Samsung 970 EVO Plus temperature sensor?
3,808 (1.73/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
In my case my high temps I considered the poor board design as a factor, the primary m.2 slot sandwiched between the GPU and CPU, two hottest components in system. All because they wanted shorter traces.
The second m.2 in a much more accessible area bottom right of board, I didnt use as only has 2 lanes routed to it. They should have made that one 4 lanes, and the one near CPU 2 lanes. Or even better just no m.2 at all, and supply/sell a m.2/pcie card as SSDs mounted on pcie have much better airflow and away from heat sources.
Trace length isnt a factor in performance as my 970 EVO runs faster in the lowest full length PCIE slot in my case (via adaptor) vs the m.2 right next to CPU.
3,127 (2.35/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
This discussion thread is a good example how posting a manufacturer's marketing photo is far less useful than the OP taking a picture of their actual current build.
We don't know for sure how many 3.5" HDDs the OP has installed in their case. Worse, we don't know if they are evenly spread out through the brackets with lots of space in between (better for airflow, more inconvenient for cabling) or if they are all clumped together (more obstructed localized airflow, easier for cabling).
It would have been helpful if the OP had included in their original post the fact that the other case components weren't showing any excessive heat-related issues and that it was only this particular m.2 SSD with temperature problems.
Again, that points out to a defective unit yet now OP is leaning to making this someone else's problem (the build's future purchaser) rather than resolving the problem.
AsRock
TPU addict
19,172 (2.98/day)
UK\USA
Cooling D15
Correct, but I do not have CPU or GPU issues even my i7-11700K is running stock with one fan on my Noctua NH-D15 chromax.black and my RX 6800 XT Red Devil doesn't really get hot which some cards can do.
Yes I do limit the power to my gpu but it runs the oc clocks that PowerColor set just with less voltage.
This was also why I put up the illustration of the XL filled with drives because it can kill airflow but my Samsung drive even before all the drives was way out of hand.
My 850 EVO doesn't skip a beat and it's only 33c this is the max I seen it at.
I would go M.2. SATA but the drives there for a good one is just priced too high compared even to a Gen3 NVME drive.
Flip the 850 with the other to see if the temps follow ( oops my bad forgot the NVME was the 970 haha ). And if the drive is 60c+ maybe carefully check with your hand. How ever it's going be higher as windows is nearly always trying to do some thing.
You tried Hard disk sentinel ?, that's always been right about the temps for me.
And lets face it it's the drive that's doing the most work out of all the drive OS and games.
EDIT
Just use a heatsink i have a Rocket heatsink and seems to do a good job although you might have to use the bottom slot.
43,494 (6.76/day)
If I look in Samsung Magician the temperture of my 970 EVO Plus 1TB is 34c and normal but CrystalDiskInfo 8.17.5 and lower reports above 60c which program is correct? :confused:
I am planning to go away from Samsung's SSDs because they are too hot compared to other brands that are even fast.
Do a capture while putting a demand on the drive (hwinfo64) and then another run with magician
Thats the problem with m.2 in all mobos, it's in the way, better off to run nvme out of a pcie slot with a heatsink and fan or use a SATA SSD
AsRock
TPU addict
19,172 (2.98/day)
UK\USA
Cooling D15
Maybe one day we will get them flipped to the other side of the board with cases having openings like the CPU does haha. And actually have better cooling for both sides of the motherboard.
43,494 (6.76/day)
A Faster SATA port standard would help and keep the mobo and ssd cooler.
Mussels
Freshwater Moderator
58,413 (7.86/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Haven't read every update - but have you checked the thermal pad on the drive?
Sounds like its contacting the NAND chips, but not the controller (which needs the cooling more)
For this level of speed, you need native PCI-E. That'd mean you'd need a 4x riser cable to every HDD.
It'd be like going back to IDE cables, except more fragile.
And uhh... Intel didn't have even close to the required PCI-E lanes for this for a very very long time.
