Is X570 Chipset overheating a possible cause of NVMe's dropping from the system?
3,383 (1.68/day)
Power Supply Corsair RM750x
Mouse Logitech M575
Any thoughts on using PTM7950 as a replacement for the X570 chipset thermal pad considering the chipset typically operates above 45c anyway?
INSTG8R
Vanguard Beta Tester
8,098 (1.10/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
I mean it probably wouldn’t hurt but I mean I’ve had both X570 and X570S and well i just accept it runs “Hot” But hey if it helps a few degrees a gain is a gain
3,383 (1.68/day)
Mouse Logitech M575
I'll have to consider thickness too. An interesting find of a different solution (
INSTG8R
8,098 (1.10/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
Good find tho interesting that it’s for your particular board but hey you got all the info you could ask for in whatever you decide.
I mean I just tried looking mine up and it was mostly standard reviews tho it was on a few ”best” vids
7,607 (1.47/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
3,383 (1.68/day)
Mouse Logitech M575
I've put mine under water block :D
Ok you can't say that and not provide a picture. :shadedshu:
I had a chance to get a waterblock from ebay when I scooped up a Taichi Razor Edition but I passed on the block since in all cases prevented me from running a full length GPU.
INSTG8R
8,098 (1.10/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
7,607 (1.47/day)
Rīga, Latvia
Software FEDORA 41
I've ordered this one aliexpress, took off the bracket and drilled holes so it fits my board. As bonus, it cools also my bottom SSD too
3,383 (1.68/day)
Mouse Logitech M575
7,607 (1.47/day)
Rīga, Latvia
Software FEDORA 41
9,692 (3.46/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
I actually used a Noctua 40mm fan on my Chipset heatsink. I also had the board fully populated though so it was always working to maintain things like RAID arrays.
834 (0.24/day)
System Name Harm's Rig's
Processor 5950X /2700x / AMD 8370e 4500
Motherboard ASUS DARK HERO / ASRock B550 Phantom Gaming 4
Cooling Arctic Liquid Freezer III 420 Push/Pull -6 Noctua NF-A14 i and 6 Noctua NF-A14 i Meshify 2 XL
Memory CORSAIR Vengeance RGB RT 32GB (4x16GB) DDR4 4266cl16 - Patriot Viper Steel DDR4 16GB (4x 8GB)
Video Card(s) ZOTAC AMP EXTREME AIRO 4090 / 1080 Ti /290X CFX
Storage SAMSUNG 980 PRO SSD 1TB/ WD DARK 770 2TB , Sabrent NVMe 512GB / 1 SSD 250GB / 1 HHD 3 TB
Display(s) Thermal Grizzly WireView / TCL 646 55 TV / 50 Xfinity Hisense A6 XUMO TV
Case Meshify 2 XL- TT 37 VIEW 200MM'S-ARTIC P14MAX
Audio Device(s) Sharp Aquos
Power Supply Seasonic Prime TX-1600 ATX | Fully FSP Hydro PTM PRO 1200W ATX 3.0 PCI-E GEN-5 80 Plus Platinum -
Mouse G502
Keyboard G413
Air over the chipset makes a difference ,and no obstruction , which I learn real fast , when installing vertical GPU mount, riser cable was the reason for me , was up against the MB , moved riser cable away from MB heatsink , went from 60c down to normal 40c as before the vertical mount riser cable , VRM never had a problem 40c .
INSTG8R
8,098 (1.10/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
I can’t believe it’s a situation where the GPU was STILL the problem. The main issue is design. Your GPU basically blocks airflow to the fan. There’s only a couple MoBos where the fan is positioned unobstructed.
Now I mean I have no fan but i maintain reasonable temps actually more reasonable than my X5670 with a fan.
834 (0.24/day)
Mouse G502
Keyboard G413
I tested with and without riser flat thick cable against the MB , Asus Dark Hero X570 is passive cool ,no fans , riser acted like a blanket on top of the heatsink ,reposition the blanket away , air runs over heatsink , air is moving in and out of this case at a good clip , 10 Noctua a14 3000rpm fans with intake filters , plus two more at the end of the day.
also my Cooler Master vertical mount is adjustable with this Mystify XL .
