NVIDIA Points Intel Raptor Lake CPU Users to Get Help from Intel Amid System Instability Issues
186 (0.10/day)
System Name Donnager
Processor 13900KS, lapped and contact frame
Motherboard Asus Z790 Hero
Cooling Heatkiller IV CPU block, Heatkiller V GPU block, GTX 480mm radiator, D5 pump
Memory 32GB Kingston Fury 7200C38
Video Card(s) eVGA RTX 3080Ti FTW3
Storage Optane 380GB M.2 OS drive, M.2 2TB game drive
Display(s) Alienware 34" Ultrawide 120Hz 3440x1440
Case Fractal Meshify 2 XL
Audio Device(s) Outlaw RR2150 stereo receiver driving DIY kits, Schiit Asgard for Sennheiser HD6XX headphones
Power Supply Seasonic Prime 1000W
I've had some WHEA BSODs at random, I fully understand it's supposed to be a hardware issue, but the one thing I noticed is that Discord was the trigger and whenever it was about to happen, the checkerboarding problem on Chromium (one of the rare few persistent NVIDIA driver bugs) would go out of control. Closing the Discord client all but fixed it.
Most mobo manufacturers have recently released a new BIOS that optimizes undervolting on Raptor and brings some additional stability improvements, you should see if ASUS made that available for you already. MSI posted it for my MEG Z690 ACE yesterday.
Worst is that i'm not even radicalized, it's a reflection of my own experience. :(
I'm definitely going to flash to the newest BIOS this evening and check the CPU power settings. My errors are black screen crashes necessitating a hard reboot.
2,500 (6.39/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
Well xmp profiles are well known to kick the voltages up and so does multicore enhancement which is also enabled when xmp profile is so does this qualify as stock if not people are wasting a lot of money on higher than standard memory speeds hehe
That’s actually part of improper behavior we are talking about. MCE definitely should not be enabled automatically with XMP.
1,950 (0.66/day)
The AMD melting chips/socket issue a while back was something you could actually blame on AMD, because it was their AGESA/EXPO algorithms that were causing the overvolting.
Nice try.
In reality, both AMD and Intel have a lot of collaboration with the motherboard companies. Very little is solely the fault of one or the other. Both this problem and the AMD problem are both solvable by BIOS updates and/or BIOS setting changes. Only brand loyalists try to deflect blame when in most instances the largest companies will try to place blame on the littlest companies if possible.
366 (0.43/day)
The latest BIOS includes "...Further optimized CEP settings when disabled". It might be worth setting IA CEP to Disabled and seeing if that helps.
Ruru
S.T.A.R.S.
12,981 (2.96/day)
Jyväskylä, Finland
System Name 4K-gaming / media-PC
Processor AMD Ryzen 7 5800X / Intel Core i7-6700K
Motherboard Asus ROG Crosshair VII Hero / Asus Z170-K
Storage 3.3TB of SSDs / several small SSDs
VR HMD Oculus Rift CV1
Doesn't surprise me at all since they're basically factory-overclocked to their maximum and Intel themselves have said that 100C temps are totally normal.
Now AMD is having platform issues with its CPUs and games. And they just recently had GPU driver crashes in a gaming tournament.
Why would anyone buy AMD with so many problems? An Intel-Nvidia platform is much more stable.
I don't want my PC to be an unstable heater with a fire hazard power connector.
Shouldn't answer to a troll but that was just a too tempting bait
777 (0.18/day)
Poland
System Name THU
Processor Intel Core i5-13600KF
Motherboard ASUS PRIME Z790-P D4
Cooling SilentiumPC Fortis 3 v2 + Arctic Cooling MX-2
Memory Crucial Ballistix 2x16 GB DDR4-3600 CL16 (dual rank)
Video Card(s) MSI GeForce RTX 4070 Ventus 3X OC 12 GB GDDR6X (2610/21000 @ 0.91 V)
Storage Lexar NM790 2 TB + Corsair MP510 960 GB + PNY XLR8 CS3030 500 GB + Toshiba E300 3 TB
Display(s) LG OLED C8 55" + ASUS VP229Q
Case Fractal Design Define R6
Audio Device(s) Yamaha RX-V381 + Monitor Audio Bronze 6 + Bronze FX | FiiO E10K-TC + Sony MDR-7506
Power Supply Corsair RM650
Mouse Logitech M705 Marathon
Keyboard Corsair K55 RGB PRO
Software Windows 10 Home
Benchmark Scores Benchmarks in 2024?
No issues with my 13600KF since I upgraded 10 months ago, but I have E-cores disabled and I have a 125 W power limit (which can only be reached with Prime95, games never even get close to 100 W).
I've seen streamers have problems with the 14900K, especially in UE5 games. But those CPUs are completely ridiculous for gaming, especially with default BIOS settings which usually have some crazy things enabled.
