RTX 3080 power supply requirements - 850W?
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
Display(s) DELL U2311H
Keyboard Microsoft Wired 600
I've hurt two 850w PSU's over the years while folding on old hardware, a Corsair and a Thermaltake. Always because I was pushing for max clocks over extended periods. I have seen over 950w come from an 850, but those 2 850s cannot put out anywhere near their rated wattage anymore. The rails are super bendy, and cannot sustain any kind of oc on that system.
Both PSU they can recover to full power if they get serviced by an expert in electronic repairs.
My HIPER 780W PSU (after 8 years ) this collapsed begging of 2020, I did refurbish it by my self ( I am expert in electronics repairs).
But I did feel the feeling of panic for a few minutes, just the idea that I had to deal with a 160 Euro of damage all the sudden when my wallet this was unprepared.
Nowadays I have also the CORSAIR CX750 and this is freshly repaired as it had a strange accident in the hands of another person, as one spare powerful replacement.
21,662 (3.40/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
Yeah right. LOL
He says that about a lot of people. He said it about TPUs PSU reviewer lol...
I have no doubt he has some electronics knowledge, but his ideation around having a degree being EVERYTHING is frankly...
nevermind. If you can't say something nice...
9,691 (3.46/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Kind of. But it is an educated guess and has been done in similar way for a long while.
RTX3080 pulls 350W. High-end CPU pulls 200W, probably 250W if an Intel CPU. Some 50W for other stuff. Then add 30% just to be safe :)
Edit:
Did not actually calculate anything but looks like this guess was a closer than I expected:
350 + 250 + 50 = 650W * 1,3 = 845W
:D
You forgot about the 3 to 8 RGB accessories.
hat
Enthusiast
21,750 (3.27/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
I feel like 850w for a single 3080 is a little overkill. I wouldn't expect to see a system with a single 3080 pull 850w unless it also had an overclocked HEDT processor, running both Prime95 and Furmark at the same time while you are rebuilding your 50TB RAID array because one of your 100 500GB discs failed.
1,006 (0.21/day)
Memory 2x24gb Gskill 8800c38
Display(s) Sammsung G7 32”
Case Dynamic XL
Power Supply Corsair AX1600i
Mouse Model O-
Ax1500i able to power up 3090 and 10900k?
21,662 (3.40/day)
Olympia, WA
System Name Pioneer
Twice over!! o_O
17,503 (4.66/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710 (Red/Black)
SF600 can handle this, 10900K.
wow, my 700w gold psu should do just fine, especially since I might roll the 65w (peak 90ish watt) 4700x. big navi or rtx 3080 i should be sittin good. nice to know. thanks for the video
  • Like
Reactions: Rei
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
I am glad to see that also Optimum Tech he also confirmed my words regarding PSU wattage headroom.
From the other hand all PC users including my self here, we are incapable to guess if our PSU performance this has degrade over time.
But the new owners of RTX 3000 series, they earned the capability to test their own PSU after the installation of the card.
Such a load testing will prove at their own eyes of its one user, of how well stands his own used PSU at this new challenge.
Naturally if your PSU pops it protection at such load testing, buy a new PSU with out begging for help within forums.
Energy related problems they can find cure only by the use of your wallet.
5,961 (0.82/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
I've had a look at the following website where several PSUs were texted with the RTX 3080, and it appears the peak load can be very high.
The recommendations of this tester were 850W for the RTX 3080.
Thoughts?
Here is also the peak power load from Igor's Lab
Thoughts: learn the dictionary definition of "peak".
13,603 (2.01/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
From the other hand all PC users including my self here, we are incapable to guess if out PSU performance this has degrade over time.
Huh? Well of course that is not true at all! Any student of electronics, and many experienced PC users know that PSU performance naturally degrades over time - as do most electronics. Capacitor aging, for example, is a natural and unavoidable process and affects many types of capacitors used in PSUs and other electronics. It is so common in fact that the best PSU calculators adjust for it, as seen by the eXtreme OuterVision PSU Calculator (hover your mouse over "Computer Utilization Time"). While the affects of aging in modern electronics is not as prevalent as it once was due to using different chemistries, purer raw material, and better manufacturing techniques, aging still occurs. Of course compensation circuits can be designed and integrated into the device, but that adds to the complexity and cost. So with PSUs, it typically is easier to add a little extra buffer when sizing your needs.
No guessing required. PSU performance degrade over time.
And any qualified and properly equipped electronics technician can easy measure PSU output and compare it to previous measurements. So precise levels of degradation can easily be determined.
Hmmm, then how are you incapable of being able to guess if your PSU's performance has degraded? :confused:
Huh? :confused: :confused: :confused: Is something getting lost in translation? For sure, not all energy related problems require spending money. A loose ground wire in a wall outlet can wreck havoc but easily be fixed for free with a screwdriver. Of if you only have a left-handed Phillips, you may be out of luck! ;)
  • Like
Reactions: Rei
Frick
Fishfaced Nincompoop
19,793 (2.86/day)
w
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Keyboard Dell SK3205
Remember this is the guy who thinks it's a good thing to withhold knowledge from people because they are not the worthy kings of electronics, IE the high and mighty engineers. He's a feudalist. I like him.
