using external power supply for graphics card
1,146 (0.20/day)
SCOTLAND!
System Name Machine XX
Processor Ryzen 7600
Cooling 120mm heatsink
Memory 32GB DDR5 6000 CL30
Video Card(s) RX5700XT 8Gb
Storage 280GB Optane 900p
Display(s) 19" + 23" + 17"
Case ATX
Power Supply 800W
I already have to modify the powersupplies heatsinks to get that to fit. lol Trust me there's no more room except for this little pocket under the... How small do they make pumps? :D
lol i was looking at a picture of the your case you could get the pumps and waterblocks in but theres no where to put a radiator.
i suppose you could mabe squeeze one of these dual 40mm radiator in.
http://www.aquatuning.co.uk/product_info.php/info/p1703_Magicool-Mini-II-2x40-Radiator.html
2,555 (0.39/day)
Illinois
Processor i7 2600k@4.6ghz
Motherboard MSI z68ma-ed55
Cooling Silentx Extreem 120mm
Memory 2x4gb XMS 7-8-7-20 1600
Video Card(s) HD6870
Storage 2x128gb Kingston Hyper-X (Raid0), 2x750gb RE3 (RAID1), 2x750gb RE3 (RAID1)
Display(s) Soyo 24", Gateway 22"
Case Fractal Design Arc Mini 6x120mm fans.
Power Supply Zalman 750w
Software Windows 7
Now your just egging me on. lol
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
what about a 80mm radiator where the hard drive mounts are behind the graphics card.
2,555 (0.39/day)
Illinois
Software Windows 7
You mean the mount at the front of the case that I'll be removing to make room for the videocard lenght? There will be about ~1.25" of space back there between the videocard and the bottom of the case. I planned on putting a 60 or 80mm thin fan there on the bottom to blow fresh air into the case for the video card. I'd need a really thin 1/2" radiator to make that work. I may need that space for a psu heatsink. I'll need to heatpipe from the psu over to it though.
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
2,555 (0.39/day)
Illinois
Software Windows 7
I didn't want to frankenstein the outside at all. Other then the fan in the bottom, there's no outside modifications. I'm trying to tweak it out as best I can and retain a simple look.
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
ah well then worth a shot lol. i dont really like having bits sticking out my computer either.
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
i have just been counting up how much the watercooling setup for my computer is going to cost me its nearly reching ÂŁ100
got
zalman cpu waterblock
zalman northbridge block
XSPC 450LHP pump
hose
i still need
92mm radiator ÂŁ28
80mm radiator ÂŁ18
graphics card core block ÂŁ15
graphics card ram block ÂŁ16
4x 90 degree fittings ÂŁ10
4x hose clamps ÂŁ2.50
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
thats me got the wiring for the external power supply set up and soldered together. just got to swap my 4850 for my friends single slot version then get it all in the case.
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
I managed to swap my 4850 with my friends single slot one and fit it along with the relay to turn the power on into the case no problem its ran furmark and 3dmark06 and its not had any problems so far. the next step is to setup the leds for the external psu status and mabe cut a vent in the side of the case bacause the graphics card is running a little hot.
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
i have ran it for a day now and the only problem i have found is that the 4850 is dumping so much heat into the case that its setting the thermal alarm off on my hard drive rack but it has been running fine without the case on it. im going to cut some vents on the side of the case to let air in and the hot air out.
2,555 (0.39/day)
Illinois
Software Windows 7
That sounds familiar. lol
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
the joys of small computers :laugh:
i am going to cut a hole in the case next to the graphics card and put one of those wire fan grills over it and another slot in the case for the hot air to leave.
i will probably make a fan shroud like the one on your 4850 to help the hot air leave the case entirely and form a seal between the graphics card and the vents on the case.
Solaris17
Super Dainty Moderator
27,282 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
this is some crazy rediculous shit good job dude you pulled it off :toast:
2,555 (0.39/day)
Illinois
Software Windows 7
Geo let me doodle up an idea for you. brb
Ok, This it a top view. How about something like this but rather then blowing out the back like mine, angle yours towards the side of the case and put a few vertical rows of holes in the case side.