268 (0.18/day)
Well, it's easy to pin the blame on motherboard manufacturers and rightfully so most of the time. Problem here is that these 'not stock' settings on intel platforms are extremely prevalent and intel hasn't done anything to stop this. In fact, many reviewers also use these non stock settings in their reviews. So it's a case at times where an unstable (or heavily degrading) Intel CPU is being compared against a stable AMD one simply because it's not done on the AMD camp anymore. Lazy motherboard manufacturers pumping stupid volts to get their EXPO settings stable is a thing of the past, thankfully.
Also, for the AMD CPU deaths in the past, you had to enable expo manually in the BIOS for the issue to occur. But on Intel it's the opposite, you pretty much have to change BIOS settings to revert to stock on Intel CPU's. for the issue to not occur That really shouldn't be the case and I wonder how many CPU's were affected by this degradation. I know a friend whose 13900K is having stability issues all of a sudden after a year or so, and he's been using 'stock' ASUS motherboard settings. Absolutely unacceptable, and I wonder why this hasn't been caught by Intel after what, 18 months? Aren't they supposed to be testing the CPU's over time along with the motherboard manufacturers? Maybe if they focused less on extracting 200mhz for 150W more power they'd have figured it out by now.
2,356 (0.50/day)
System Name msdos
Processor 8086
Motherboard mainboard
Cooling passive
Memory 640KB + 384KB extended
Video Card(s) EGA
Storage 5.25"
Display(s) 80x25
Case plastic
Audio Device(s) modchip
Power Supply 45 watts
Mouse serial
Keyboard yes
Software disk commander
I feel like we're going through that phase again where both cpu and gpu vendors are pushing the limits a bit too hard. Well, not AMD cpus, but their power is also creeping up again iirc. Sometimes I think my next PC should be a 95W cpu + sub 200W gpu, performance be d4mned.
7,013 (4.81/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Audio Device(s) Apple USB-C + Sony MDR-V7 headphones
Keyboard IBM Model M type 1391405 (distribución española)
Nice try.
While what you said is true, AMD is still exclusively responsible for AGESA and all of its bugs, no motherboard manufacturer has any involvement in that. So yes, the CPUs burning up, the screwed up memory training, all of that is only on AMD and no one else.
777 (0.18/day)
Poland
System Name THU
This is my new strategy. In games I'm averaging ~50 W on the 13600KF and ~130 W on the undervolted 4070. And I play at a capped 4K60 (usually with upscaling), so utilization is almost never maxed out.
And I don't buy games at launch anymore. They run much better after a few months worth of patches, and you get a nice discount. If a game is too heavy for my config, I'll play it after the next upgrade.
1,142 (0.20/day)
SCOTLAND!
System Name Machine XX
Processor Ryzen 7600
Cooling 120mm heatsink
Memory 32GB DDR5 6000 CL30
Video Card(s) RX5700XT 8Gb
Storage 280GB Optane 900p
Display(s) 19" + 23" + 17"
Case ATX
Power Supply 800W
AMD at least have finally set hard limits for motherboard auto overclocking after the x3d chips started getting killed by the same overvoltage bs motherboard manufacturers have done to both Intel and AMD, they have done it for decades, MCE, fsb overclocking, etc.
The main difference is that its all enabled by default on intel boards, with AMD you need to enable it.
3,862 (0.59/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
"motherboard makers often run the CPU outside of Intel's default spec,"
default should = to specification
If they can't do this and/or don't do this, they should not be in the motherboard business.
930 (0.14/day)
Round Rock, TX
Processor 9950x
Motherboard Asus Strix X870E-E
Cooling Kraken Elite 280
Memory 64GB G.skill 6000mhz CL30
Video Card(s) Sapphire 7900XTX Pulse
Storage 1X 4TB MP700 Pro - 1 X 4TB SN850X
Display(s) LG 32" 4K OLED + LG 38" IPS
Case Lian Li o11 Air Mini
Power Supply Corsair RM1000x
Software WIndows 11 Pro
Neither of my i9's have these issues.
My 14900K is locked to intel limits though, Asus default settings were insane.
My 13900HX of course is low power being in a laptop.
Both are rock solid stable.
18,584 (2.68/day)
System Name AlderLake
Have to wait and see once I upgrade to i7 14700K on my Z690 Aorus Master..
I mean ..I've got the VRM's but.. Wait and see..
594 (0.12/day)
St. Louis, MO
System Name Desktop
Processor AMD Ryzen 7800X3D
Motherboard MSI X670E MEG ACE
Cooling Corsair XC7 Block / Corsair XG7 Block EK 360PE Radiator EK 120XE Radiator 8x EK Vadar Furious Fans
Memory 64GB TeamGroup T-Create Expert DDR5-6000
Video Card(s) MSI RTX 4090 Gaming X Trio
Storage 1TB WD Black SN850 / 4TB Inland Premium / 8TB WD Black HDD
Display(s) Alienware AW3821DW / ASUS TUF VG279QM
Case Lian-Li Dynamic 011 XL ROG
Audio Device(s) Razer Nommo Pro Speakers / Creative AE-9 w/ Audio-Technica ATH-R70X
Power Supply EVGA P2 1200W Platinum
Mouse Razer Viper, Logitech G600
Keyboard Razer Huntsman Elite
I was having random hard locks and resets when I first put my intel system together. Though I am currently using a Beta BIOS from MSI and have locked in the stock limits as specified by Intel. I haven't had any issues really since. Been about 2 months now. I get the occasional hard lock due to Nvidia Driver failure when certain video playback is occurring (Discord Streaming and some embedded videos on web pages).
