The latest project - laptop cooled by water
159 (0.05/day)
Poland
Hello !
Today we take the details, made patterns on wooden inserts - inserts resemble air outlets from model P771 to refer to the laptop.
The adapter will be black and the wooden elements will be of ash (light wood).
photos:
Front and back will be 6 inserts. These ones are not different in shape so one pattern is enough to do 6 elements.
159 (0.05/day)
Poland
up!
The wooden inserts need to be fitted and the milling edges of the elements must be bent.
159 (0.05/day)
Poland
UP !
One page made :) - Today I was doing drm so it went much faster: D
photos:
Now you have to make six elements on the other side :). Sponsor of all confusion! The company ... - Ah can not tell their name, they wrote that they will reveal themselves at the end or when the laptop will be flashing;) They will send me a laptop next week.
The P771DM will include:
CPU on LGA 1151 stand (i5 i doubt i7 to give)
Cooling system,
No disks and ram (i'm in the process of fixing this hardware;)
GTX980M 8GB graphics card
Screen 17 inches, I do not know what resolution, so far using the 15 "laptops I have used to a small screen but here the comfort of work should be better - much depends also on the same type of matrix.
This is powerful equipment and very warm at the same time :) - we will see if the whole cooling system after polishing and adding LC will have to show :) Maybe also dild procka: D. For a moment this is all :) Greetings!
159 (0.05/day)
Poland
Grinding continued
I spoke with a barite - he said that it might be that many bumps will kill the flow of fluid ... we came up with something like this:
There will be two copper tubes and the number of bends will be kept to a minimum. It is always a way out, but first version with one tube and a test of water flow, as it will be poor it is already some way out.
CAPSLOCKSTUCK
Spaced Out Lunar Tick
8,578 (1.93/day)
llaregguB...WALES
System Name Party On
Processor Xeon w 3520
Motherboard DFI Lanparty
Cooling Big tower thing
Memory 6 gb Ballistix Tracer
Video Card(s) HD 7970
Case a plank of wood
Audio Device(s) seperate amp and 6 big speakers
Power Supply Corsair
Mouse cheap
Keyboard under going restoration
Time taken so far?
159 (0.05/day)
Poland
Wings done! Now you have to grind them and break the edges in them.
159 (0.05/day)
Poland
The edges of the elements have been broken on the milling machine :)
159 (0.05/day)
Poland
Laptop already with me!
There is even a proce - Intel I7 6700K. Nice :)
Thanks are due to ... well you will soon learn: P
Photos:
And now as I have a patch is the last my post in the topic of xD ... packaging and running away from the limits: D - laughs: P. The P771DM itself features G-Sync, which is an interesting addition - the Full HD. At the weekend with my brother we will bend the copper elements for cooling;) Stay tuned!
159 (0.05/day)
Poland
A piece of adjustable height stand is ready.
Photos:
And so it will be the basis for the ready:
159 (0.05/day)
Poland
up 25.06.2017
The backlight RGB in the stand will look like this:
In addition, I came up with the fact that the keyboard panel can stick in this way - just now the question ...
Beech veneer + black stain + lacquer.
Or ash veneer (such as wings in the stand) + lacquer.
I tak może wyglądać góra :
And the same can be beech veneer, black stain like tar and lacquer, or bright ash veneer and lacquer. There may also be a covered center and the mug flap no longer. What do you think about that? (Much depends on the person)
85 (0.03/day)
Australia
System Name deluge pro
Processor Intel Core i7 6850K Six Core OVERCLOCKED
Motherboard Gigabyte GA-X99-Designare EX Rev 1.0 (Intel X99 ATX DDR4)
Cooling Corsair Hydro H60 Rev2 Liquid Cooling System
Memory Crucial 32GB DDR4-2400
Video Card(s) NVIDIA GeForce GTX 1080 8GB
Storage 500GB Samsung 850 EVO SATA SSD
Display(s) 31.5 Samsung u32E850R 3850R 3840x2160 ^)HZ 4ms
Case Fractal Design Arc Midi R2 (black w/window)
Audio Device(s) Realtek ALC 1150
Power Supply EVGA SuperNOVA P2 1000W
Mouse Logitech Wireless Marathon
Keyboard Das mechanical keyboard 4 Professional
I favour the beech, black, lacquer but as you say it will come down to personal choice.
159 (0.05/day)
Poland
To disassemble the front panel, disassemble the entire laptop - I will not do it now, because I do not have veneers, glue or tools ... but I got bored so I undressed and saw what I was waiting for ...
Remove panel does not problem ...
Later it will be harder ...
Because the touchpad will not remove ... unless it is glued ;/ buttons can be unscrew and wrapped separately or leave.
The upper parts where the speakers are not screwed only welded ... will work with it but this is work to do.
