System Name | Main PC |
Processor | 13700k |
Motherboard | Asrock Z690 Steel Legend D4 - Bios 13.02 |
Cooling | Noctua NH-D15S |
Memory | 32 Gig 3200CL14 |
Video Card(s) | 4080 RTX SUPER FE 16G |
Storage | 1TB 980 PRO, 2TB SN850X, 2TB DC P4600, 1TB 860 EVO, 4TB WD SA510, 2x 3TB WD Red, 1x 4TB WD Red |
Display(s) | LG 27GL850 |
Case | Fractal Define R4 |
Audio Device(s) | Soundblaster AE-9 |
Power Supply | Antec HCG 750 Gold |
Software | Windows 10 21H2 LTSC |
Skip to 13:06 for the important stuff, video is padded out a lot.Der8auer got the card & cable & PSU.
Observed and compared the results with his own 5090.
Finds out there are 2 wires carrying 20A in stress testing. (Other wires carried ~5A)
It makes those 2 wires extremely hot and dangerous.
The 12V-2x6 plug works already. The only problem is there is a lot of the 12VHPWR cables still out there. Even Der8auer stated all his test setup is 12VHPWR. Those should all be recalled.yeah they need to improve the aera of connection too and those cylindric system are always a pain in the a***
perhaps one day we are gonna have plug with screw to tighten plugs
There is no difference between the 12V-2x6 and 12VHPWR standards when it comes to cables according to https://www.corsair.com/us/en/explo...nits/will-my-12vhpwr-cable-work-with-12v-2x6/ . If there are any differences between a manufacturer's 12V-2x6 and 12VHPWR cables other than labeling, names, and part numbers, then either the manufacturer is possibly admitting that its 12VHPWR cables are garbage because it cut down the quality of the 12VHPWR cables to be just good enough for an RTX 4090 and is not good enough for an RTX 5090 because the RTX 5090 draws more amps and therefore demands more of the cable than what an RTX 4090 demands.The 12V-2x6 plug works already. The only problem is there is a lot of the 12VHPWR cables still out there. Even Der8auer stated all his test setup is 12VHPWR. Those should all be recalled.
System Name | Personal Gaming Rig |
Processor | Ryzen 7800X3D |
Motherboard | MSI X670E Carbon |
Cooling | MO-RA 3 420 |
Memory | 32GB 6000MHz |
Video Card(s) | RTX 4090 ICHILL FROSTBITE ULTRA |
Storage | 4x 2TB Nvme |
Display(s) | Samsung G8 OLED |
Case | Silverstone FT04 |