I researched this quite a bit and found a post on Reddit talking about it and then a video by De8auer who talked about this issue too.
I would highly recommend folks manually set the stock limits for their respective processors and give it a go. For the longest time, I thought it was my RAM but nope, it was the CPU and voltages/currents that the motherboard was trying to force.
7,013 (4.81/day)
São Paulo, Brazil
Make sure you update the BIOS beforehand. The older microcodes will try to initialize 4 e-core clusters on the 14700K, and this will fail as only 3 are enabled in the chip.
18,584 (2.68/day)
I'm on the latest BIOS. Thanks.
4,626 (0.92/day)
Tbh it's past time for the CPU makers to have some words with the motherboard makers regarding this.
Time to put motherboard makers on leash was when Shitsus started to blow up X3D chips and the fact that even after that saga neither AMD nor Intel have talked with them is quite concerning.
1,292 (0.53/day)
Nobody is putting anybody "on the leash".
Reviewers, and consumers, award motherboard makers for even a fraction faster performance - but we know it's just an out of spec setting, a factory overclock. Do you have instabilities, or has your PC just died because of that? That's the part of being in PC Glorious Master Race - you gambled with a cutting edge, and got cut.
The fact is that Intel for several generations now advertises one set of settings when they talk about efficiency, but quite another when they talk about performance. Some reviewers have even gone so far that they hid they used different motherboard settings for different measurements - and later claimed they didn't have to disclose that, because they are all "stock" - some are stock Intel recommended settings, other are stock settings motherboards set as default.
Intel of course knows and validates all the overclock that's going on. And when motherboard vendors finally go too far, they can always wash their hands, point out to them, and claim... Ignorance? Amnesia?
It's nice to have your cake and eat it too, to claim efficient CPUs that barely sip electricity, and on the other hand to claim performance crown (in select areas we proclaim are the only ones relevant), even for the sake of making extremely hot, extremely power hungry products that are destroying themselves in their default settings - "It wasn't our setting!"
Outback Bronze
Super Moderator
2,042 (0.42/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 48GB G.Skill 7200
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Samsung 34" G8
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Asus
Keyboard Corsair
Software Win 11
3,459 (1.17/day)
Processor 9800X3D
Cooling DeepCool AK620
Storage 4TB Samsung 990 Pro
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX850
Mouse Razor Death Adder v3
Software win11
It's interesting who's to blame when you see something like this:
RTX 4090s continue to melt — GPU repair facility claims it works on 200 flagship Nvidia cards per month | Tom's Hardware (tomshardware.com)
In saying that, we don't know which GPU's are having issues with these so-called Intel CPU's but you would think if people have the money for i9's they prob have 4090 as well.
My pal with 4080S + 14900K used to get crashes every 5 mins in Helldivers 2, until he undervolted his 14900K.
Meanwhile my undervolted 13700K + 4090 (with original 12VHPWR connector) are much more stable, though I had to lower CPU clock by 100mhz (5.4ghz P-Cores instead of 5.5ghz) because HD2 utilize the CPU much more heavily than any other game.
Outback Bronze
Super Moderator
2,042 (0.42/day)
Walkabout Creek
Cooling w.c.
Case Corsair 460X
Mouse Asus
Keyboard Corsair
Software Win 11
Nor are people who manually set voltages, even those who are overclocking past stock.
Yeah, never had an issue, just gota know how to not cook your CPU but it helps when you've been OCing for 20 years and know what parameters in the bios to manipulate.
Im not saying Intel is not to blame here but it could be a case of the pot calling the kettle black.
3,459 (1.17/day)
Processor 9800X3D
Software win11
Well the 4080/4090 are pushing CPU harder than any other GPU, that's for sure
201 (0.42/day)
Motherboard ASUS Prime X670E-Pro WIFI
Cooling Noctua NH-D15S
Memory Kingston FURY Beast 2x16GB 6000MHz CL36
Video Card(s) Gainward RTX 2070 Super
Storage Samsung 990 Pro 2TB, Samsung 990 Pro 4TB, Samsung 970 EVO Plus 2TB, Lexar NM790 4TB
Case Fractal Design Meshify 2
Power Supply Corsair HX1000i ATX 3.1
Add AssRack(they burn non 3d cpu's) and MSI(they blame amd for any bios issues) to the list too.