I suspect that with the top cover will not be so much trouble :). Interesting - I did not know that for the smaller model is used the same motherboard: D
159 (0.05/day)
Poland
Up - 27-06.2017
Photos from the works:
The base under the laptop - I do not know if the shape eventually will not change, but I think so will be.
The wooden element of the foot will be made of aluminum, or I will make it from another kind of wood (ash), the photo is now 35mm high - may be 27 mm. So this item will be smaller. I will plug in the connector so that they will not protrude behind the clamp, the other side will be screwed into a non-copper conductor. From the opposite side, the second element of the coupling and the 90 degree angle. I think bending elements will come to me during the week (they were ordered yesterday) so during the weekend bends and attempts to flow water.
159 (0.05/day)
Poland
Bend tube 8mm? Massacre!
Heat does not do anything - from the fact that the tube from the machine is "overheated" and water-cooled, which increases its plasticity. Repeat this process no longer positively affects the bending of the tube. It's nothing, came into the vise for 2 hours of work and the effects are in the photos, it is good in two places slightly need to improve and the whole crush slightly before soldering :), tube nowhere broke so it's also a success, but bigger bends can not do ... It was also possible to bypass all fixing screws so that the dismantling / assembly of the cooling will be trouble-free.
159 (0.05/day)
Poland
Bending the tube went ok!
On 5th gear:
On 1 gear:
I am satisfied: D
Do not complain about the tape which seals the joints temporarily - because their twist is once tight, then after the twist, you have to replace a sleeve that under the force of twisting crushes and seals.
159 (0.05/day)
Poland
Laptop was cut into the first part: P
The rear leg will be attached to the bottom cover so that, with cooling, they will be one piece and can be disassembled without disassembling the space on the quick couplers.
Now you need to correct a bit of a tube, one screw from the CPU is obscured, you need to do so to be good. In addition, you can align the other side ... and align the sections under the couplings. Before soldering, it is necessary to get rid of the black paint from the cooling (paper +500).
Just aesthetics do not worry the bottom part will be finished.
de.das.dude
Pro Indian Modder
9,248 (1.70/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad | Old Monke
Case Ant Esports Tempered case | Thinkpad | NZXT Guardian 921RB
Audio Device(s) Logitech Z333 | Jabra corpo stuff | Some USB speakers
Mouse Logitech G400 | nipple | Dell
VR HMD ;_;
Sub!
surprised you didnt just drill and tap into the heatsink pipes for water cooling plumbing :p
159 (0.05/day)
Poland
We have managed to finish everything on the way :)
For the best photos my younger sister :)
Now you need to cut the tubes, and take care of the back of your laptop as well as the connectors themselves.
For ten moments is yes, it is even better to improve something;):
And seriously, the couplings I can hide still with 7-8mm, I would prefer 5mm ... Improve what not? But it's early in the morning: D now let me finally sleep; P
159 (0.05/day)
Poland
I have reversed the couplings by 5 mm - so optimally.
In addition, I fixed my leg ...
As well as the fittings themselves have been twisted already ready.
In addition, I also sealed the cooling in the lapku ...
I'm afraid to connect it to the xD cradle yet it will start to pour water on all sides and it will be a lime ...: D I'm not picking up today and I will have to overcome it;)
159 (0.05/day)
Poland
So yes ...
Teflon and oring =
100% tightness!
:toast:
3 gear
5 gear max - D5.
After disconnecting the connectors there are water droplets on them - rather it must be so ... must be careful with the oringi that seal the connection.
Virgin firing with the base ahhh this moment ... so many hours of work
:rockout:
Desktop :
menu wot :
Game in wot: (g-sonic something out there) 1 round (about 5-8 min).
Noise? What? -1 The run on the GPU turned on xD ... on the CPU no (from 50 Degrees fan turns on) and now so ... you have to run the valves on the smile.gif and do longer tests. The only ones listening to it are the rotting water in the reservoir xD
The water in the hoses is getting warmer, even the stuck joints of the lap are warm to the touch
I do not know how you smile.gif but I deserved a 4-smile I fire up wota and go :rockout::peace::toast:
Aaa and this teges - you can apply even better paste now i have given some invention since fd added to their water cooling - some GELID or something here is indicated biggrin.gif: D: D
PCH diode? - is ram memory in lap?
159 (0.05/day)
Poland
And now the work culture of the trap:
With stand, 1-speed gear pump + 3 fan max.
With stand, 3-speed gear pump + 3 fan max.
With stand, 5-speed gear pump + 3 fan max.
Without stand ... the colossal difference ...
A couple of photos of the whole:
So we must snatch the hoses and connectors - that is, shorten the hoses and give two the same couplings ... either straight or 90 degrees.
To this, ledy, and we build the bottom of the stool - I will probably make myself cardboard templates;)
You can also do some kind of holder / housing on two power supplies to make one.
