System Name | Sleepy Painter |
Processor | AMD Ryzen 5 3600 |
Motherboard | Asus TuF Gaming X570-PLUS/WIFI |
Cooling | FSP Windale 6 - Passive |
Memory | 2x16GB F4-3600C16-16GVKC @ 16-19-21-36-58-1T |
Video Card(s) | MSI RX580 8GB |
Storage | 2x Samsung PM963 960GB nVME RAID0, Crucial BX500 1TB SATA, WD Blue 3D 2TB SATA |
Display(s) | Microboard 32" Curved 1080P 144hz VA w/ Freesync |
Case | NZXT Gamma Classic Black |
Audio Device(s) | Asus Xonar D1 |
Power Supply | Rosewill 1KW on 240V@60hz |
Mouse | Logitech MX518 Legend |
Keyboard | Red Dragon K552 |
Software | Windows 10 Enterprise 2019 LTSC 1809 17763.1757 |
Mine doesn't have any that I can hearHow do you guys deal with coil wine?
Isnt what decides how "clean" the power is, is the efficiency of the PSU? Or is that just PCMR snake oil?Mine doesn't have any that I can hear
(Note: I just had an ultrasound done, and could hear that)
Lexluthermeister has a guide on qwelling coil whine.
How to quickly & easily fix coil-whine(coil choke noise)
A forum user recently asked about Coil Whine, which is the noise a choke coil sometimes makes as it operates. This is almost always a video card problem, but can happen on any other computer or electronics components employing a choke in it's circuitry, including motherboards & power supplies...www.techpowerup.com
IIRC, Mussels has used Hot Glue as well for same. Hot glue has some 'dampening' properties; super glue is a more rigid bond.
Even, with the cleanest power, many cards still 'scream'
Yes/No.Isnt what decides how "clean" the power is, is the efficiency of the PSU? Or is that just PCMR snake oil?
Reason I bring that up is cause I have an EVGA 650W but it's only 80+ bronze
System Name | The Banshee |
Processor | Ryzen 5 5600 @ 4.65GHz CO -30 |
Motherboard | AsRock X370 Taichi |
Cooling | CM Hyper 212 Plus |
Memory | 16GB 2x8 G.Skill Trident Z 3600 CL16 1.35V |
Video Card(s) | RTX 3060M 6GB @ 1750-2000MHz Core / 1875MHz Mem |
Storage | 1TB Kingston NV2 & 1TB Mass Storage HDD |
Display(s) | LG 25UM57-P @ 75Hz OC |
Case | Fractal Design Arc XL |
Audio Device(s) | ATH-M20x |
Power Supply | Evga SuperNova 1300 G2 |
Mouse | Evga Torq X3 |
Keyboard | Thermaltake Challenger |
Software | Win 10 Pro 64-Bit |
That doesn't sound good, that's what my first one ended up doing when it died. I thought I damaged the interposer but maybe it was just bad luck instead.Oh boy this gpu is fun. Finally got the coil whine sorted out and now Im having a new fun issue. Im stuck with a perpetual Code 43 in windows. I've DDU multiple times, taken out my other gpu, reseated the GPU, REFLASHED THE BIOS, tried both official and unofficial drivers. Im lost as to what to do guys
I reseated it and it decided to unkill itself for now. Happy daysThat doesn't sound good, that's what my first one ended up doing when it died. I thought I damaged the interposer but maybe it was just bad luck instead.
I mean considering it barely makes a difference for 8GB Vega these 16GB ones certainly don't need it for games. Still useful if you're doing actual work on it though.The TLDR: Dont forget to turn off HBCC guys
It rekilled itself. It's not completely dead as it still outputs just fine. Im not sure what its doingThat doesn't sound good, that's what my first one ended up doing when it died. I thought I damaged the interposer but maybe it was just bad luck instead.
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
Tried driver removal and install? 43 is a hardware fault and that right there if drivers wont install or if the os freezes after driver install indicats you might need the board repaired by people at northridgefox or krisfix.de just to name 2If anyone ever has an idea as to what could be causing this Code 43 lmk. Again it outputs fine but no driver functionality whatsoever
Im not sure I wanna bother them with that lol. Not really sure what to do. Without drivers installed, I get that "POSTed driver is not the same as driver trying to load" error. With them installed, I get error 43. Full driver wipe, full vbios wipe. Oh manTried driver removal and install? 43 is a hardware fault and that right there if drivers wont install or if the os freezes after driver install indicats you might need the board repaired by people at northridgefox or krisfix.de just to name 2
Yeah it's probably done for, good thing they're cheap at least (IMO I'd just get a 1080 instead).Im not sure I wanna bother them with that lol. Not really sure what to do. Without drivers installed, I get that "POSTed driver is not the same as driver trying to load" error. With them installed, I get error 43. Full driver wipe, full vbios wipe. Oh man
I need something with 16gb of VRAM so that won't work. Of course it breaks RIGHT AFTER I got the VR set up working (literally what I bought it for)Yeah it's probably done for, good thing they're cheap at least (IMO I'd just get a 1080 instead).
