RTX 3060 Freezing for number of seconds then unfreezes???
179 (0.18/day)
47.1301417 -119.2780771
System Name FronkenSteen!
Processor Intel(R) Xeon(R) CPU E5-2640 v3 @ 2.60GHz, 2601 Mhz, 8 Core(s), 16 Logical Processor(s)
Motherboard X99-UD3P-CF
Cooling The Refrigerator
Memory 16GB
Video Card(s) r9 390x 8GB, RX 580 8GB, RTX 3060 (Barely Functional), An RX 5500 XT and a little cheap ati card ;D
Storage 960GB Kingston
Display(s) one
Case Nun! xD
Power Supply 1200 Watt.. 'Nuff Said!
Mouse Flashing Red Dragon
Keyboard Flashing Rainbow Dragon
VR HMD HP
Software Windows 11 64-Bit (Version: 10.0.22000 Build 22000)
Hey guys!
I am now the proud owner of an RTX 3060 12GB I picked up from Ebay for $94 bucks! :D
the GPU automatically installs the drivers and everything and shows the Nvidia control panel just fine but here's when some sets in...
once the drivers are installed I have about 7 seconds until the picture goes black and freezes then unfreezes and goes back to picture.
I just want to know how and why it does that and how to fix it.
I have it disabled right now and installed.
Anyone have a clue why this happens??
Please I am really desperate to get this to work!
Thank you!
I am running a 1200 Watt PSU.
My Specs:
4K monitor Isnignia
Computer: GIGABYTE
CPU: Intel Xeon E5-2640 v3 (Haswell-EP, R2)
2600 MHz (26.00x100.0) @ 1202 MHz (12.00x100.2)
Motherboard: GIGABYTE X99-UD3P-CF
BIOS: F1, 02/10/2015
Chipset: Intel X99 (Wellsburg-X)
Memory: 16384 MBytes @ 935 MHz, 19-18-18-43
- 8192 MB PC21300 DDR4 SDRAM - V-Color Technology TD48G26S819-VC
Graphics: NVIDIA GeForce RTX 3060 (GA106-300) [Hewlett-Packard]
NVIDIA GeForce RTX 3060, 12288 MB
Graphics: AMD Radeon HD 7470 [DELL]
AMD Radeon R5 235/HD 7470, 1024 MB DDR3 SDRAM
Drive: KINGSTON SA400S37960G, 937.7 GB, Serial ATA 6Gb/s @ 6Gb/s
Sound: Intel Wellsburg PCH - High Definition Audio Controller [B1]
Sound: NVIDIA GA106 - High Definition Audio Controller
Sound: ATI/AMD Caicos/Seymour/Caspian - High Definition Audio Controller
Network: Intel Ethernet Connection I218-V
OS: Microsoft Windows 11 Professional Workstation (x64) Build 22000.318 (21H2)
Frick
Fishfaced Nincompoop
19,286 (2.84/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Make and model on the PSU?
966 (0.44/day)
Uttar Pradesh, India
Processor AMD R7 1700X @ 4100Mhz
Motherboard MSI B450M MORTAR MAX (MS-7B89)
Cooling Phanteks PH-TC14PE
Memory Crucial Technology 16GB DR (DDR4-3600) - C9BLM:045M:E BL16G36C16U4W.M16FE1 X2 @ CL14
Video Card(s) XFX RX480 GTR 8GB @ 1408Mhz (AMD Auto OC)
Storage Samsung SSD 850 EVO 250GB
Display(s) Acer KG271 1080p @ 81Hz
Power Supply SuperFlower Leadex II 750W 80+ Gold
Keyboard Redragon Devarajas RGB
Software Microsoft Windows 10 (10.0) Professional 64-bit
Benchmark Scores https://valid.x86.fr/mvvj3a
This maybe faulty hardware.
If this was used for mining I have seen some GPUs exhibit this exact behavior.
So just a word of caution. If the buyer has another card the he can replace this one with I would look at that option before your return window
closes.
Just a heads up. If the hardware is damaged from mining then you wont be able to fix it. Judging from the price it was either sold faulty or from an ex miner hence the low price.
1,884 (1.50/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
He is absolutely right. This kind of behavior appears usually at abused cards from mining environment.
179 (0.18/day)
Memory 16GB
Display(s) one
Case Nun! xD
VR HMD HP
So there is absolutely NO WAY to fix this??? i can't even use it at all??
It practically looks brand new too no marks nothing..
i can't have it physically fixed either?
Like reflowed or anything like that?
So is there ANY work-around or way to use it without the display and use another gpu for a display??
Best Example: use the 3060 dedicated to gaming and not normal use in nvidia control panel and use just a cheap card for video display???
I WANT to utilize it SOMEHOW..
1,884 (1.50/day)
Romania
Well, the way you will use it depends on the way you will use your computer.
For gaming i doubt that the card will stand the frequencies needed for memory and GPU itself.
Keep in mind that most of the miners OC the cards.
You for example could do it also when you want to play games.
But it is a huge difference between you as a gamer that plays let's say 6h / day and a miner that will run the card at 100% load 24/7.
That is the reason for the non visible damages.
179 (0.18/day)
Memory 16GB
Display(s) one
Case Nun! xD
VR HMD HP
"You for example could do it also when you want to play games"
So how would i do that??
1,884 (1.50/day)
Romania
Well, in that case let's do something else:
If you don't mind i would like to check your actual BIOS to see if it was modded for mining.
