- Apr 12, 2021
- 161 (0.12/day)
whats TIM?I have over 90C in Prime though I have crappy reused TIM even tho I have a custom loop on my Xeon...
Well that's the best the Rampage 3 Gene can do for now, with this 16 GB mix match 11-11-11-28 junk had to remove the 2 matching corsair XMP 1600 9-9-9-24 (2x4) gig sticks, tried doubling the ram clock on the northbridge clock crash, had to kick it down a notch, but its stable and actually runs this 750Ti nicely in doom and Fortnite, 108 fps in cinebench for a 750 is solid its going to have to settle for the GTX 1050 for now with the price of GPU's might take the RX 570 for a test run though building this one for my nephew to upgrade from his Dell OptiPlex 380 sff 771 bios mod X5650 Xenon I built him 5 years ago, getting the GTX 1050 out of that, it's a full size phoenix fan GPU I striped down to fit in the dell sff case along with his 500 Gb SSD he only plays Fortnite in performance mode but he wants to play COD war zone
did you try tightening the timings? try 8-9-9-24 then 8-9-8-24 then lower the RAS timing one at a time 24,23,22,21,20....Best I can get with the uncore being doubled of the ram this is with turbo enabled resulting 4.52ghz at vcore 1.336v, Qpi/Dram Core Volt =1.25v. I think the ram is possible holding me back as I can't get it to work correctly if I go to the next multi for faster ram the system would take about 2 reboots before posted but with this ram been selected below it don't do the weird reboots
