using external power supply for graphics card
1,146 (0.20/day)
SCOTLAND!
System Name Machine XX
Processor Ryzen 7600
Cooling 120mm heatsink
Memory 32GB DDR5 6000 CL30
Video Card(s) RX5700XT 8Gb
Storage 280GB Optane 900p
Display(s) 19" + 23" + 17"
Case ATX
Power Supply 800W
looks like a mini 1u power supply.
the only problem i see with them is that they run hot, and typicaly have a deafing 40mm fan
yea thats what i thought so i just got another 120w external power supply. im just waiting for it to arrive.
2,555 (0.39/day)
Illinois
Processor i7 2600k@4.6ghz
Motherboard MSI z68ma-ed55
Cooling Silentx Extreem 120mm
Memory 2x4gb XMS 7-8-7-20 1600
Video Card(s) HD6870
Storage 2x128gb Kingston Hyper-X (Raid0), 2x750gb RE3 (RAID1), 2x750gb RE3 (RAID1)
Display(s) Soyo 24", Gateway 22"
Case Fractal Design Arc Mini 6x120mm fans.
Power Supply Zalman 750w
Software Windows 7
The one you posted the picture of is an open frame psu with passive cooling = silent.
I have yet to find a sff psu with a quiet fan. The 1u supplies are even worse.
788 (0.14/day)
Seattle
Processor Intel Xeon x5660 (4.2ghz)
Motherboard Gigabyte X58A-UD3R
Cooling Corsair H100
Memory 24gb (6x 4gb DDR3 1600) Kingston Hyperx
Video Card(s) XFX Black r290x 4gb ddr5 OC
Storage 6x 2tb 64mb WD drives, Patriot Pyro sandforce2 drive ,intel 180gb ssd
Display(s) HP w2558hc
Case Corsair Carbine 500r
Audio Device(s) X-Fi Pro Fatality
Power Supply XFX 750 watt
Mouse Thermaltake Theron ee Sports+
Keyboard Corsair Vengence k70 RGB Cherry Red
Software Windows 8.1 x64
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
well the other thing was like i said in a post before i dont like mains 240v cables in my case.
2,555 (0.39/day)
Illinois
Software Windows 7
I know you had mentioned that. Were you pondering putting the open frame supply in the chassis? I figured you would mount it externally.
What's the 120w brick going to run you?
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
if i was going to use it i would have mounted it under the hard drive rack but im not sure if it would fit.
my other idea was to get a 400w 12v dc psu and run the graphics card and a pico psu for the motherboard
what do u mean?
2,555 (0.39/day)
Illinois
Software Windows 7
what do u mean?
What was the cost?
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
got a bit of an update i made a new front for case out of card board so i can use it as a template . so the lcd is mounted along with 2 usb ports underneath it and i still have to install the leds for the power supply status. ive decided to leave the stock buttons for now i probibly will change them eventualy.
i have found a strange problem when i turn on pci-e 2.0. i start getting random BSOD's when starting the computer. now i can only start the computer with it off and becasue i only have a pci-e 4x link it takes about 20fps off me in games.
i done a few measurements with a killawatt meter on the 2 power supplys and with a prime 95 + furmark load it was pulling 205w from the main psu and 83w from the external one. so it very close the max power of the internal 200w psu.
2,555 (0.39/day)
Illinois
Software Windows 7
http://i45.tinypic.com/24n4qi9.jpg
cardboard ftw.
Is their any wattage difference when you turn on 2.0?
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
cardboard ftw.
i havnt had a chance to check as it bsod's straight away. i removed four of my hard drives and unplugged anything not essential and it did the same. anyway i have bought a 9600gso for some cuda action and to lower the power consumption a little.
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
Got the 9600gso installed and it worked for a few days then the bsod's returned so ive took the card out and im going to get a new itx case that will take a micro atx psu for the phenom/mobo/hd4850. None of this dual psu hassle and put my intel atom board back in the 200w case.
smashed_99cbr
323 (0.05/day)
seems like a lot of work and a lot of trouble... not to mention silly... with no real benefits to speak of
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
1,146 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
the case that im looking at is this one
http://www.ksn-online.co.uk/product_info.php?products_id=7530
that case is smaller and will let me use a normal micro atx power supply that is much quieter and the 200w power supply is not powerfull enough for a decent gaming computer.
i seen 500w micro atx power supplys but they are too cheap to be any good. so i was thinking of getting this one
350w Be Quiet BN134 SFX microATX PSU
http://www.scan.co.uk/Products/350w-Be-Quiet-BN134-SFX-uATX-PSU
is there any more decent micro atx power supplys out there?
