Need Help Finding: Coinmine RX 580 2048sp (8gb) stockbios
42 (0.05/day)
So I bought this card third party from a seller on eBay linked here: https://www.ebay.com/itm/124787137308#cvip_desc
Gpu Description found here (it says RX 580 but if you scroll to the bottom it says 2048sp): https://www.techpowerup.com/vgabios/226299/226299
And in the description for the GPU it says
However recently I've been getting "code 43" every morning and GPU-z doesn't work immediately. After further research, this has to do with the fact that it's a mining card with custom bios, hence my need to put it back into stock bios.
But after further speculation when I look at the GPU specs it says it's actually a Polaris GPU(located here): https://www.techpowerup.com/gpu-specs/radeon-rx-580-2048sp.c3321
However, CoinMine must've modded it because it has 8 GB of memory rather than the expected 4GB. And I can't find the bios for the Polaris, Please help me I'm in desperate need if there is any other information necessary please ask, I've been dealing with this problem for about a year and I don't want to deal with it any longer.
1,884 (1.49/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
Hello.
Based on the description you provided to us, the pictures and the links you put, i've come to the conclusion that this card BIOS is original.
I mean it was designed especially for mining not for computing.
Even you highlighted the text that describes exactly that " Without using the software windows will give "Code 43"...
For example i have a batch of Radeon RX 480 that does not even have a display adapter - you can't connect a monitor to any of them.
They were sold by Sapphire as "Mining Edition"
So why in the world you would decide to pay for a card that was designed only for mining and to try after that to use it in a gaming system ?
42 (0.05/day)
Sorry, When I purchased this GPU I didn't really know the difference all I knew was that I was looking for an rx 580 with 8gb, (because it was the cheapest 8gb card I knew of at the time). And since I bought it at the height of the GPU shortage and since it said in the title that it was a "gaming graphics card"\
Me and my small brain thought that it was fine. I'm now more knowledgeable on the topic and regret buying it, but it's not in my budget to buy another GPU.
Since this is the actual original BIOS is it possible for me to get a gaming bios for this card, and if so could you provide the bios I could use?
So sorry for wasting your time, thanks for the quick response though :)
izy
998 (1.21/day)
Can you provide pictures with the sticker and with the memory modules of the card?
Does the card have dual bios? Maybe the other bios works better(if it has dual bios)
42 (0.05/day)
Um, could you point me to a tutorial or send me instructions on where I could find all of this?
thanks in advance!
4,496 (0.83/day)
Denmark
System Name The work PC /2700x/5950x
Processor 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V
Motherboard Gigabyte AORUS Master X570/2xMSI X470 M7 AC
Cooling Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE
Memory 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400
Video Card(s) 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI
Storage 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Lian test bench/NZXT 500
Power Supply AX 850 Titanium/AX 860i/AX 760
Software Dual boot/Win 10 / Linux / Win 10+Linux
42 (0.05/day)
Thanks for this, however before I take out the GPU from my PC is it possible tot ell from the pictures on the ebay's seller page?
Here they are:
izy
998 (1.21/day)
You need to remove the cooler and take a picture of the ram and chip inside so i can try to find a vbios for you. (i cant be sure that the information you gave me about the card are accurate). Ive looked into it and i didnt find much and some people are even saying that it could be an RX 570 more than an RX 580.(sounds kinda weird yeah)
Anyway you could try flashing this (based on the info you provided, at your own risk, not sure if it will make any difference)
r9
3,300 (0.56/day)
System Name Primary|Secondary|Poweredge r410|Dell XPS|SteamDeck
Processor i7 11700k|i7 9700k|2 x E5620 |i5 5500U|Zen 2 4c/8t
Memory 32GB DDR4|16GB DDR4|16GB DDR4|32GB ECC DDR3|8GB DDR4|16GB LPDDR5
Video Card(s) RX 7800xt|RX 6700xt |On-Board|On-Board|8 RDNA 2 CUs
Storage 2TB m.2|512GB SSD+1TB SSD|2x256GBSSD 2x2TBGB|256GB sata|512GB nvme
Display(s) 50" 4k TV | Dell 27" |22" |3.3"|7"
VR HMD Samsung Odyssey+ | Oculus Quest 2
Software Windows 11 Pro|Windows 10 Pro|Windows 10 Home| Server 2012 r2|Windows 10 Pro
This is what I used to install driver after mudding the bios VRAM timings for higher hashrates.