  • Like
Reactions: Rei
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
Good choice of words I can get along with that.
it's a good thing to withhold knowledge of people which are not ready to comprehend it, they do that at schools too.
There is no guy here, here is Mr. Kiriakos Triantafillou.
Low quality post by Bill_Bright
13,603 (2.01/day)
Nebraska, USA
Mouse Logitech M190
2,963 (0.82/day)
Long Island
Theres a lot of malarky oft being parrotted on many sites in threads of this type from days were it mattered and where it never mattered. For example, several myths busted here:
But there is no universal wisdowm that can be applied here ... as with most tools, the goals and level of need varies so must the solutions.
There are many capable sites out there with this information.
"Recommended PSU: 700 W "
" Here is our power supply recommendation:
  • GeForce RTX 3070 - On your average system we recommend a 550 Watt power supply unit.
  • GeForce RTX 3080 - On your average system we recommend a 650 Watt power supply unit.
  • GeForce RTX 3090 - On your average system we recommend a 750 Watt power supply unit.
If you are going to overclock your GPU or processor, then we do recommend you purchase something with some more stamina. "
Things to remember when selecting PSU wattage rating... It's not just about staying away from the point where something blows up. I generally go at about 1.25 to 1.50 times calculated average gaming load:
a) The closer you get to the rated wattage, the more likely the PSU will see decreases in voltage ability and electrical noise and short term peaks will exacerbate these.
b) The close you get to the rated wattage, the greater than fan noise. I'd love to see reviews noting the point at which semi passive PSUs go from no fan to fan spinning
c) The closer you get to the rated wattage the worse the efficiency point. A Titanium PSU at 100% load is as efficient and will produce as much heat as a Gold at 50% load
There is no one size fits all solution to PSU selection. Your average user, serious gamer, heavy overclocker and noise nitpickers all have varying degrees of need and will be looking for PSUs with different characteristics. If ya calculate average gaming load of 500 watts, 625 (+25%) is as low as Id go ...If moderately overclocking with big GFX load, and calculated 625 - 650 watts , Id go 850. If going for the best possible OCs and bigger loads and targeting dead silence while system was running at say 725 - 750... Id go 1050
On this box I am typing from, I had a calculated load of 780 watts including overclocks and dual 23 watt pumps. ... never considered a 850, Had a 1050 on build list but the same Seasonic 1250 was cheaper, Im looking over that the case now while I type this, AutoCAD running on 2nd screen, system is being cooled in passive mode, all case fans, rad fans and PSU fans are not spinning, pumps speed is at 25% My 2nd oldest son had a 850 EVGA G2 on his build list w/ SLI build ... the 1000 G2 was cheaper and tho expected it to be quiet at load , it was the noisiest thing in the build ... asked around various forums and reactions were mixed ... most said their's was fine, but many said they had same issue. It failed and was replaced, but replacement had same issue... he changed GFX cards and now had a Seasonic Gold + 750 w/ single card which is very quiet. He's going to be replacing that with a water cooled 3080.
19,375 (3.52/day)
Sorry, what? Part of the 80Plus metric is taken at 100% load and 50% load. The difference is the few % between them.
EDIT: Oh I see what you are saying. And you are correct.
That said, the problem is that nobody in their right mind runs at 100% anyway, so that's pretty much a moot point, no? People, IMO should be around 60-80% load depending on several factors... as you mentioned, tolerance of noise being one of them as they get louder running closer to their nameplate value. overprovisioning by 50% is just wasting cash in most cases though.
You don't have a system listed... ;)
1,953 (0.61/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
DRDOOM
12 (0.01/day)
I am fully aware these figures represent peak load. Which is exactly why I created this thread - I was curious to know if 850W is actually preferred in a power supply to be on the safe side?
19,375 (3.52/day)
That has been answered... :)
A 750W will be plenty on most situations including overclocking.
45 (0.01/day)
Processor 9700k
Motherboard asrock z390 extreme4
Video Card(s) 5700
Display(s) benq xl2411p 144hz 1080p
Deleted member 203344
Well I looked at it with a more simple approach .. i use a EVGA 3080 ftw ultra running 450w bios so i started with that ... added an allowance for 200w on CPU as its overclocked and another 150w for everything else .. this gave me around 800w.
Ideally you should be running PSU's around 80% capacity for longevity and at their ideal efficiency rating so for me i settled on a Corsair 1000w PSU.
Hope that helps.
253 (0.07/day)
Japan
System Name ChronicleScienceWorkStation
Processor AMD Threadripper 1950X
Motherboard Asrock X399 Taichi
Cooling Noctua U14S-TR4
Memory G.Skill DDR4 3200 C14 16GB*4
Video Card(s) AMD Radeon VII
Storage Samsung 970 Pro*1, Kingston A2000 1TB*2 RAID 0, HGST 8TB*5 RAID 6
Case Lian Li PC-A75X
Software Proxmox 6.2
850W isn't too expensive nowadays anyway; PSU is the last thing I will save on.
I always overkill on PSU, and have got 1000-1600W on my different system for an overhead of ~ 200-400W.
17,503 (4.66/day)
I wonder how much a stock 5900x will pull on watts... it says 105w but i imagine even if i leave everything default it will still boost to 150w?
253 (0.07/day)
Japan