I'm using the 11124 one, always worked fine so I never tried any others.Which VBIOS are yall using?
I am on the vBIOS that DR4G00N recommended. I've attached the vBios and exact ATItool version I've used for 2x successful MI25 conversions (both the 6+8pin and 8+8pin variants).I need something with 16gb of VRAM so that won't work. Of course it breaks RIGHT AFTER I got the VR set up working (literally what I bought it for)
Which VBIOS are yall using? View attachment 317495
(Also) as eidairman1 mentioned,Get amdvbflash 2.93
Then look for Version 4.68, underneath 4.68 you will see a link to show older version, click that and you should see version 2.93
Follow these steps carefully:
1. Open your "C:" drive in Windows, create a new folder, call it atiflash.
2. Extract the contents of atiflash_293.zip to the "C:\atiflash" folder
3. Find the bios file you downloaded and rename the bios file to 5 digits with .rom on end Example RX 580, change file to rx580.rom (r****.rom)
4. Move r****.rom to the "C:\atiflash" folder
5. Open the start menu, type cmd, when cmd.exe appears right click it and hit "Run as administrator"
6. At the command prompt type in cd\ and press enter until only C:\> is on the screen.
7. Type in cd/atiflash and press enter, you should see C:\atiflash>
8. Type in amdvbflash.exe -i to identify the gpu you want to flash with a 0, 1, or 2)
9. At the C:\atiflash> prompt type in
amdvbflash.exe -unlockrom 0
(there is a space between the e and -unlockrom and 0)(0 is the number zero)
press enter and you will be prompted that the "ROM Unlocked" (or 1, 2)
10. At the C:\atiflash> prompt type in
amdvbflash.exe -f -p 0 r****.rom
(there is a space between the .exe and -f, and a space between -f and -p and 0).
(Or 1, 2)
Press Enter
Follow directions on screen and if flash is successful exit the command prompt and restart, windows should show up on screen
(Just pulling and re-inserting the card, didn't seem to work.WARNING: This is against every 'good practice' I've ever learned
generally HARD power losses (of any cause) are unhealthy for components.
Thank you so much for putting this all together. I'll begin testing these different ideas tomorrow and let you all know thank you againI am on the vBIOS that DR4G00N recommended. I've attached the vBios and exact ATItool version I've used for 2x successful MI25 conversions (both the 6+8pin and 8+8pin variants).
I used eidairman1's guide (for Polaris, oddly) for the conversions.
Not sure if MI25's 'lock' like Polaris, but I elected to do the extra step.
The Code 43 usually indicates a hardware problem.
Neither MI25 I've played with has had even the slightest-detectable coil whine.
So, it's not impossible there *was* already something wrong with your example, or 'fixing it' caused the Code 43-related damage.
IIRC I *think* I've gotten a Code 43 when using a secondary card for video but had 'hard crashed' the MI25-WX9100 during tweaking and stability testing.
I believe this 'throws' the MI25-WX9100 into some non-UEFI compatible 'recovery mode' or something.
'talking out my arse but, I'm not the only one that's seen Vega(s) do this kinda thing.
In fact, one of the early-researcher/experimenters with the MI25 over @ Level1, strongly believes these cards are only RELIABLY flashable, using a clip-on programmer.
I've also had a Legitimate Vega 64 do very similar, appearing 'dead', and 'coming back' after a HARD power cycle:
The only way I've found to 'fix' was to cut all power to the system (flip PSU switch) while POSTing, wait a moment, then re-power (flip-on PSU) and re-boot the machine.
I'm guessing that a hard power loss immediately 'drains' any and all caps on the card, and triggers some kind of firmware-level 'reset' of sorts.)
Note: I've also had complications arise from 'hidden devices' in device manager.
DDU's supposed to clean them up but, IME it doesn't.
On the driver-side of things:
You're probably already trying these drivers:
select the 22.40 kernel MPT workaround during setup,
use the SDI (Snappy Driver Installer) instead of the other options
I know it is even more money down the drain but,
you could pick up another MI25 for ~$50, and resell your Code 43 as For Parts for $20+ probably.
That's because with lower voltage it has more power budget available and so it will boost higher until it reaches the power limit again.However, even if the voltage is lowered, the heat will hardly change.
I see. thankyou for the explanation.That's because with lower voltage it has more power budget available and so it will boost higher until it reaches the power limit again.
It will still run at 170W, only with a higher frequency.
You need to rethink your fan shroud, it's simply not getting enough airflow directed through the heatsink. If you were to extend that plexi shroud along the full length of the card and do away with the tape it would probably work better. Basically, for fans right angles and restrictions/reductions are the enemy to airflow so the less of those you have the better.I see. thankyou for the explanation.
Is there a way to disable or suppress that "boost"?
My aim is to make this MI25/WX9100 have a performance/heat ratio like my vega56 reference model.
Is it not possible?
Currently, in my opinion, this MI25/WX9100 is too hot.
I loaded my vega56's pptable and tried running mi2/wx9100 with the power limit set to -10%.
It's still hot.
If "boost" is controlled by hardware (e.g. FPGA M2S010 near the 25P80), there's nothing I can do about it.
