RTX 3080 FTW3 Ultra Problem ROM
emilio5502
26 (0.04/day)
Hello, my case is next
I had 2 graphics cards connected to the PC, a 12 GB 3060 XC EVGA to give the PC an image
And an RTX EVGA 3080 FTW3 ULTRA to flash it from NVFLASH
By mistake I flashed the 3080 with the 3060 rom and now from the device manager I see 2 RTX 3060, one is the one that is fine, which is 1, and the second that appears transparent after clicking on show hidden devices, a message appears 2 rtx 3060, which when you give it puts what you see in the photos
The rtx 3080 appears as 3060 when flashed badly, when you revert the driver it does nothing, from several versions of nvflash the 3060 appears, which is fine, but the other one does not appear so I don't know how to flash it
Using DDU in safe mode I was able to put the 3080 as the basic display adapter, but when connected to nvidia it updates directly as 3060 because it has the 3060 rom inside
Any solution or help is appreciated, since now I have the gpu as a paperweight
Thank you so much !!
142 (0.18/day)
Processor AMD Ryzen 2700X
Motherboard MSI X470 Gaming Pro Carbon
Cooling NH-D15 SE-AM4
Memory 4x Kingston 8GB DDR4-2666
Video Card(s) 2x EVGA GTX 960
Storage Kingston SA400 480GB, LSI 9260-8I RAID[2x WD4005 4TB, 3x Kingston SA400 480GB]
Display(s) Scepter P30, Samsung T22B350
Case Phanteks Enthoo Pro
Power Supply Seasonic Prime Titanium 650w
Mouse Logitech MX Master 3
Keyboard Corsair K60 RGB Pro RGP01110
DDU doesn't revert the ROM file. If you don't have a backup of the 3080 ROM you've got a paperweight. If you do, the only way to fix it is to manually flash the BIOS. Basically any software flash you're gonna do is expecting 3060 architecture, but since it's a 3080 the wrong things go in the wrong places. The fix is to use the backup ROM, if you have one, or someone has to desolder and reflash the ROM with a ROM chip flasher.
emilio5502
26 (0.04/day)
DDU no revierte el archivo ROM. Si no tiene una copia de seguridad de la ROM 3080, tiene un pisapapeles. Si lo hace, la única forma de solucionarlo es actualizar manualmente el BIOS. Básicamente, cualquier flash de software que vayas a hacer espera una arquitectura 3060, pero dado que es un 3080, las cosas equivocadas van en los lugares equivocados. La solución es usar la ROM de respaldo, si tiene una, o alguien tiene que desoldar y volver a actualizar la ROM con un flasher de chip de ROM.
Do I need to desolder yes or yes?
using ch341a usb programmer. Or another solution would not work?
Using DDU I have managed to get the 3080 to show up as the basic display adapter, if I do that couldn't I flash it somehow?
142 (0.18/day)
If you attempt to reflash the chip without desoldering it, you may have more problems, either failing to flash properly due to interference from other components on the board, or in the worst case damaging other components on the board. Also you have to make sure that the programmer you're using is compatible with the BIOS chip you have.
It may be possible to reflash in-circuit using a chip clip and a programmer, but you should get a reliable and trustworthy brand if you want to attempt this.
emilio5502
26 (0.04/day)
Desolder and re-solder? Is there any video?
3,547 (2.58/day)
Processor Ryzen 5 5700x
Motherboard B550 Elite
Power Supply MSI 750w
Mouse G502
doesn't that card have dual bios?
1,400 (0.81/day)
Do you have a backup of your BIOS?
Disconnect from internet, so Windoze won't install drivers after DDU. Here is a copy in TPU database, you can flash it.
emilio5502
26 (0.04/day)
Hello ! Thank you for your message, This GPU has OC and normal bios, But neither works, since I mistakenly updated from NVFLASH the rom to a wrong rom, neither normal nor OC mode works
Thanks for your contribution !
I tell you, when I enter safe mode and in DDU, 2 gpus appear in device manager
Both appear as BASIC DISPLAY ADAPTER
One is my 3060, and the other is the 3080. When removing the internet, the drivers are not updated, but when putting the internet, they are updated and both appear as 3060, although the 3080 appears only when showing hidden devices
The link you sent me is for the ROM, but nvflash doesn't detect the gpu so I can't flash it
If I had the display.inf driver, I could update from device manager then properties on the 3080, and update drivers manually, but I don't have it
3,604 (4.95/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Memory 32 GB DDR4-3200
Storage Yes.