Download amdvbflash , run it and do not flash anything, instead use the "save" button
179 (0.18/day)
Memory 16GB
Display(s) one
Case Nun! xD
VR HMD HP
but it's an nvidia card?
ok i'll try it! :D
1,884 (1.50/day)
Romania
Sorry i forgot that - i am red fan :)
Here you are : NVIDIA NVFlash
179 (0.18/day)
Memory 16GB
Display(s) one
Case Nun! xD
VR HMD HP
I am too at this point! lol
ok will do when i get a chance!
Thank you and i will get back to you
The pic above is the most accurate description of the BIOS and everything else.. :)
1,884 (1.50/day)
Romania
As you wish.
When i said to check your BIOS, i mean your hidden settings.
I will open it with a BIOS editor to check if your BIOS was modded for mining.
But you choice.
Solaris17
Super Dainty Moderator
26,654 (3.81/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Display(s) Odyssey OLED G9 (G95SC)
Audio Device(s) Moondrop S8's on schitt Modi+ & Valhalla 2
Keyboard Monsgeek M3 Lavender, Akko Crystal Blues
VR HMD Quest 3
As you wish.
But you choice.
$94
eBay
Non-LHR
Even if it’s been flashed back I bet it was used for mining lol
1,884 (1.50/day)
Romania
As i said earlier i am 100% that the card was abused.
What i don't know right now, if the card still have the mining BIOS in it.
If it does, we can try to help the guy to have at least a gaming card not a mining one.
And as you said : you also bet that too, so we are 2
8,185 (2.19/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
I would also suggest posting a GPU-Z log or HWinfo64 log or both.
179 (0.18/day)
Memory 16GB
Display(s) one
Case Nun! xD
VR HMD HP
Yes please help this poor soul to play some of the latest games!
i will post HWINFO Now... :)
Please excuse the HUGE pics.. :)
and also to clarify,
This Is For Gaming Only NOT mining.. :)
As you wish.
But you choice.
YES please do! :D
  • GA106.rom
8,185 (2.19/day)
SE Michigan
System Name Dumbass
Nice memory size. :D
179 (0.18/day)
Memory 16GB
Display(s) one
Case Nun! xD
VR HMD HP
Why, thank you.. ROFL! :D
1,237 (0.29/day)
California, unfortunately.
System Name Sierra
Processor Core i5-11600K
Motherboard Asus Prime B560M-A AC
Cooling CM 212 Black RGB Edition
Memory 64GB (2x 32GB) DDR4-3600
Video Card(s) MSI GeForce RTX 3080 10GB
Storage 4TB Samsung 990 Pro with Heatsink NVMe SSD
Display(s) 2x Dell S2721QS 4K 60Hz
Case Asus Prime AP201
Power Supply Thermaltake GF1 850W
179 (0.18/day)
Memory 16GB
Display(s) one
Case Nun! xD
VR HMD HP
lol really?? COOL!
Man, that was my first major gpu when i started the collecting.. :D
It still rocks i bet!
1,237 (0.29/day)
System Name Sierra
lol really?? COOL!
It's a GTX970 Founders Edition. That's how all GPUs should feel in your hand and look. Such an attractive hunk of metal!
Sorry I can't really help you with your issue :(
179 (0.18/day)
Memory 16GB
Display(s) one
Case Nun! xD
VR HMD HP
yeah!!!!!
My thoughts EXACTLY! lol
Some people like bikes, some cars, i like GPU's lol
Don't worry about it bro.. :D
yeah!!!!!
Bump, Any suggestions??
I'm at a total loss..
I am afraid to enable it because when enabled in device manager it freezes up after even a few seconds?
Now, i have a BIOS cable i picked up from amazon will that work???
very similar to this
Amazon.com: Ximimark 1 Set SOIC8 SOP8 Flash Chip IC Test Clips Socket Adpter BIOS/24/25/93/95 Programmer : Electronics
Ok,
Here a thought!
WHAT IF my card the HP 3060 OEM is not what it says it is? lol
What if it's really the near identical HP 3060 LHR????
ALSO,
I don't think my X99 motherboard can support Bus InterfacePCIe 4.0 x16... :(
So would that mean i would need a new motherboard?
179 (0.18/day)
Memory 16GB
Display(s) one
Case Nun! xD
VR HMD HP
Bump.
anyone?
63 (0.09/day)
Processor Ryzen 5 5500
Motherboard ASUS Prime B450-Plus
Cooling 3x Inwin Saturn AS120 + 1x Aerocool Standard
Memory 2x8 GB XPG D50 3200 MHz - CL15
Video Card(s) Gigabyte Gaming OC RX 6600 XT
Storage WD Blue SATA SSD 1TB + 500GB Hitachi HDD
Display(s) GAMEON 144hz IPS 1080p
Case Aerocool Rift Tempered Glass
Power Supply MSI MAG A550BN
Ok,
Here a thought!
ALSO,
I am not a computer expert or engineer or anything of that sort, but I think your issue may be connection-related. Maybe the HDMI/DP whatever slot you use is broken or some solder/wire got messed up during the card's previous use. It's safer to just return this and get a different card if you can. Whatever fix you find could stop working in a matter of days.
Whether your card is a regular or LHR version depends on the GA106 that your card's using. GA106-302-A1 for the LHR version and GA106-300-A1 for the OEM version. If you wanna know the type of card, the die on the PCB will say so (I believe).The die is right under the heatsink and fans. Although I am not sure whether or not the die type matters or not regarding your issue.
Regarding PCIe 4.0, no you won't have any issues whatsoever. The drop is so small you'll never lose more than a single frame usually, so no problems with your motherboard's PCIe compatibility.
AsRock
TPU addict
19,010 (3.01/day)
UK\USA
closes.
All so volt modding can to.
