Rtx 3060 ti power supply?
DukeRukanGVC
5 (0.00/day)
Yes. You can easily have a good quality PSU with a good warranty period and has plenty of power for gutrure GPUs... 650W is fine and will handle any single mainstream CPU and GPU including overclocking and allowing for plenty of headroom for other items and upgrades. I run a 3080 Strix with a 10980XE overclocked to 4.5 GHz on a 750W PSU. Surely you can run a 3060 Ti and [name CPU here] with 650W. This will put some more money in your pocket and still accomplish your goals.
I'm going to be using an AMD Ryzen 5 1600 or 3400G so seems like the problem is solved, PC parts are pretty expensive here in Norway so my PC is going to cost around $1400 or $1700 with screen, keyboard and mouse
Tatty_Two
Gone Fishing
25,941 (3.77/day)
Worcestershire, UK
Software Win 11 Home x64
Nvidia recommend in relation to Intel CPU's for the RTX3060Ti as a minimum 550w coupled with an i5, 650w with an i7 and 750w with an i9, AMD CPU equivalents are roughly the same, I might naturally be sceptical about the 550w but I suppose if it is using a single 8 pin PCI-E there would be no problem. In my experience Nvidia factor in some headroom for these "recommendations" but generally they don't allow for significant GPU and/or CPU overclocking.
19,371 (3.56/day)
You'll be fine with a 550W with that setup... but I'd still go 650W. 850W is just burning money. :)
97 (0.05/day)
Indonesia
Processor Reasonably good Intel CPU
Motherboard Eh, the cheapest ATX that supports the processor
Cooling Big ass Noctua always a good thing to have
Memory Cheapest 32GB kit for my needs
Video Card(s) Nvidia 3070
Storage NVME 2x, SSD 2x, HDD 1x
Display(s) Dual monitor 1080p for life!
Case NZXT Flow
Audio Device(s) ALC something-something
Power Supply Good ol' Corsair
Mouse Good ol' Corsair
Keyboard Cheap Logitech wireless keyboard
So previously i was only considering the 3060 ti because the 3070 is like 200 usd more expensive but now it's only 100usd so like msrp difference. Which one should i go for? I'm playing at 1440p. Do i go for the 3060 ti or just go with the 3070?
How much is the price difference in your country? From this youtube benchmark, the 3070 is around 10% faster than the 3060Ti@1440P, so if the price matches, I'd buy the 3070 instead. In my country the 3070 is priced 20% higher than 3060Ti and with rumor Nvidia is going to announce new products (3080/3070Ti?) in January, I'm not buying the 3070 as of now.
DukeRukanGVC
5 (0.00/day)
It is
The RTX 3060TI is $399 in the US, but here in Norway it's about $559. But then again Norway is pretty expensive especially when it comes to PC parts
110 (0.07/day)
The 3060 ti is about 570 usd for the gigabyte gaming oc while the 3070 tuf goes for 800 usd. I bought the 3070 tuf from taiwan instead for 600usd but the downside is no warranty. Well there is but i have to send it back to taiwan.
230 (0.04/day)
System Name NERV
Processor AMD Ryzen 5 2600X
Motherboard ASROCK B450M Steel Legend
Cooling Artic Freezer 33 One + 2x Akasa 140mm
Memory 2x8 Crucial Ballistix Sport 2993 MHz
Video Card(s) KFA2 GeForce RTX 3060 Ti
Storage Crucial Mx500 500GB + 1TB HDD
Display(s) Samsung C34H892
Case CM Masterbox Q300L
Audio Device(s) ALC892 + Topping D30
Power Supply Corsair RM650
Mouse CM Mastermouse Lite S
Keyboard Logitech G510
Software Win 10 Pro x64
Benchmark Scores No bech, only game!
Yesterday I built a secondary system with some component laying around the room.
Final config:
- i5 8600k stock
- Z370P D3 Gigabyte
- 16GB DDR4 2400
- SSD 500GB
- 2TB HDD
- Sound Blaster Z
- RTX 3060Ti (temporary moved for testing purpose)
- OCZ ModXstream 500W semi-modular (I know, it's a near 10 years old PSU :-\ )
I installed Rise of the tomb Raider and Need for Speed Heat: Hwinfo said 205W for Gpu power and 67W for CPU Package power. No stability issue during the game session, I'm pretty happy...