Even now, we barely have the bandwidth for two x4 drives on each motherboard, any more always comes at a cost of disabling slots, or disabling other features (16x becomes 8x, SATA ports disabled, etc etc)
We miiiiiight see some improvements here, something like a PCI-E 5.0 x8 card could handle 4x 4.0 drives at full speed, if the slot supports bifurcation - but it seems less and less likely. Anything other than NVME->PCI-E directly adds more chips, complications and slowdowns.
7,374 (1.04/day)
Video Card(s) Sapphire Radeon RX 590 Nitro+ SE (RX 7900 XT/XTX or RX 9070 XT?) | Intel® Iris® Xe Graphics
I have now had the cooler part and I can actually see the storage chips in the thermalpad like the edge around them so it's getting squished and I read somewhere that Samsung's storage ram on their ssd's sit a tiny bit lover then the controller or was it vice versa I don't remember I read that some years ago.
Right now the SSID is up to 55c in hwinfo :banghead:
I actually purchased 2 of these coolers I was planing to but one on my Sabrent Rocket that I use for gaming but it's just is chill compared to my Samsung even it's twice the size and speed.
So maybe I am just unlucky with my Samsung SSD here.
EDIT
When I touch the heatsink yesterday I was like wow that's hot even compared to my Red Devil's cooler only way I could bring the heat down on it was adding a fan directly to the edge of my case and set it to really fast rpm which was too load for my taste. But even reviews sometimes state at Samsung's drives run hotter then others which ain't a benefit.
I am already using the bottom slot on my Gigabyte Z590 Vision G board even took of the long passive cooler because the ssd could easily reach 65c without any problems.
You can actually reach my system specs to see how many 3.5inch drives I have in my system I keep it up-2-date.
But here goes the list, 1x10TB, 1x16TB, 1x4TB, 1x1TB and the small Samsung 850 EVO 1TB at the very top.
I am actually using the 10TB as a kind of anti-sag bracket because even my RTX 3070 ROG Strix was so long it rested the edge cooler on it and never been a issue even on my Red Devil :rolleyes:
9,340 (5.14/day)
Louisiana
Keyboard G710+x3
Besides the higher than I've seen temperature doing nothing the actual temp spread between temp 1 & 2 isn't bad.
Before I added my little blower style cooler I saw up to 10c difference in temp 1 & 2 but doing nothing was 40c +- which is pretty silly so yeah 970 is a thermal defect it seems.
Ditch the 970 and replace sounds like a good decision :rockout:
18,584 (2.66/day)
System Name AlderLake
It's hot for my fingers indeed
A 970 evo plus shouldn't run that hot especially when idle.
My 980 Pro sits between the CPU and the GPU with heatsink and it gets up to around 46 degrees when I run a game off it with 25 degrees ambient.
Then my 970 evo sits below the GPU , sitting idle at few degrees cooler.
9,340 (5.14/day)
Louisiana
Keyboard G710+x3
Never asked but is the little fan even running on the cooler ?
It should show up on hwinfo64 if connected.
7,374 (1.04/day)
The fan is only 3 pin sadly so I cannot read anything of it but it spins like crazy :roll:
Tell that to my drive because honestly I think this was the reason last time I tried to game I had a bad time even my game SSD is always 10c cooler then med 970 EVO Plus.
369 (0.23/day)
Texas
System Name Alienware PC
Processor Intel 4790K
Motherboard ASROCK Z97 EXTREME4
Cooling Stock Intel Cooler
Memory 32GB DDR3 1600 MHz
Video Card(s) ATI Radeon HD 7770 2GB GDDR5
Storage SAMSUNG 970 EVO PLUS M.2
Display(s) SAMSUNG UE57 Series 28-Inch 4K UHD
Case Alienware Area 51 Black Tower Case
Audio Device(s) Realtek On Board
Power Supply EVGA 850 watt
Mouse Microsoft Wireless
Keyboard HyperX - Alloy Elite 2 Mechanical Gaming Keyboard.
