WX9100 Power mods - help w/ powerplay tables
40,435 (6.57/day)
Careful that mini-display port is extremely fragile. I thought I had artifacting but is was actually the dp cable needed a little support
You need a 90 degree cable
1,499 (0.29/day)
Azalea City
System Name Main
Processor Ryzen 5950x
Motherboard B550 PG Velocita
Cooling Water
Memory Ballistix
Video Card(s) RX 6900XT
Display(s) Samsung UE590
Case QUBE 500
Audio Device(s) Logitech Z623
Power Supply LEADEX V 1KW
Mouse Cooler Master MM710
Keyboard Huntsman Elite
Software 11 Pro
Sheesh it's already hot as hell in my office/lab with all these cards folding I bet it's already 90 degrees :D
40,435 (6.57/day)
Nah its 98 degrees lmao
conron
29 (0.07/day)
If any of y'all figure out how to make VR headsets actually work on this thing that would be amazing. I don't like being restricted to my old quest 1 with this headset
930 (0.29/day)
System Name The Banshee
Cooling CM Hyper 212 Plus
Memory 16GB 2x8 G.Skill Trident Z 3600 CL16 1.35V
Video Card(s) RTX 3060M 6GB @ 1750-2000MHz Core / 1875MHz Mem
Storage 1TB Kingston NV2 & 1TB Mass Storage HDD
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 10 Pro 64-Bit
I've never used vr so I have no idea. Can you not just connect the headset to a second gpu but run the game on the MI25?
Before I got my mini dp-hdmi adapter I ran my monitor off my GTX 1050 and used the MI25 for running the games.
1,499 (0.29/day)
Azalea City
System Name Main
Cooling Water
Memory Ballistix
Case QUBE 500
Software 11 Pro
Alright so I spent all week folding on the MI25 flashed to the WX9100. It's great, especially when tuned to like 100W.
But now my next question. Is it possible to flash this thing to a Vega Frontier and push the video through my 5600G igpu?
oneb1t
8 (0.02/day)
there is something which is holding this WX9100 back..
i experimented with mine and i think that because VRM temperature is not available GPU is throttling even that it is not needed
what i think is that we need to somehow flash bios from VEGA NANO which have the same VRM configuration
using pptables from other cards have minimal impact best way to increase score is to underclock it as much as possible
also if you set pptables like this:
it will have little better performance but no undervolt actually happen
also it will be nice to flash Radeon Pro SSG vbios which should be also compatible but with higher TDP and still working DP output
930 (0.29/day)
Mouse Evga Torq X3
Try a different bios, vrm sensors work fine on mine using this bios: https://www.techpowerup.com/vgabios/217771/217771
I found that increasing the freq in the lower power states and then setting an appropriate power limit to keep it in those lower power states seems to help a bit but I haven't done any back to back tests yet.
2,207 (0.86/day)
I have a spare Vega 56 Nano which I can do full experiments with no care if it blows-up as card has a small fault. But I need to complete lapping heatsink project first before I can do any risky experiments. Flashing hardware is easy as I use external programmer.
oneb1t
8 (0.02/day)
Thank you this bios is able to show vrm temp. I will try to do more testing tonight this card seems fun.
edit: ok so with this vbios i been able to use pptables for clock setup and sapphire trix for offset and maximum power (voltage with pptables does not work). With this combination on base cooler with 8cm fan i was able to run timespy @ 7 481
points
2,044 (1.10/day)
Olympia, WA
System Name Sleepy Painter
Processor AMD Ryzen 5 3600
Video Card(s) MSI RX580 8GB
Case NZXT Gamma Classic Black
Audio Device(s) Asus Xonar D1
Mouse Logitech MX518 Legend
Keyboard Red Dragon K552
points
What drivers and what version of TriXX? I wasn't able to get any software to control power limit or voltage other than a crapshoot w/ ppt editing.
