Rtx 3060 ti power supply?
JamisGordo
3 (0.00/day)
850w or 1000w, minimum. Even if you dont use it all, it is always better to have a much greater wattage psu, however brand is very important here, do not cheap out on psus, check tier 1 psus.
Well a 850w PSU in my country is LITERALLY a minimum salary so, no thanks.
1,593 (0.65/day)
London, UK
Really? Well you have to see how it works best for you, there are good tier 1 650w psus. I guess it might not be wattage the problem, the problem must be tier 1 psus are very expensive because the components they have inside.
For example, https://www.newegg.com/evga-supernova-g3-series-220-g3-0650-y1-650w/p/N82E16817438094
This is a 650w tier 1 psu, look how much it costs, $120. There are 650w psus, not tier 1 that costs $50. I would not even think about buying them.
14,275 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Good evening, I intend to buy a 3060 TI next year and i got a question.
Will my Corsair VS500 PSU be enought for a ryzen 5 2600 + 3060 TI
And do i need to change my motherboard?
No and No.
Minimum PSU should be 750W Bronze.
19,375 (3.51/day)
the wattage listed here is so far overkill it almost isn't funny...wow
No and No.
I wouldnt run 500W unit either... that said 750W is surely not the minimum. We covered that a few times here. It depends on the system and overclocking, but hell, a quality 550W unit with both cpu and gpu at stock can have a 3060ti in many cases. I'd say at least 600w for overclocking and adequate headroom. When you start moving to 100W chips, 650W would be considered a minimum.
Its a budget mobo and chipset, that's for sure. But if its working its working...
Rei
656 (0.40/day)
Guam
System Name 1 Desktop/2 Laptops/1 Netbook
Processor AMD Athon X2 64/Intel Pentium 997/Intel Pentium 4/Intel Atom
Motherboard EpoX ATX motherboard/Samsung/Toshiba/Lenovo
Cooling Stock
Memory 4 GB/4 GB/2 GB/2 GB
Video Card(s) Asus GeForce GTX 780 Ti/Intel HD Graphics/GeForce 4MX/Intel GMA
Storage 6+ TB Total
Display(s) HP Pavilion 14 Inch 1024x768@60Hz 4:3 Aspect Ratio CRT Monitor
Case None
Audio Device(s) Various
Power Supply Seasonic 500 Watt & VenomRX 500 Watt
Mouse Wayes Iron Man Wireless Mouse
Keyboard Rexus VR2 Wireless Keyboard
Software Win10 & WinXP SP3
Benchmark Scores It sucks...
Full Config:
R5 2600 Stock
3060 TI
A320M-S2H
VS500
1 SSD and 1 HDD
2 cooling fans
Is this trustable?
If you have correctly inserted your proper upcoming spec into the value, then the screenshot of the PSU calculator you posted should be about accurate, so your Corsair 500 Watts PSU should be able to power your PC just fine.
No and No.
What the hell is with the unnecessarily high wattage requirement?!? It is not energy efficient & his/her wallet would be emptier than it had to be. And the PSU tier list ain't important either as it is just a guideline.
4,827 (0.97/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
seriously, WTF is a "tier 1" PSU?
You go onto the JG forum talking about "tier" lists and they will laugh you off the site. It's a fan boy list half the time and the other half is over kill for anyone who actually needs to see a tier list.
  • Love
Reactions: Rei
Rei
656 (0.40/day)
Guam
Cooling Stock
Storage 6+ TB Total
Case None
He/she is prolly talking about Linus Tech Tips Forum's PSU Tier List. I see it more as Santa's naughty list... :slap:
110 (0.07/day)
So previously i was only considering the 3060 ti because the 3070 is like 200 usd more expensive but now it's only 100usd so like msrp difference. Which one should i go for? I'm playing at 1440p. Do i go for the 3060 ti or just go with the 3070?
19,375 (3.51/day)
Its up to you man. Is the performance difference worth it over the life of the card? Always get the best you can/want to afford.
Rei
656 (0.40/day)
Guam
Cooling Stock
Storage 6+ TB Total
Case None
Obviously, for my take, you should get the 3070 if it's only $100 difference, the performance difference should be somewhat worth it. The TDP between the two is also only 20 Watts difference, so your PSU should be able to handle it. If in doubt about your PSU capability paired with 3070 just use a PSU calculator to make sure. I recommend using OuterVision's PSU Calculator as they are more detailed & more accurate.
4,827 (0.97/day)
He seems to have cleaned it up recently (or since last I saw it). He was on the forum a year or two ago and I explained there were way too many tiers with little real world difference to the consumer that would actually use the list.
110 (0.07/day)
So in the end i went for the asus tuf gaming rtx 3070. Hopefully i made a good purchase. I purchased the gpu from taiwan because it costs 200 usd less than the gpu in my country which is malaysia. The only downside is that there's no warranty but im willing to take the risk as this seller has good reputation and whether or not the gpu fails on me in the future, we'll see.
  • Like
Reactions: Rei
Rei
656 (0.40/day)
Guam
Cooling Stock
Storage 6+ TB Total
Case None
That should be a nice card indeed. How much did you get it for in US dollars?
