No picture
Status
Not open for further replies.
58 (0.01/day)
Suffolk
System Name Windows 7
Processor intel i7 960 @3.20Ghz
Motherboard Gigabyte GA-X58A-UD3R
Cooling Just a massive fan
Memory 12GB Ram
Video Card(s) Gtx msi 780
Storage 1TB
Display(s) 55" tv
Case Cosmos massive
Power Supply corsair ax 1200
Bought a new nvidia gtx 980 to replace 780, put the new card in and connected the power cables turned pc on and no picture everything connected properly so put old card back in and no picture but the old card was working not 1 minuets before not sure what's happened here any help would be appreciated.
18,584 (2.69/day)
System Name AlderLake
"To replace the 780"? I thought you had a Titan Z 6GB? As in your system specs.
Thats a bummer man, I hope someone here can help you.
2,092 (0.53/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
Are the gpu fans spinning and can you enter the bios? or no picture from the start?
58 (0.01/day)
Suffolk
Memory 12GB Ram
Storage 1TB
Display(s) 55" tv
Case Cosmos massive
No picture well the TV says no signal from the start all cables are connected properly
newtekie1
Semi-Retired Folder
28,473 (4.10/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Check all power connectors, especially the ones going to the motherboard.
58 (0.01/day)
Suffolk
Memory 12GB Ram
Storage 1TB
Display(s) 55" tv
Case Cosmos massive
I haven't touched them they should be ok
the54thvoid
Super Intoxicated Moderator
13,048 (2.39/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
Silly question, does the TV input have to be selected (i.e. HDMI, Antenna etc)? If it's a TV and not a monitor, if the selected input has been changed by mistake, does the TV input have to be checked?
If the PSU comes on and the gfx card fans start spinning, you know you are getting power. If you dont have a windows login password, you should hear the windows tune on booting (unless sound is through TV and not dedicated speakers).
Double check the physical connection from the gfx card to the TV as well. If in doubt, if you have another PCI express lane, try that.
newtekie1
Semi-Retired Folder
28,473 (4.10/day)
Indiana, USA
You very well could have bumped them and one came loose. The 8/4-Pin CPU power connector being loose can cause these symptoms. The PC will power on, but not POST.
Tatty_Two
Gone Fishing
25,940 (3.77/day)
Worcestershire, UK
Software Win 11 Home x64
Did you buy one of those you mentioned on e bay?
12,323 (2.27/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
Reset the BIOS, boot with no card, then replace with the new card.
the54thvoid
13,048 (2.39/day)
Software W10
Lol. Let's stop giving suggestions until the OP replies. We need more feedback to help him out.
24 (0.01/day)
Try a different PCI-E slot and make sure your output signal cable is in fact even connected...
5,689 (1.11/day)
System Name Space Station
Processor Intel 13700K
Motherboard ASRock Z790 PG Riptide
Memory Corsair Vengeance 6400 2x16GB @ CL34
Video Card(s) PNY RTX 4080
Storage SSDs - Nextorage 4TB, Samsung EVO 970 500GB, Plextor M5Pro 128GB, HDDs - WD Black 6TB, 2x 1TB
Display(s) LG C3 OLED 42"
Case Corsair 7000D Airflow
Audio Device(s) Yamaha RX-V371
Power Supply SeaSonic Vertex 1200w Gold
Mouse Razer Basilisk V3
Keyboard Bloody B840-LK
Software Windows 11 Pro 23H2
Did you remember to plug in the Pci Ex power cables on the card, rather than just plugging it into the MB?
58 (0.01/day)
Suffolk
Memory 12GB Ram
Storage 1TB
Display(s) 55" tv
Case Cosmos massive
Done all that
Yes
Done
It's as if like I've connected to an actual real life "IT crowd" you'll be asking me if I've turned it on and off in a minuet
the54thvoid
13,048 (2.39/day)
Software W10
No need to be cheeky.
If you want as much help as we can offer, while not physically seeing the 'fault' you could do some work.
What motherboard is it?
What BIOS revision? Should say on it somewhere.
Take a clear picture of the card installed showing the full motherboard.
Also, you haven't answered (or clarified):
Do the gfx card fans spin up?
Can you plug the speaker output into some headphones and tell us if you get the windows tune?
Does the motherboard have any LED lights?
You may have somehow broken your motherboard or power supply. Give us as much info as I've asked for if you need help.
Otherwise take it to a PC repair outfit and pay them.
21,465 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
12,323 (2.27/day)
Oregon
It would help if you filled out your specs. Did you try it with no card?
58 (0.01/day)
Suffolk
Memory 12GB Ram
Storage 1TB
Display(s) 55" tv
Case Cosmos massive
dorsetknob
9,107 (1.27/day)
Not sure what these lights are
Its at this point you realise sh*t i should have read the motherboard manual
( if you do not have one then download one from the gigabyte support site)
58 (0.01/day)
Suffolk
Memory 12GB Ram
Storage 1TB
Display(s) 55" tv
Case Cosmos massive
The mother board Manual does not really help click the link above it will take you directly to the page
58 (0.01/day)
Suffolk
Memory 12GB Ram
Storage 1TB
Display(s) 55" tv
Case Cosmos massive
What difference does a watermark make
dorsetknob
9,107 (1.27/day)
pay my train fare and BEER money and i will come to you and fix it
58 (0.01/day)
Suffolk
Memory 12GB Ram
Storage 1TB
Display(s) 55" tv
Case Cosmos massive
58 (0.01/day)
Suffolk
Memory 12GB Ram
Storage 1TB
Display(s) 55" tv
Case Cosmos massive
I think I disabled windows startup sound
Status
