Lowering idle power on Zen 4?
14 (0.01/day)
RPL was a dead end and it pulls a ton of power while ARL is too expensive, so zen was my only choice either way. I honestly didnt even know that new zen pulled 30W for fun. thats like, a pretty big deal for everyone without A/C since that means cooking yourself alive in the summer.
Oh, and I also didnt know they dont target a frequency but rather a temp (is there any way to change this by the way? 50°C while on the desktop is kinda bad).
it's my mistake in the end, but reddit can be an hell of a braindead echo chamber.
The power is one thing but why do you care what the temp is?
JakoDel
13 (0.02/day)
what I meant is. I dont care about the temperature itself but since the cpu scales with temp and it has 50°C as a target while idling, it pulls 15w extra to keep the CPU at 4GHz for no reason at all, without anyone interacting with the PC for an hour. the snapdragon 801 in my 2014 smartphone has a smarter behaviour
14 (0.01/day)
That doesn't seem right, my 7700X idles at around 50C-60C on a hotter day and the clocks reduce to tens or low hundreds of MHz as you would expect.
freeagent
10,035 (4.24/day)
Winnipeg, Canada
Processor AMD R9 9900X
Cooling Thermalright Aqua Elite 360 V3, 6x TL-B12 V2
Memory 2x16GB Lexar Ares @ 6000 30-36-36-68 1.35v
Storage WD SN850 1TB, SN850X 2TB, 3x SN770 1TB
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
SOC voltage will play a strong role in your idle temps.
3,892 (1.93/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 85C temp limit, CO -8~14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.3037), upgraded from Win10 to Win11 on Jan 2024
Ryzens are known to be boost jumpy on small loads and win power plan can be complimentary on this. Also depends on the services on the background.
Win 11 have 2 different settings on power plan.
I use balanced at 1 and low power at 2.
So cores are idling at 3.3GHz before entering the suspended mode. Long term while I use PC for the simplest stuff, like browsing and watching vids the avg core (discrete) clocks are 3.4-3.5GHz.
Power hovers around 40-50W usually and temp in the high 30s - low 40s. Ambient 23C.
The 420mm AIO helps but still fan speed stays (avg) 300-350rpm with above conditions. Pump also reduces speed under 50%.
2,138 (0.80/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Storage six M.2 pcie gen 4
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 pro x64
@freeagent
but almost non, vs limiting max clock for idle/low load use.
as i will never see ~50w less, just by lowering soc, even at stock clocks.
@JakoDel
as said before, adjust the power savings plan (disable usb/pcie savings) to 0% for min and 50% for max cpu clock, and when there is need for power, switch to balanced (99% min, 100% max cpu).
you can find guides online to make shortcuts for each, and switch between them easily.
117 (0.09/day)
System Name Nirn
Processor Amd Ryzen 7950X3D
Motherboard MSI MEG ACE X670e
Memory 128 GB Kingston DDR5 6000 (running at 4000)
Video Card(s) Radeon RX 7900XTX (24G) + Geforce 4070ti (12G) Physx
Storage SAMSUNG 990 EVO SSD 2TB Gen 5 x2 (OS)+SAMSUNG 980 SSD 1TB PCle 3.0x4 (Primocache) +2X 22TB WD Gold
Display(s) Samsung UN55NU8000 (Freesync)
Case Corsair Graphite Series 780T White
Audio Device(s) Creative Soundblaster AE-7 + Sennheiser GSP600
Power Supply Seasonic PRIME TX-1000 Titanium
Mouse Razer Mamba Elite Wired
Keyboard Razer BlackWidow Chroma v1
VR HMD Oculus Quest 2
Most of the day is idle or most of the day is running?
My CPU idles around 45W
PC is running about 14-16h per day avg.
But only half of that time is idling. Maybe even less...
Lets say 8 hours. Compared to a CPU that is idling at 10W its 35W more
35W/h = 0.035 KW/h X 8 h = 0.28 KW/h
The cost of my KW/h including vat, taxes and everything is about 0.22€
0.28 KW/h x 365 days = 102.2 KW/h
102.2 KW/h x 0.22€ = 22.5€
+22.5€ per year on my bill for the excessive amount of +35W
oh boy...
where are you that they are charging .22 a kh/h. its like .15 usd here in the states.
3,892 (1.93/day)
Since I wrote €, I am half the planet across.
EU, Greece
And I believe that in some states of US its even more expensive than here. And on other places of Europe too.
~5years ago the price was less than 0.1€ and after what started in Europe everything has gone up. Power, gas, diesel, NG, food...
5,617 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
Because your country still produces a lot of dirty power ie: Wood/coal/gas fired power stations along with some Nuclear power stations aswell in other countries where they lack that and relied upon Gas that used to come cheaply from Russia which isn't now costs of production have gone up. In my own country NZ I get stung $0.25KW/h excluding GST (sales Tax) which will add another 15% to that and ours is mostly Hydro and Geothermal with a tiny bit of wind generation and the odd bit of Coal/Gas when needed
117 (0.09/day)
System Name Nirn
man that must suck. i dont think i would want clean energy if it made my bill go up by almost double.
  • Like
Reactions: AMF
freeagent
10,035 (4.24/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
You are talking about this power?
