using external power supply for graphics card
1,146 (0.20/day)
SCOTLAND!
System Name Machine XX
Processor Ryzen 7600
Cooling 120mm heatsink
Memory 32GB DDR5 6000 CL30
Video Card(s) RX5700XT 8Gb
Storage 280GB Optane 900p
Display(s) 19" + 23" + 17"
Case ATX
Power Supply 800W
this is come power consumption figures i took with my killawatt meter
1.05vcore no cool and quiet
cpu
138w load
99w idle
so with 138w will a full prime 95 load leaves 62w ish
well from what i got from a german computer site as
4.38A @ 11.89V = 52.1 W pci-e slot
7.82A @ 11.97V = 93.6 W from the pci-e power cable for the hd4850 so that is well below the 120w or 10A that the external power supply can deliver
138w+52.1w = 190.1w that is a bit close to the wire on the internal power supply so i think i will so some undervolting and underclocking of the graphics card to bring the power draw down.
even then i highly doubt that i will be running furmark + prime 95 at the same time.
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
ok ive got the relay and the diodes now i just have to go over to my friends and swap my hd4850 golden sample for his reference design single slot 4850
i have also ordered a lot of new parts for this computer ive got the flu just now and in my fevered delirium i started thinking crazy thoughts like a full water cooling setup, lcd screens and much much more.
my water pump just fits under the hard drive rack and i can get a 80mm radiator and a 92mm radiator to fit on it and i still have a cpu/northbridge waterblocks i want to fit.
but il leave that for now and focus on getting the graphics card working.
i have made up a circuit that will let me use a red/green/blue led to indicate the status of the external power supply. when the computer is off and the power supply is connected the relay is open and turns on the red part of the led to let me know that the power supply is connected ok and when the computer is powered up it will close the relay and connect the blue part of the led letting me know the graphics card has power.
the new parts ive ordered for the computer are
aluminum sheet for the front. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150380922094&ssPageName=STRK:MEWNX:IT
new usb ports for the front http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160363354028&ssPageName=STRK:MEWNX:IT
new power switch http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160369271033&ssPageName=STRK:MEWNX:IT
reset switch http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320433577305&ssPageName=STRK:MEWNX:IT
rgb led's http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=380127739848&ssPageName=STRK:MEWNX:IT
led holders http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=350232770025&ssPageName=STRK:MEWNX:IT
usb lcd display http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220485014364&ssPageName=STRK:MEWNX:IT
im going to start a project log soon once i get the graphics card in.
Sir_Real
706 (0.12/day)
Lincoln England
Processor PC 1: Q6600@3.25,1.34v / PC 2: E8200@3.88,1.35v
Motherboard PC 1: Asus P5Q-SE / PC 2: Asus P5Q-E
Cooling PC 1: Air / PC 2: Air
Memory PC 1: 4gb Ocz PC8500 / PC 2: 4gb Kingston hx PC8500
Video Card(s) PC 1: Saphirre HD4870x2 2GB / PC 2: 2x XFX HD4870 1GB in xfire
Storage PC 1: Samsung 750GB (win7) + Seagate Barracuda 500GB (XP pro) / PC 2: Seagate Barracuda 160GB
Display(s) 2x HANNS-G HH251 24.6" 1980x1080 LCD
Power Supply PC 1: CIT gold 750watt / PC 2: Powercool 850watt modular
Software PC 1: Win7 home 64 + XP pro 32 / PC 2: Win7 home 64
Benchmark Scores PC 1: 3Dmark2006: 18674 PC 2: 3Dmark2006: 19250
Seems alot of messing about to me ! Whats wrong with just flicking the switch at the wall socket ?
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
lol that would be easy wheres the fun in that.
2,555 (0.39/day)
Illinois
Processor i7 2600k@4.6ghz
Motherboard MSI z68ma-ed55
Cooling Silentx Extreem 120mm
Memory 2x4gb XMS 7-8-7-20 1600
Video Card(s) HD6870
Storage 2x128gb Kingston Hyper-X (Raid0), 2x750gb RE3 (RAID1), 2x750gb RE3 (RAID1)
Display(s) Soyo 24", Gateway 22"
Case Fractal Design Arc Mini 6x120mm fans.
Power Supply Zalman 750w
Software Windows 7
Looking good Geofrancis. Didn't want to waste that other switch pole on the relay hmm? At first I thought your LED was an op-amp and I was really wondering wtf you were doing then I read the post. :laugh:
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
well i wanted to run an op-amp but i didnt see the point :laugh:
if i get everything i want into this computer actually into it then it must be some kind of record for the most computer parts stuffed into less than 1 cubic foot.
2,555 (0.39/day)
Illinois
Software Windows 7
I have .1812 cubic feet to cram 12,000 3dmarks into without burning the carpet.