Display(s) MSi G2712
Audio Device(s) Yes.
Software Windows 11 / 10 / 8
https://www.techpowerup.com/vgabios/225304/EVGA.RTX3080.10240.200904.rom if you got a 10 GB version.
https://www.techpowerup.com/vgabios/242626/EVGA.RTX3080.12288.211222_1.rom if you got a 12 GB version.
Just flash (MAKE SURE YOU ARE FLASHING 3080 AND NOT 3060) with an appropriate one using nvflash.exe (https://www.techpowerup.com/download/nvidia-nvflash/) and reboot.
Your DDU can't do anything BIOS-related so you just wasted your time. Drivers and BIOS are different things.
In case nvflash sends you something like "it's impossible bruh" you have to flash using your ch341a.
emilio5502
26 (0.04/day)
Thanks for the DDU
My 3080 is 10 GB but since NVFLASH does not appear, I used several versions of NVFLASH. When I put nvflash --list , it gives me 0 RTX 3060 , but 1 does not give me anything, try nvflash -i1 -b bios.rom and nvflash -i1 -4 -5 bios.rom and nothing says nvidia adapter not found, even if I exchange the graphics, the 3060 still appears in position 0 and the 3080 does not appear in 1, so it is almost impossible to flash from nvflash
The only solution that I see is to buy the ch341a that will arrive in 4-5 days, and with that I hope to be able to fix it although I have no idea how it goes or if I need to look for a file of the 3080 ftw3 ultra to put it with the ch341a or how put it
18,584 (2.66/day)
System Name AlderLake
For what reason did you flash anyway....
Solaris17
Super Dainty Moderator
27,320 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
of course you will need a bios to restore it.
emilio5502
26 (0.04/day)
I flashed the 3080 ftw3 ultra because it started to fail and you need to update the bios, in a hurry and with many files on my pc, I mistakenly flashed the rom of the 3060 EVGA 12 gb on top of the rtx 3080 FTW3 ultra 10 GB
18,584 (2.66/day)
How , "fail", if hardware is damaged, no flash will fix that...
emilio5502
26 (0.04/day)
I have already bought the device ch341a from amazon
I'll receive it in a few days, right now there's nothing I can do besides wait for the ch341a, right?
The 3080 began to fail since I updated the bios of the graphics, it stopped giving an image and the fans go to 100% when starting the pc but it does not give an image
When trying to reflash it with the original rom, I mistakenly put another rom in it
43,714 (6.78/day)
Hardware faults are not fixed via bios flashing, you will need to replace the card.
emilio5502
26 (0.04/day)
I understand, but I have already invested many hours in this 3080, even though things are complicated, I would like to try all the possible ways to see if any of them work and I can fix the graphics or at least put its original rom on it and see if that works, if not then nothing but at least open trying all possible ways
The usb programmer arrives in a few days, will that be enough?
43,714 (6.78/day)
Ok you had a problem with the card before you flashed it, thats a hardware fault. Now you bricked the card. Get a spi flasher and put the card on a shelf
emilio5502
26 (0.04/day)
Ok, tuviste un problema con la tarjeta antes de flashearla, eso es una falla de hardware. Ahora has bloqueado la tarjeta. Obtenga un spi flasher y coloque la tarjeta en un estante
¿No tengo posibilidades de repararlo incluso con ch341a?
Edit Translation: I have no chance to fix it even with ch341a?
43,714 (6.78/day)
You will make the card come back online but that will not fix the hardware fault it has.
At that point it is just a decoration.
If anything go buy a brand new in box RX 6800.
emilio5502
26 (0.04/day)
Well, being able to configure the bios again with the usb programmer will be enough
I saw that to flash the gpu with the usb programmer I need to have the file in .bin format or is that wrong?
43,714 (6.78/day)
I'm pretty sure there are tutorial videos on Youtube that will specify what you need.
Good luck.
Solaris17
27,320 (3.83/day)
Alabama
VR HMD Quest 3
They will come in .bin or .rom
43,714 (6.78/day)
Knowing that card has a hardware fault
I would buy a Brand New In Box 6800XT, that has a warranty on it