Rei
656 (0.42/day)
Guam
System Name 1 Desktop/2 Laptops/1 Netbook
Processor AMD Athon X2 64/Intel Pentium 997/Intel Pentium 4/Intel Atom
Motherboard EpoX ATX motherboard/Samsung/Toshiba/Lenovo
Cooling Stock
Memory 4 GB/4 GB/2 GB/2 GB
Video Card(s) Asus GeForce GTX 780 Ti/Intel HD Graphics/GeForce 4MX/Intel GMA
Storage 6+ TB Total
Display(s) HP Pavilion 14 Inch 1024x768@60Hz 4:3 Aspect Ratio CRT Monitor
Case None
Audio Device(s) Various
Power Supply Seasonic 500 Watt & VenomRX 500 Watt
Mouse Wayes Iron Man Wireless Mouse
Keyboard Rexus VR2 Wireless Keyboard
Software Win10 & WinXP SP3
Benchmark Scores It sucks...
Final config:
- i5 8600k stock
- Z370P D3 Gigabyte
- 16GB DDR4 2400
- SSD 500GB
- 2TB HDD
- Sound Blaster Z
- OCZ ModXstream 550W semi-modular (I know, it's a near 10 years old PSU :-\ )
Nice... :clap: PSU should last another 5+ years. Dunno how much efficiency has gone down but should not be much. It's still good for your current rig.
19,371 (3.56/day)
nor was it good to start with... OCZ PSUs were meh at best. 10 years old... id be looking for another sooner than later. Glad it's working though!
I won't be worried about efficiency so much as it being able to output what it's supposed to in the first place. You're running well under, but I'd still look into getting a high quality unit sooner than later. :)
230 (0.04/day)
System Name NERV
Absolutely correct, I was just curious to see if my old 500W (decent at time) psu was enought with a balanced rtx 3060ti build. After that, gpu will come back to my main r5 2600x rig (and a less old RM650 psu) :cool:
Btw thanks for your advice.
19,371 (3.56/day)
Cool. My point was to clarify that PSU wasn't good (ever, lol) and that it isnt efficiency so much as power output that changes over time. It may last 5 more years, but I'm not hedging my bets on it considering the starting quality wasnt great on that platform. :)
Enjoy!
DukeRukanGVC
5 (0.00/day)
Quick question, does anyone know if the Corsair CV550 PSU would work with the 3060 TI since it needs a certain amount of pins or something like that to power up? The specs on it weren't really clear...
Frick
Fishfaced Nincompoop
19,579 (2.86/day)
PiteĂĄ
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
RainbowSixth
1 (0.00/day)
What about mine, i have seasonic s12g 550w 80+ gold, buy it from mid 2019 i think,. and i want to upgrade my gpu to 3060 ti with r5 3600.
AskYourDoctor
1 (0.00/day)
I thought of buying a Corsair RM650X. Would 650w be enough, if i plan to overclock the CPU a little bit?
PSU calculation sites mostly show ~500W, but i read that the the 10600K could require a 750w psu, and the 3060ti also requires a lot of power.
GPU: Planned to buy a 3060ti OC
CPU: Intel i5 10600KF cooled with Be quiet! pure rock 2 (120mm)
Case-Fans: 4 x 140mm
Mainboard: Gigabyte Z490 Gaming X
RAM: 2x8GB DDR4 3600mhz (w/ RGB)
Storage: Samsung 860 EVO 1TB
Other recommendations and opinions are appreciated, i'm quite new to this stuff.
4,611 (0.94/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
Very good PSU with more than enough power for your build. 750w for the 10600k is flat out incorrect
2 (0.00/day)
CZ
System Name what?
Processor intel i7-8700K@5GHz AVX0
Motherboard Asus ROG Maximus Hero X
Memory 2x16GB 2666@3000 16-16-16-34/CR1
Video Card(s) Palit 3060Ti Gaming Pro OC 8GB
Storage 2x nvme 2TB, 1TB, 3x WD-RED 12TB, 8TB, 8TB
Display(s) LU28R550U, PB278Q
Case Fractal Define
Power Supply Enermax Platimax 550W!
Mouse Razer Naga MMOG
Keyboard Apple Wireless
Software Win10, macOS
Used to have a nitro+ 5700xt with two 4k LCDs attached, hope the old 500W Enermax Platimax will cope now when 3060ti is about to arrive today. The cpu is i7 8700k@5Ghz and with furmark, cinebench and aida running simultaneously there was round 450W on the wall socket. Hopefully it will be ok for (undervolted) 3060ti...
edit: Works like a charm, no issue what so ever.