Software Windows 10 Pro & LTSB & LTSC Windows 11 Pro
7,374 (1.04/day)
@Mr Bill you come with half the size of the ssd and 87c will never be good.
Anyone got a good alternative for ssd that be used as a windows drive gen3 will be enough doesn't have to be gen4 but it has to be 1TB and avaliable on Amazon.de so I can properly find it in my country too.
Sabrent M.2. Gen3 1TB is 115eur and Gen4 1TB is 135eur so don't say does because I already know would like to get omkring about 90-95euro.
369 (0.23/day)
Texas
Could you please explain I guess @70 sometimes I get confused, is my temp 87c? My drive is a 970 EVO Plus NVME, is this not correct?
Thanks!
18,584 (2.66/day)
7,374 (1.04/day)
18,584 (2.66/day)
5300TBW looks too high to be true because the official PDF from Seagate only says 1275TBW for the 530 and 1800TBW for the 520 :confused:
Firecuda 520: https://www.seagate.com/www-content/datasheets/pdfs/firecuda-520-ssd-DS2024-1-1909US-en_US.pdf
Firecuda 530: https://www.seagate.com/files/www-content/datasheets/pdfs/firecuda-530-ssd-DS2059-1-2106US-en_US.pdf
Also there was this thread: https://www.techpowerup.com/forums/threads/seagate-firecuda-530.296984/
Maybe it's all to good to be true. :ohwell:
7,374 (1.04/day)
Maybe and the 520 is actually a bit cheaper like 17eur no much but that TBW is higher and speeds are lower but who needs the 7000+ numbers? I don't.
Hmm it looks like the Seagate Firecuda 520 and the Sabrent Rocket NVME 4.0 uses the same PCB, controller and properly cache but the memory chips are different.
Saw this on a Gear Seekers video:
18,584 (2.66/day)
Anyways there are quite some reviews of 1tb nvme drives on TPU, maybe check some out.
INSTG8R
Vanguard Beta Tester
8,098 (1.10/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
I have a 500GB as my OS drive under the cooler from my MoBo and one sensor when under load can easily be 10C over the 45C vs 55C. Yeah I find it a bit alarming when my 2TB Corsair Core in the second slot as my game drive with just one sensor rarely gets up to 45C.
7,374 (1.04/day)
I have a 500GB as my OS drive under the cooler from my MoBo and one sensor when under load can easily be 10C over the 45C vs 55C. Yeah I find it a bit alarming when my 1TB Corsair Core in the second slot as my game drive with just one sensor rarely gets up to 45C.
I already had this ssd on 2 different drive a Asus Strix B550-A Gaming and my current Gigabyte Z590 Vision G and tested passive they are still same temps no matter if I use the slot underneath the CPU or at the buttom.
This was why I purchased the m.2. cooler and dropped it into the lowest slot of my Gigabyte but this Samsung drive won't do lower temps even moving my Sabrent Rocket 4.0 2TB around it just is chilling no matter it's placement on the motherboard and I best if I add a cooler to this drive it might freeze itself :roll:
3,808 (1.73/day)
UK, Midlands
System Name Main PC
Processor 13700k
That is actually a really good idea, I like it. It would require I think industry working together with cases been sold for at least a few years before with the openings in place as on current cases you would have to take the board out to maintain.
INSTG8R
8,098 (1.10/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
Yeah I tried remounting the heatsink, tried without it, pretty much got the same results as you, no change. Basically the controller on this thing just runs really hot…
Mussels
58,413 (7.86/day)
Oystralia
As for OP's heat issues: Find a way to pad out that thermal pad on the controller. Tear a piece off the end and double up over it, flatten the NAND side down, etc.
You misread that
The 1TB only has 1275TBW, more or less the same as my samsung 970 pro
The 4TB has the 5100TBW