I went ahead and flashed the latest vbios @DR4G00N posted, already. Haven't tried messing w/ PPTables again, yet; but, am very interested in what TriXX offers in its interface.
edit:
Trixx 6.8 on 23.4.1 using DR4G00N's vBIOS is working flawlessly!
I thought I'd 'tuned' my card best I could. Nope, between you 2, I'm already performing better, and it's 'taking' my PPTs now too.
Thank you both!
oneb1t
8 (0.02/day)
hey guys for inspiration this is now my contraption :-D
40,435 (6.57/day)
Another ghetto mod pic lol
2,044 (1.10/day)
Olympia, WA
Update:
NimeZ custom drivers will detect a Radeon PRO-modded MI25 as a Vega 64 Series card, and will restore Wattman compatibility.
In doing so, custom-set PPTs (using OverdriveN) *actually* work as expected, in addition to being able to control P-States, Voltages, Fanspeed, etc. in Wattman (Radeon Software "Performance->Tuning").
Thanks to @Zyll Goliat for the suggestion.
Note: My MI25-WX9100 was not stable on the NimeZ drivers *until* I used OverdriveN to set more-MI25-like voltage/clock states.
Working (not fully optimized) PPT for my card.
The MI25's 'factory' PPT
Edit (since I missed these tidbits, before):
It's only the 3rd time I've moved my PC and 7th or 8th 'connect/disconnect' cycle, already my mDP is feeling loosy-goosy. I think I'll go ahead and order some 90-degree adapters, rather than the short-straight Dell mDP-DP I'm using @TM.
930 (0.29/day)
Mouse Evga Torq X3
Yeah that works great so far on mine. Just had to load a custom ppt and it unlocked full clock & voltage controls in the control panel.
Undervolt is actually working, quickly tried at 1600 @ 1100mV just to check.
Fan curve works too which is great because the WX fan profile sees the gpu at just 40C and returns the fan back to idle after a few mins of use. :shadedshu:
1,499 (0.29/day)
Azalea City
System Name Main
Cooling Water
Memory Ballistix
Case QUBE 500
Software 11 Pro
Thanks I'll have to play around with that. Can power limit be increased over 50% like with the vega table mods?
40,435 (6.57/day)
Update:
Yup these cables today without thread lugs are abysmal (especially hdmi)
conron
29 (0.07/day)
Not sure how I never saw this reply lol
If the main monitor is run off of the MI25, flatscreen games ofc work fine, however, VR games will run off whatever gpu the headset is hooked up to. If I flip it around, it gives me a "VR headset must be connected to the same gpu as the main monitor error" (which doesnt occur if the MI25 is being used by the main monitor??)
I cant seem to find a way to have the VR run off the first gpu if the headset is plugged into the second one
also how did you go about using the MI25 to run games? did you have to change the setting in windows graphics settings for each and every app?
930 (0.29/day)
Mouse Evga Torq X3
I'm not sure, it just used it by default usually even when plugged into the 1050. I believe there was also a flag for steam games that let you select which gpu to use but I can't remember what it was.
conron
29 (0.07/day)
when its plugged into my second gpu, it chooses the second gpu by default and i can only use the mi25 if i go to windows settings
930 (0.29/day)
Mouse Evga Torq X3
latest drivers allow WX9100 to be controlled via watman with all voltages and everything :)
Does MSI Afterburner and the like work also? I'm using the Nimez 23.7.2 drivers atm for oc'ing but I'd rather use AMD's if possible.
2,044 (1.10/day)
Olympia, WA
What's the driver number exactly? Latest drivers wont even let me use wattman on my RX6600
I'm using 23.4.2, Amernime Zone Radeon Software on my 16GB Vega. I did not have wattman ability on any official driver.
conron
29 (0.07/day)
I'm using 23.4.2, Amernime Zone Radeon Software on my 16GB Vega. I did not have wattman ability on any official drivers
Thank you. If I ever manage to flash my second card correctly I'll make sure to use this