How to use Atikmdag Patcher​
Step 1 - Download the program​
We go to the official site with releases and press the "Download" button. The download will start in 10 seconds. Or download the archive from the official forum. Extract the archive to any convenient folder. atikmdag download
Step 2 - Run the program​
Run downloaded atikmdag-patcher.exe.
If all video card limits are found, click "Yes" to correct and sign. If no limits are found or multiple matches are found, the patcher must be updated to the latest version.
If an error occurs, it is sufficient to reinstall the GPU driver.
atikmdag
Step 3 - Restart your computer​
After completing these procedures, you will see a window that says "Driver successfully patched and signed." Now you need to restart your computer.
atikmdag success
Video Guide​
SUBSCRIBE
Error “43”​
Quite often the “43” error appears on the video card. She reports problems. If you need to patch the video card driver, then you need to use the Atikmdag patcher. Then follow the simple steps:
  1. Download the program and unzip it.
  2. Run as administrator.
  3. In the window that appears, click “yes”.
  4. After completing the operation, confirm the action. Next, you need to reboot the system. If the message with Code 43 does not appear, then the problem is closed. Otherwise, you need to reinstall the driver or the operating system itself. We also recommend checking the equipment itself. When mining, it overheats or the riser has problems.
Video: How to Fix AMD Radeon Graphics Error 43 on Windows 10
izy
998 (1.21/day)
if i am not mistaken Polaris 20 XL is RX 570 not RX 580. (so better dont flash anything before you show us the pictures of the card)
izy
998 (1.21/day)
I cant see the model number on the vRAM chips, can you try focus more on them? Or can you try to read the version from them and write it after?
41,476 (6.58/day)
Its a Gigabyte card by the sticker on the back
Get a pic of a ram chip that has the most legible stencil on it, need to know if it is hynix afr or mfr ram.
42 (0.05/day)
If the Vram is the black thing it's seriously Faded and unintelligible even in person
also I already closed the GPU and put it back in my PC but I have more pictures if necessary.
Also about the RX 570 thing, after a little more research the rx 580 2048 SP is actually a polaris rx 570, it says so on this techpowerup article: https://www.techpowerup.com/gpu-specs/radeon-rx-580-2048sp.c3321
What does the RAM chip look like in the GPU ?
izy
998 (1.21/day)
Well without knowing the vRAM type i can only guess what vBios you need and that can brick your card, do you have iGPU (on the cpu)? Maybe @eidairaman1 can land a hand and give you a suggestion.
Based on your gpu motheboard (113-GA13V10 ) i find vbioses only with Micron memory and we are not sure (at least im not) what type of vRAM you have.
42 (0.05/day)
Here is another some what decent photo
No I Don't have an iGPU I only have a Ryzen 5 3600x
Sorry my phone camera is trash
41,476 (6.58/day)
Ok the green thermalpad above remove it and get a pic there please
42 (0.05/day)
Im so sorry I already put the gpu back in my pc so I cant do that... however if you guys can make an educated guess on a gaming bios I could use I would be willing to risk bricking it.
izy
998 (1.21/day)
I can do only an educated guess and give you like 3 4 different vbios versions to flash and hope one of them will work but you can brick your card and you wont be able to unbrick if you dont have another GPU (as you can get no video output). What i tend to do in this type of situation is using TeamViewer from my laptop (or phone) if im lazy to get my other GPU so i can reflash in case the screen goes black.
42 (0.05/day)
well, actually I have an anicent GPU that I could use if worst comes to worst.
wait how would using TeamViewer work?
izy
998 (1.21/day)
I think its better to listen to @eidairaman1 first just to be on the safe side. @eidairaman1 Is the vram under the thermalpad ? I thought it was the vrm.
@AlphaKelo You can make a free account with Teamviewer then install it on your computer and select "Start at startup" (or what is the option called) , install Teamviewer on second computer / phone log in with the same account and you can connect to your computer (but you should test it before doing anything ofc).
42 (0.05/day)
For the record this is what that black chip says:
SKhynix
H5GC8H24AJR
R2C 916A
VTBNK008WYL
And here's what's under the green thermalpad