2,138 (0.80/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
@cal5582
cost is more related to provider, not source. you can find "green" power for similar cost (when i looked at prices in germany few month ago).
@freeagent
whats that, ryzen sw?
fucked up my fan profiles once, when i played around with tweaks, havent used it since.
i used OCCT, for cpu power package/ppt, as i wanted to show that difference between unrestricted cpu clocks + lower bus clocks (jedec ram),
vs what you can get from limiting max clock with power plan, while still running higher bus clock.
and you can still do any soc (vol) tweaking besides my tip.
freeagent
10,035 (4.24/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
No sir, I avoid that like the plague.
That is just HWiNFO64.
I use my bios for everything, including my fans.
AMF
712 (0.50/day)
USA
System Name MR T System price $2464
Processor Ryzen 9 3900x 325$ 4.725Ghz boost pbo +50+75 enhance .1875.-+offset auto voltage -.2500 offset soc
Motherboard ROG STRIX X570-E Gaming $ 125 open box
Cooling 280mm ARCTIC FREEZER II idle temps 25c cpu 28c cpu diode 20c vrm 25c motherboard b stock 60$
Memory 2x 16GB Dual rank G Skill Trident Z Neo F4-3600C16-16GTZNC @3800 1.405v 16-19-16-19-35-54-1T $96
Video Card(s) Asrock RX 6950XT Oc formula 705$ pcie4x16 2599 min 2699mhz 2799boost 1110v 2392mhz mem 19GB/s
Storage 500 GB WD SN850 PCI-E 4.0x4 85$ pcie 4.0x4
Display(s) Vizio M50QXM-K01 4k@120hz 2.5k 120hz 2k@240hz $448
Case Cougar Panzer Max G Full Tower Tempered Glass 150$
Audio Device(s) Vzio M51a 5.1 Soundbar Dolby Atmos goodwill 45$!!!!
Power Supply Seasonic SS-1250XM2 Bought in 2013 350$ 11 y/o hasnt lost any voltage or watts
Mouse Perixx eRGO wireless Trackball 25$ 2000dpi
Keyboard Corsair K57 50$
VR HMD Dont give a damn about vr
Software win 11 pro modded by me no ai no remote connections free hehe
Benchmark Scores 8188 multi 540 single cinebench r20
dude run your pump at max all times watch temps drop raise fan minimum to around 600 or so cores should come up a bit
3,892 (1.93/day)
No thanks
After 2 hours of simple usage the CPU temp average is around 36~40C with ~300rpm average on the fans (1600rpm max) and pump to 1200~1250rpm average (2000rpm max).
My mistake stating that pump drops below 50%. Its actually 60%.
At those CPU temps the LF II 420 PWM controller drops to 10~12% as my curve dictates
Its a single PWM controller that controls both fans and pump simultaneously.
The pump will max rpm at 60C CPU temp and fans will max out at 72C CPU temp.
Works great, with low noise and minimum wear and dust accumulation.
  • Like
Reactions: AMF
3,041 (2.03/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
i don't understand why most people here want to lower either core clocks or VCore or do some magic with cooling, delidding or whatever.
almost all of your idle powerdraw comes for the I/O Die. on Zen 3 it pulled around 28W and on Zen 4/5 it pulls around 22W.
lower the SoC Voltage to ~1.1V and it should drop by 4-5W. that's all you can do. There is no other trick or tweak.
3,892 (1.93/day)
Under 20W (17~19W) mostly on my dual CCD 5900X, all speeds at 1:1:1, 1800MHz (3600MT/s)
VSoC at 1.09V
IF power can another 10-15W and that is "invisible" but reflected on total CPU power (PPT).
14 (0.01/day)
Gonna necro this thread a bit to mention that finally messing with curve optimiser has given me some substantial idle power improvements (around 17-21W now). I didn't realise it before but of course a negative CO offset can reduce idle power, as it globally reduces the voltage used for each frequency step along the V-F curve which includes low clock states. At -60 (the maximum CO offset allowed on my B650E-F) I was able to achieve stability by limiting the max boost clock to 5325MHz, since the highest frequency states are of course the least stable/have the least OC/UV headroom (this is where so-called "idle instability" with CO on Ryzen comes from -- clock speed spikes).
A nice bonus is that my heavy MT gaming perf (PT Cyberpunk specifically) improved by 5% when compared to default AMD cTDP 65W profile (88W PPT) while only using around 50-60W.
14,996 (6.67/day)
Midlands, UK
Cooling be quiet! Dark Rock 4
Case Kolink Citadel Mesh
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
I get that idle power with 4800 MHz RAM and no CO. What you do with the cores doesn't matter in idle. Your SOC voltage (which is affected by RAM speed and IF clock) does.
Not using those watts on your SOC gives your cores more breathing room, hence the higher performance. That's one reason why I keep saying, RAM tuning is overrated.
4,626 (2.67/day)
System Name Mean machine
Processor AMD 6900HS
Memory 2x16 GB 4800C40
The cores don't change idle power much, actually zen 3 to zen 5 cores drop to a very low state in idle, they barely draw any power. It's the SOC that's the main issue. In mobile zen chips that are monolithic idle power drops to 2-3w, same level as any intel chip.
14 (0.01/day)