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
nothing liquid helium wont fix lol
i also discovered a natural coolant that i use when things go on fire....i piss on it
2,555 (0.39/day)
Illinois
Software Windows 7
I hope you unplug it... unless your into that kinda stuff... in which case I still hope you unplug it. :roll:
1,037 (0.17/day)
London, England
System Name Le Don
Processor Core i 5 2500K Unlocked 3.3GHz HD Graphics 3000
Motherboard Asus P8P67 Pro B3 Revision Rev 3.1
Cooling Arctic Freezer Pro 7 Rev.2
Memory 8Gb Corsair DDR3 (CMZ8GX3M2B1600C9), 1600MHz, 1.5V, 9-9-9-24
Video Card(s) EVGA Signature 2 Super Clocked GTX680 2GB
Storage Total 6 TB storage
Display(s) LG 23" D2342P and LG 42" 42LF65 LCD (Wall mounted)
Case Antec P180 Silver
Audio Device(s) Audigy 2 ZS Platinum Pro
Power Supply Corsair 850HX
Software Windows 7 Ultimate 64-bit,
TheMailMan78
Big Member
22,599 (3.49/day)
'Merica. The Great SOUTH!
1,037 (0.17/day)
London, England
System Name Le Don
no thanks, that one's NOT an urban myth.
2,555 (0.39/day)
Illinois
Software Windows 7
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
does anyone know where in the uk i can get some very thin bolts about 1mm that i can use to secure a northbridge waterblock to the motherboard?
2,555 (0.39/day)
Illinois
Software Windows 7
Do you have a hobby shop in your town? Some hardware stores also carry very small machine screws but they might be on a seperate rack then the other nuts and bolts.
1,644 (0.27/day)
System Name Black Killing Machine
Processor Delidded NO IHS mount Intel i7-4770k
Motherboard Gigabyte Z87X-OC
Cooling Swiftech DIR655 pump, Watercool HEATKILLER® GPU-X³ 79X0 Ni-Bl gpu, DT SNIPER CPU block, UT60 420 RAD
Memory Gskill Trident 2400mhz CL9 Samsung IC9
Video Card(s) SAPPHIRE HD7950 OC 950mhz Edition, VaporX HD7950
Storage 2xM4 Crucial 64GB RAID 0, 1 OCZ AGILILITY 3 60GB, WDCB 500GB x2RAID0, WD Green, Hitachi 1TB
Display(s) Samsung SyncMaster 226BW and 24" 120hz BenQ gamer
Case SilverStone Raven rv-02
Audio Device(s) Audio Technica ATH-AD900 headphones, Topping D2 DAC/Headphone AMP
Power Supply Seasonic Platinum 860
Software Windows 7 Pro 64bit
Benchmark Scores http://hwbot.org/user/sonda5/ Delidding is magic. http://valid.canardpc.com/2878462
Now why whould u do taht when its known that u shortsircuit the green mobo pin of the psu in need with any ground....
Short circuiting is not a good thing.
I had the extra MB sitting around and it was easy to do. didn't have to mess with my main RIG MB. Kept the video card PSU out of the case. Just ran the power cables through the holes in the rear of the ANtec 900 case.
It was just an experiment. I did end up pulling off my best Vantage score though.
http://service.futuremark.com/resultComparison.action?compareResultId=1411203&compareResultType=19
Performance gain from multi-psu set up is marginal and questionable.
I was trouble shooting my main Corsair TX650W to see if I should upgrade PSU.
Results proved to me that I didn't need to upgrade PSU.
Best to go with a good PSU that is rated for devices to begin with.
2,555 (0.39/day)
Illinois
Software Windows 7
I did a few tests on my HD3870 to see what it was drawing off the 12v connector.
DC amps / activity
1.90 / Post and booting.
0.25 / Windows desktop.
2.6-3.2 / 3dMark06 with the highest current draw being Firefly Forrest.
I read this card is 80w. I also read the standard for 6-pin is 75w and 8-pin is 150w. Divided by 12v = 6.25a and 12.5a respectively.
I wanted to mention my results with the 4850. It's bios modded for lower idle clocks and fan control was altered. Readings taken from 12v connector. Quite a difference from the 3870. :confused:
DC amps / activity
3.35 / Post and boot
2.08 / Windows desktop
6.14 / 3dmark Firefly Forest
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
DC amps / activity
well that looks less than i was expecting so it shouldnt have a problem running of the 120w 10a psu.
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
i have came up with a plan for my computer to fit all the watercooling components i will need into it.
its gonna be tight!
375 (0.06/day)
United Kingdom / Poland
System Name FlowTI
Motherboard MSI MAG B650 TOMAHAWK WIFI
Cooling Arctic Liquid Freezer II 240 RGB
Memory Corsair Vengeance DDR5 32GB 6000MHz/CL30 RGB
Video Card(s) Gainward GeForce RTX 4070 Ti
Storage Main: Crucial P5 Plus 1TB | Data: Crucial P3 Plus 4TB
Display(s) DELL S2721DGFA 165Hz
Case NZXT H5 Flow RGB
Audio Device(s) Audioquest Firefly Black DAC | Beyerdynamic DT 700 PRO X | Shure MV7 Microphone
Mouse Logitech Pro X Superlight
Keyboard Logitech MX Keys
Benchmark Scores Don't care
All :respect: Microsoft Paint. :rockout:
:D
Looks good IMO. Good luck!
2,555 (0.39/day)
Illinois
Software Windows 7
This is all crammed into that case? haha nice.
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
TheMailMan78
Big Member
22,599 (3.49/day)
Any pictures of fire? I wanna see some burning silicone damn it!
2,555 (0.39/day)
Illinois
Software Windows 7
yea its gonna be real tight! you should try and get some watercooling into your build.
I already have to modify the powersupplies heatsinks to get that to fit. lol Trust me there's no more room except for this little pocket under the... How small do they make pumps? :D