Trusting a reputable seller is fine and all but there is more to a warranty (or lack thereof). If your GPU does fail in the future, it won't be the seller's fault & maybe that is why it's cheaper. Hopefully your GPU will last a really long time though. Don't take risk such as overclocking, changing cooling, re-applying thermal paste, etc. on your GPU without consulting an expert first.
110 (0.07/day)
No i wont be doing all those. I'm not really a newbie in pc as I'm experienced in overclocking, applying thermal paste etc but i definitely wont be taking the risk. I bought it for 590 usd while in my country it's 790 usd lol. The zotac rtx 3080 is 840 usd in my country so i cant seem to justify going for the 3070 in my country if the 3080 is just 50usd off but i dont have enough budget for 790 usd too. I supposed i'll be taking a gamble.
  • Like
Reactions: Rei
283 (0.13/day)
Processor Intel Core i5-12400
Motherboard ASUS ROG STRIX B660-A GAMING WIFI D4
Cooling Corsair H115i RGB PRO XT (with Noctua Redux 1500RPM fans)
Memory Corsair Vengeance ARGB 4x8GB 3200MHz
Video Card(s) ASUS Dual Mini 3060 12GB GDDR6
Storage Kingston Fury Renegade 500GB, WD SN550 1TB, Samsung EVO 860 1TB
Display(s) LG 27GL650F
Case Thermaltake H550 ARGB TG
Power Supply Seasonic Focus GX-850 80+ Gold
Mouse ASUS Cerberus
Keyboard ASUS Cerberus
Benchmark Scores CB R20: 4710cb CB R23: 12431cb
Hi, a little late, but i am gonna ask it anyway. 10600K (no OC), Z490 Tuf Plus Gaming, 2x8GB Kingston Predator 2933MHz, iCue H100i RGB Pro XT, M.2 250GB Kingston A2000, Samsung EVO 860 1TB, 3x 120mm fans (with LEDs) and a EVGA GQ 650 80+ Gold. Will my PSU be enough for a Zotac 3060 Ti Twin Edge? Thanks!
defrons
6 (0.00/day)
It will be enough bro, Im using leadex iii 550w with the gaming x trio from msi
Rei
656 (0.40/day)
Guam
Cooling Stock
Storage 6+ TB Total
Case None
Don't worry, it's never too late to ask these kind's of question. And to answer your question: Yes, your EVGA 650 Watts PSU is great enough for 3060 Ti. You have nothing to worry about in your PSU department... Unless it's over 8 years old.
PSU power efficiency drops over several years, so if your PSU is for example over 10 years old, a 650 Watts could have the equivalent power rating as a 450 Watts PSU or worse. But this is just a general example. It all depends on the tech & circuitry component inside a PSU.
283 (0.13/day)
Mouse ASUS Cerberus
It's brand new. Here, in Argentina, it's VERY difficult to find a decent PSU at a reasonable price. Thanks for your explanation and time! :)
  • Like
Reactions: Rei
Rei
656 (0.40/day)
Guam
Cooling Stock
Storage 6+ TB Total
Case None
No problem. TechPowerUp community is always happy to help where they can.
If it's brand new, then you will unlikely have PSU issue for a very long time. Just so you know, your PSU should also be able to power RTX 3080 if you decide to upgrade into that or something equivalent in the future. But the fan noise on the PSU will be louder if that is a problem for you.
283 (0.13/day)
Mouse ASUS Cerberus
The 3080, here, is too expensive. I can barely afford the 3060 Ti, haha! Thanks again!
Thanks for your answer! :)
  • Like
Reactions: Rei
461 (0.21/day)
Western NY, USA
Processor AMD Ryzen 7 3700x
Cooling Scythe Ninja 5
Memory G.Skill Ripjaws V 16GB (2 x 8GB) (F4-3600C16D-16GVKC) @ 3733 MHz 16-19-19-19-36-56
Video Card(s) MSI RTX 2060 Super Armor OC 8GB
Storage 1x Samsung 970 EVO 500GB / 3x Crucial MX500 / 4 HDDs
Display(s) Dell 23" LCD S2316M
Case Rosewill Rise Glow
Power Supply CORSAIR RM650
Mouse Cooler Master MS120
Keyboard Cooler Master MS120
Would it be a waste of money to get a 850W PSU?
Not if it is a good quality PSU with a good warranty period.
That will give you plenty of Power for future GPU's.
My PSU has a10 year warranty so I will be using it through at least one GPU upgrade and possibly 2 GPU upgrades.
  • Like
Reactions: Rei
19,375 (3.51/day)
Yes. You can easily have a good quality PSU with a good warranty period and has plenty of power for future GPUs... 650W is fine and will handle any single mainstream CPU and this GPU including overclocking and allowing for plenty of headroom for other items and upgrades. I run a 3080 Strix with a 10980XE overclocked to 4.5 GHz on a 750W PSU. Surely you can run a 3060 Ti and [name CPU here] with 650W. This will put some more money in your pocket and still accomplish your goals.