486 (0.16/day)
Processor Intel i7 4770k
Motherboard ASUS Sabertooth Z87
Cooling BeQuiet! Shadow Rock 3
Memory Patriot Viper 3 RedD 16 GB @ 1866 MHz
Video Card(s) XFX RX 480 GTR 8GB
Storage 1x SSD Samsung EVO 250 GB 1x HDD Seagate Barracuda 3 TB 1x HDD Seagate Barracuda 4 TB
Display(s) AOC Q27G2U QHD, Dell S2415H FHD
Case Cooler Master HAF XM
Audio Device(s) Magnat LZR 980, Razer BlackShark V2, Altec Lansing 251
Power Supply Corsair AX860
Mouse Razer DeathAdder V2
Keyboard Razer Huntsman Tournament Edition
It probably will but the PSU will be at high loads if you plan on running heavy tasks often, so it might lower the lifespan even more or kill it. That's my opinion.
272 (0.07/day)
Singapore
System Name Garbage / Trash
Processor Ryzen 5600X / 5600
Motherboard MSI B450M Mortar Ti / GB B550M Aorus Pro-P
Cooling Deepcool GTE / ID Cooling SE224XT
Memory Micron 32GB DDR4-3200 E-die @ 3600C16 / Ballistix Elite 16GB 3600C16
Video Card(s) MSI 2060 Super Armor OC / Zotac 3070 Twin Edge
Storage HP EX920 1TB Micron 1100 2TB, Crucial M550 1TB, Hynix P31 1TB
Display(s) Acer XB271HU @ 150Hz x2
Audio Device(s) JBL LSR305 + Topping D50S / iLoud MM + SMSL DO100
Power Supply Seasonic Focus Plus 850W / G-series 650W
Mouse Logitech G304 x2
The last time I used a wattmeter it was 300W on the wall for a 8700K + 1070 running Witcher 3
110 (0.07/day)
So im writing this as a follow up to my original question. My rig has an asus tuf rtx 3070 undervolted without performance loss and a ryzen 5 3600 with an aio id cooling zoomflow 240x running at stock. Today i measured the power draw from the wall during horizon zero dawn and heaven benchmark at all max settings. My psu is the corsair cx550m. The wattmeter shows average around 350 and max at 370w. So after calculating the efficiency, my system is roughly using 280w average during game and 296w on peak. So yeah i guess a quality 550w psu is more than enough for a rtx 3070 and ryzen 5 3600.
Deleted member 205776
I'm running an RTX 3070 Gaming X Trio and Ryzen 9 3900X (stock) on a 650W 80+ Bronze CX 650 (for now until I get my RM850x on monday).
No issues whatsoever. PSU is dead silent.
Only issue is PSU-generated GPU coil whine which is why I'm switching to an RM850x, not because the CX 650 can't keep up. It sure can. But the coil whine is a bit annoying.
283 (0.13/day)
Processor Intel Core i5-12400
Motherboard ASUS ROG STRIX B660-A GAMING WIFI D4
Cooling Corsair H115i RGB PRO XT (with Noctua Redux 1500RPM fans)
Memory Corsair Vengeance ARGB 4x8GB 3200MHz
Video Card(s) ASUS Dual Mini 3060 12GB GDDR6
Storage Kingston Fury Renegade 500GB, WD SN550 1TB, Samsung EVO 860 1TB
Display(s) LG 27GL650F
Case Thermaltake H550 ARGB TG
Power Supply Seasonic Focus GX-850 80+ Gold
Mouse ASUS Cerberus
Keyboard ASUS Cerberus
Benchmark Scores CB R20: 4710cb CB R23: 12431cb
Wow, lots of comments and some very helpful. Can anyone tell me if the EVGA 650 GQ is a regular/good/great PSU (i want to replace the 2060S with a 3060 Ti or should i wait till RTX 4000 series)? Running a 10600K at stock, H100i RGB Pro XT, 4x8GB Kingston Hyperx Predator 2933MHz, RTX 2060 Super, ASUS Z490 Tuf Plus Gaming, M.2 Kingston A2000 250GB + Samsung EVO 860 1TB SSD, ASUS Cerberus Kit (mouse and keyboard), Thermaltake H550 ARGB TG, 3x 120mm fans.
110 (0.07/day)
Your psu should be more than enough but i wouldnt upgrade in your case. The 2060s isnt that far off from the 3060 ti in some games. Maybe 3070 is better but at 1080p, i would keep your 2060 super until i see some unplayable framerates in most games.
283 (0.13/day)
Mouse ASUS Cerberus
Thanks for your suggestion. I'm playing everything fine for the moment. It's just the NEED for new things, haha! Cheers!
