The latest project - laptop cooled by water
159 (0.05/day)
Poland
I improved today the lacquered elements:
And it looks like this:
159 (0.05/day)
Poland
The look of the laptop has changed a bit :) The elements have to be sanded and varnished. They are glued to two-sided tape in only three places for easy removal.
159 (0.05/day)
Poland
improved cooling - it bounces properly as it should, and the pressure is increased - the bolts were removed, their seats rested against the distance on the plate, so here they were sanded and the bolts themselves under the springs got the pads: D - miodzio.
Cooling took a bit from the burner - so the bottom has to be polished now - especially the parts under the cpu cores and gpu.
159 (0.05/day)
Poland
first applied liquid metal xD i did not know it would be so hard :)
no cep already glued - waiting for tomorrow: D. How something went wrong will be the fix at most xD
159 (0.05/day)
Poland
Today's work with my sister started with polishing CPU / GPU cooling.
The move went to the toothpaste and polishing tips - the whole went out great, you can see the delicate effect of the mirror.
I did not want to waste the "teddy bear" on trial tests - so on the CPU and GPU went past the Alphacool paste.
CPU load after 5 min 100% (UV CPU -130mv) 65 Degrees MAX! - the temperature is obtained without the use of the LC stand :) 4GHz, you can still OC :D
The pump also got a braid;)
159 (0.05/day)
Poland
I would like 4.5 ghz (it is possible because I checked without the LC snapshot but it shows that the CPU gets too little PAPU - will need to raise the W limit and reduce the UV procka - because after 1min cpu decreases the clock to 4,5 Ghz, and again 3.9 Ghz) :) as soon as the starter is complete (I am waiting for Temp sensors and other duperele) then I am putting on CPU and GPU - then we will catastrophe: D
I increased W and decreased the UV (- 40 do not know if you can more) moment and 70 degree pair: D with LC will be better: D (did not jump Power throttling so is cool :) ) - because I was afraid the power supply may be too weak.
159 (0.05/day)
Poland
came pack from Alphacool and Phobya.
I took off the cooling - I corrected a little February using the end of the tin I had. The two-component thermo-conductive adhesive on it did not equate - I know that there is no conductivity of the tin, but some of it has more to smooth out the surface curves so it's visually better to apply black matte paint.
There are also thermocouples, RGB controller, pastes and sensors. So you can fold the cooling rack to the end. Today is my birthday so I had other things to do than a long time digging for the project - I'll try to catch up;)
159 (0.05/day)
Poland
witam !
Cooling painted, dries;)
Sensor stand ready and waiting for flood!
We assume a moment to cool down and ...
still today;)
be cautious!
159 (0.05/day)
Poland
It's hard to breathe the system - like last time:mad:
Well, nothing for longer tests do not have time: P bubbles fly and fly. Starting fluid temperature - 27 degrees - at the end of the test - 35. How not to look at the benchmark, so it will not play - and the laptop turns on the fans only for the first run. Later I will see the pace of the game - more important to me! :rockout:
159 (0.05/day)
Poland
one round of wot - laptop does not even turn on the xD fans (gpu fan activates from 50 degrees to cpu from 55 degrees)
159 (0.05/day)
Poland
They are leds (RGB) is a party!
I seriously sacrificed some time ago. In addition, the reservoir has already taken the assembly threads and stick to the destination.
You need to buy a handle for these wires :)
Durvelle27
6,823 (1.46/day)
Memphis, TN
System Name Black Prometheus
Processor Ryzen 7 3700X
Cooling Thermalright PA120 SE
Display(s) ACER AOPEN 34" 3440x1440 144Hz
Power Supply EVGA 600W
Mouse Logitech Trackman
Keyboard Logitech K350
Software Windows 10 EDU x64
Dude that looks sick
Not a huge fan of laptops but this really makes me wish i had one unique like it
AleksandarK
2,975 (1.06/day)
This reaches all the limits of the known universe. AWESOME WORK!!!
I would like to see more mods from you!
159 (0.05/day)
Poland
thank you very much !
Still a bit and the mod will be finished;)
Would you like me to finish the same movie at the end:
just with a laptop?
159 (0.05/day)
Poland
Leads from leds have been arranged;)
The ledges on the leds got black rims and waited to cut the matte Plexiglas
Wooden ornamental dies on the die received three layers of paint and are ready for assembly.
159 (0.05/day)
Poland
I improved slightly down;) according to one user's guide.
Overlays affixed to the lid of a laptop:
159 (0.05/day)
Poland
Latest project photos:
There is not much to do - soon to end :)
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
even I have to admit that work is really nice looking. not to mention the Image uploads ALONE are a lot of work ;)
159 (0.05/day)
Poland
something I clicked on;)
but not final pics - because ready to go xD must be upright.
I know more or less some pics I want: D
Only the sponsors logo on the matrix has been made;)
159 (0.05/day)
Poland
The project is complemented by:
Memory Kingston HyperX DDR4 2400MHz 16GB x 2
SSDs:
1 Drive - WD BLACK2 128GB SSD / 1TB HDD,
2 Drive - Samsung Evo 840 1TB,
3 Drive - Crucial M.2 (Sata) SSD MX300 275GB,
4 Drive - Apacer Z270 M.2 PCIe GEN 3 x 4 240GB
So thanks to the sponsors;)
tomorrow will put the laptop disks, cut logs and final session already in the wekkend
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
