Rtx 3060 ti power supply?
283 (0.13/day)
Processor Intel Core i5-12400
Motherboard ASUS ROG STRIX B660-A GAMING WIFI D4
Cooling Corsair H115i RGB PRO XT (with Noctua Redux 1500RPM fans)
Memory Corsair Vengeance ARGB 4x8GB 3200MHz
Video Card(s) ASUS Dual Mini 3060 12GB GDDR6
Storage Kingston Fury Renegade 500GB, WD SN550 1TB, Samsung EVO 860 1TB
Display(s) LG 27GL650F
Case Thermaltake H550 ARGB TG
Power Supply Seasonic Focus GX-850 80+ Gold
Mouse ASUS Cerberus
Keyboard ASUS Cerberus
Benchmark Scores CB R20: 4710cb CB R23: 12431cb
Definitely know that feeling lmao.
I looked online, and some people said that the best PSU calculator is the one incorporated in the CPU part picker website. I attached two pics, one with my current 2060S and the other with the 3060 Ti. Using the EVGA 650 GQ. Cheers!
9,781 (2.18/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
the 3060ti sips power. anything 500W of worth while build quality & above will be fine (if your cpu or other components are high power draw, 600+). you should see the pins on the power plug adapter, they look like tiny little ipod ribbon cable contact, like a plug for a miniature video card. if you see them , you'll know what i mean.
283 (0.13/day)
Mouse ASUS Cerberus
Is this message for me: "you should see the pins on the power plug adapter, they look like tiny little ipod ribbon cable contact, like a plug for a miniature video card. if you see them , you'll know what i mean."? Then the 650 BQ will be enough? Thanks!!
mate-malte
1 (0.00/day)
Hey im getting a 3060 ti and have a i9-9900k with 2x 16 gb ddr4 ram can a 550w psu do the job its about a 1 year old corsair
18,584 (2.67/day)
System Name AlderLake
2 (0.00/day)
CZ
System Name what?
Processor intel i7-8700K@5GHz AVX0
Motherboard Asus ROG Maximus Hero X
Memory 2x16GB 2666@3000 16-16-16-34/CR1
Video Card(s) Palit 3060Ti Gaming Pro OC 8GB
Storage 2x nvme 2TB, 1TB, 3x WD-RED 12TB, 8TB, 8TB
Display(s) LU28R550U, PB278Q
Case Fractal Define
Power Supply Enermax Platimax 550W!
Mouse Razer Naga MMOG
Keyboard Apple Wireless
Software Win10, macOS
18,584 (2.67/day)
Easily recommends 750W psu for my system running Enermax Platimax 500W, beginning to believe I have an exceptional piece.
The BQ PSU test used to be a reliable PSU wattage calculator..
264 (0.14/day)
System Name Ryzen 1
Processor Ryzen 5800X
Cooling Scythe Fuma 2
Memory 32GB Patriot Viper 3600 CL16
Video Card(s) AMD RX 7800 XT 16GB
Storage SSD's
Display(s) HP X32 32" 1440p 165Hz
Case Phanteks P400A
Power Supply Superflower Leadex III 750w
Seems to not overshoot drastically trying to get you to spend more money. Said 605w worst case for me. 8700K and 3060ti on a 500w unit with several hard drives, yikes. Don't run furmark and cinebench at the same time.....
14 (0.01/day)
Turkey
650W or 700W if you'll think overclocking, or that's depends your CPU, or you'll buy other CPU.