I also cut off the plastic deflector that directs the air upwards. This gave it a straighter shot back.
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
lol that was pretty much exactly what i was planning to do. my dremel packed in so im just waiting for a hacksaw and some files to arrive so i can cut it by hand.
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
i have gave up on the aluminum front as it kept getting scratched so i ordered a perspex front as its much easier to cut and shape so im waiting for the perspex so i can get my led's, usb ports, power and reset buttons all mounted. without the hassle of trying to shape aluminium.
2,555 (0.39/day)
Illinois
Software Windows 7
Aluminium is butter! What's giving you a problem? Maybe I can suggest something.
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
there was scratches all over it and i burnt out my dremmel so i figured i can do just as good a job with clear plastic with an aluminum backing. the plastic is much easier to work with. i can file it into shape much easier and get everything into place rather than hacking away with aluminum that takes a lot longer.
i also got the overheating problem sorted. the problem was my sata rack was set to turn the overheat alarm on at 45c so i set it to 55c instead and now there is no alarms going off all the time.
my lcd screen finaly arrived and has been tested so im going to have that mounted soon
2,555 (0.39/day)
Illinois
Software Windows 7
Did you do the side port mod for your gpu intake? How's that working out?
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
i didnt have to the reason i was going to do that mod was because like i said my hard drive rack overheat alarm kept going off but all i had to do was set it from 45c to 55cf and now there is no problems. the hard drives were never in danger but the alarm is loud and annoying.
the card still runs a but hot but the fan only hits 60% its still loud so i might do the mod anyway once i get another dremel.
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
bad news kids the 120w psu i was using has been acting up. first it started with freezing when it was starting up the computer. but it got worse and worse BSOD's freezing crashing.
i only noticed that the psu was cutting in and out because i seen the red light on the back of the graphics card going on and off and the fan going mental.
next step is to get a new power supply possibly a 200w psu that i can mount internaly like this one
2,270 (0.39/day)
the uk that's all you need to know ;)
System Name not very good (wants throwing out window most of time)
Processor xp3000@ 2.17ghz pile of sh** /i7 920 DO on air for now
Motherboard msi kt6 delta oap /gigabyte x58 ud7 (rev1.0)
Cooling 1 green akasa 8cm(rear) 1 multicoloured akasa(hd) 1 12 cm (intake) 1 9cm with circuit from old psu
Memory 1.25 gb kingston hyperx @333mhz/ 3gb corsair dominator xmp 1600mhz
Video Card(s) (agp) hd3850 not bad not really suitable for mobo n processor/ gb hd5870
Storage wd 320gb + samsung 320 gig + wd 1tb 6gb/s
Display(s) compaq mv720
Case thermaltake XaserIII skull / coolermaster cm 690II
Power Supply corsair hx 650 w which solved many problems (blew up) /850w corsair
Software xp pro sp3/ ? win 7 ultimate (32 bit)
Benchmark Scores 6543 3d mark05 ye ye not good but look at the processor /uknown as still not benched
788 (0.14/day)
Seattle
Processor Intel Xeon x5660 (4.2ghz)
Motherboard Gigabyte X58A-UD3R
Cooling Corsair H100
Memory 24gb (6x 4gb DDR3 1600) Kingston Hyperx
Video Card(s) XFX Black r290x 4gb ddr5 OC
Storage 6x 2tb 64mb WD drives, Patriot Pyro sandforce2 drive ,intel 180gb ssd
Display(s) HP w2558hc
Case Corsair Carbine 500r
Audio Device(s) X-Fi Pro Fatality
Power Supply XFX 750 watt
Mouse Thermaltake Theron ee Sports+
Keyboard Corsair Vengence k70 RGB Cherry Red
Software Windows 8.1 x64
looks like a mini 1u power supply.
the only problem i see with them is that they run hot, and typicaly have a deafing 40mm fan
