The latest project - laptop cooled by water
159 (0.05/day)
Poland
Today I took behind the LED masking. Diodes (strips) will be inserted in front and on the sides of the stand.
With balsa I made the grilles and I covered them with ash. Diodes will be inserted in the middle and in front of them will be plexi.
The front will be a light stand and the diodes under it. Something like this little backlight that's on the front laptop.
The whole looks like this:
For those moments it's all - after payout you need to have a razor to improve the intel leap;)
Sora for quality but at this time, it's not the time to take Pictures;)
159 (0.05/day)
Poland
6,270 (0.90/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
You going to pain that? If you decide to I sure would like to see it.
159 (0.05/day)
Poland
So everything will be painted.
The stand (MDF and plywood 10 mm) will be painted in black mat - all wood (ash) in the lacquer (half-mat).
6,270 (0.90/day)
New York
Please post pics of the finished job of this amazing work of yours!
159 (0.05/day)
Poland
To finish just a little bit:
- You need to sift through and seize
- Paint
- After painting the wooden elements
- make RGB LEDs
- Delic CPU + thermo paste + polishing cooling + increase the CPU pressure.
- Paint all your laptop cooling on a black mat.
- Mount the screws from the bottom of your laptop.
I can not wait either;) I'm very happy that you like it.
159 (0.05/day)
Poland
We are still working on the bottom of the laptop - but some of the elements will be covered with ash.
Aquatuning.pl Sponsor Pack should arrive within 2 weeks - then we will take care of the cooling of the laptop. (Delid, painting + better clamping for layouts).
159 (0.05/day)
Poland
It went like this:
I am happy, of course, the whole thing you still have to fix on the screws, sand the material and the whole to paint :)
159 (0.05/day)
Poland
UP!
You just have to buy other screws (shorter probably on the bus).
Nuts were melted, then pulled out and pasted into the resulting place :)
159 (0.05/day)
Poland
I made a recess so that the overlay was easier to paste into place
r9
3,300 (0.54/day)
System Name Primary|Secondary|Poweredge r410|Dell XPS|SteamDeck
Processor i7 11700k|i7 9700k|2 x E5620 |i5 5500U|Zen 2 4c/8t
Memory 32GB DDR4|16GB DDR4|16GB DDR4|32GB ECC DDR3|8GB DDR4|16GB LPDDR5
Video Card(s) RX 7800xt|RX 6700xt |On-Board|On-Board|8 RDNA 2 CUs
Storage 2TB m.2|512GB SSD+1TB SSD|2x256GBSSD 2x2TBGB|256GB sata|512GB nvme
Display(s) 50" 4k TV | Dell 27" |22" |3.3"|7"
VR HMD Samsung Odyssey+ | Oculus Quest 2
Software Windows 11 Pro|Windows 10 Pro|Windows 10 Home| Server 2012 r2|Windows 10 Pro
Great job :rockout:.
Just don't forget to paint all black at the end :D.
159 (0.05/day)
Poland
Yes - it will be painted black :) - calmly, first you have to prepare the surfaces and give the backing layer;)
159 (0.05/day)
Poland
Due to the fact that the didy is wiped and glued to its place, it is time to paste the sides and front into the elements on which the laptop stands. As soon as it goes all will still receive a layer of gray primer - then we will compensate for defects, another primer and final black matte paint.
159 (0.05/day)
Poland
Primer layer, filler, grinding and primer layer - so much behind me;)
g
159 (0.05/day)
Poland
The item under the laptop is already done - the break is not corrected. It is true that the aim is not to be similar enough. How to dry to matt and give a light cloud of paint.
Combination of ash and black similar to me: D
85 (0.03/day)
Really interesting project. Will do you a newer revision of this and make it a bit slimmer or is that not possible?
2,363 (0.45/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Keyboard Corsair K95 Platinum
Only if he gets an actual waterblock milled, looks like he's already at the limit with the copper piping and fittings.
85 (0.03/day)
Only if he gets an actual waterblock milled, looks like he already the limit with the copper piping and fittings.
Would be interesting to see how a new revision would improve the whole thing, because from what I can see now the laptop isn't a laptop anymore, more or less a stationary desktop :)
159 (0.05/day)
Poland
The laptop is raised by 28mm.
Not true - laptop can work without LC pad - and with it the working culture of the game is great!
159 (0.05/day)
Poland
nd is still wet). Paint with porous texture is more resistant to scratches.
- Of course not everything is on tip top - you have to improve a little here and there. But the whole is git.
- I got some varnished items and I have to rip off the little black dots and give a new layer of lacquer.
