9 Ghz. If we get the 1065G7 to 4.8 Ghz, we get 3200 points. That would translate into 34% higher IPC. Any thoughts? I was also skeptical about the 40% mentioned in this stupid forum picture, but passmark looks a bit more legit to me.
3,973 (1.33/day)
Early hardware and incorrectly reported clock speeds? Intel implementing something new in terms of frequency boost that goes beyond specced boost clock?
That is a 35% difference, sounds very unrealistic.