INSTG8R
8,098 (1.10/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
LOL I Run 2K Noctua Industrials I have 3Ks as well but when I switched from my hot and loud 6950XT to my 7900XTX the thermals were much better so I went back to 2Ks
834 (0.24/day)
Mouse G502
Keyboard G413
I just run ASUS fan software , the only times I hear the fans ,when using PassMark , day to day ,and gaming, my 4090 is the loudest thing in the case LOL .
INSTG8R
8,098 (1.10/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
I have all my set in my BIOS they only spin up when gaming or they’re pretty silent at 900rpm idle. My 3 Magflows on my rad are the “loudest” at a static 1500rpm. I have always been thermals>noise. I game in 5.1. Even when wound up it’s not even a distraction.
43,407 (6.76/day)
700 (1.76/day)
Seattle
System Name DevKit
Processor AMD Ryzen 5 3600 ↗4.0GHz
Motherboard Asus TUF Gaming X570-Plus WiFi
Cooling Koolance CPU-300-H06, Koolance GPU-180-L06, SC800 Pump
Memory 4x16GB Ballistix 3200MT/s ↗3800
Video Card(s) PowerColor RX 580 Red Devil 8GB ↗1380MHz ↘1105mV, PowerColor RX 7900 XT Hellhound 20GB
Storage 240GB Corsair MP510, 120GB KingDian S280
Display(s) Nixeus VUE-24 (1080p144)
Case Koolance PC2-601BLW + Koolance EHX1020CUV Radiator Kit
Audio Device(s) Oculus CV-1
Power Supply Antec Earthwatts EA-750 Semi-Modular
Mouse Easterntimes Tech X-08, Zelotes C-12
Keyboard Logitech 106-key, Romoral 15-Key Macro, Royal Kludge RK84
VR HMD Oculus CV-1
Software Windows 10 Pro Workstation, VMware Workstation 16 Pro, MS SQL Server 2016, Fan Control v120, Blender
Benchmark Scores Cinebench R15: 1590cb Cinebench R20: 3530cb (7.83x451cb) CPU-Z 17.01.64: 481.2/3896.8 VRMark: 8009
It's a really dumb issue to outline but I think this does a fairly good job of it.
I won't be able to water cool the X570 chipset without rearranging SFP to top slot and GPU to 2nd slot all because this obstruction is so pervasive on 500 generation.
The guy that decided on this was like a cat. Perch that thing right in the middle of all the traffic to obstruct everything.
It will take some fitting but a low profile copper block similar to the kind I use on my chillers MIGHT work but it's not really designed for motherboards.
We need something with sealed side path fittings that run parallel to the board.
834 (0.24/day)
Mouse G502
Keyboard G413
Just moving Riser half a inch from heatsink , about 10C lower , back to normal 40C .
freeagent
9,557 (4.10/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Yup.. just gotta blow on it a little..
INSTG8R
8,098 (1.10/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
834 (0.24/day)
Mouse G502
Keyboard G413
GPU at max ,450w , temps best I ever seen on my system, room temp 72f. 12 Noctua a14 3000 .
freeagent
9,557 (4.10/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
12 Noctua a14 3000
Dude.. I just put 2 in my case, and a TY-143.. I went from a slumbery consumer system to a psycho box..
I had to put my 5900X back in just to cap it off :D
7,607 (1.47/day)
Rīga, Latvia
Software FEDORA 41
Before going full nuclear, I even consulted internally ASUS, the main point of my upgrade was that little whiny bitch of a fan, after a year it got irritating, basically you cannot get a new one, you RMA your board you get a RMAed refurbished shit board with a random fault and same other old whiny fan. As a hot blooded, corporate hating chap, I said no thank you.
So before that I considered doing another stunt laptop users do, putting additional heatpipes. So thermal epoxy and a pipe to somewhere, like in the old days, when motherboards had real cooling across the board, not RGB bling. Pipes went across the board and cost like a hundred... ffs, now you have to fix the board even coming out of the box... reminds me of soviet culture.
