toshiaki_12
- Mar 10, 2024
- 6 (0.10/day)
You need to rethink your fan shroud, it's simply not getting enough airflow directed through the heatsink. If you were to extend that plexi shroud along the full length of the card and do away with the tape it would probably work better. Basically, for fans right angles and restrictions/reductions are the enemy to airflow so the less of those you have the better.
This is how I have mine set up currently; Just a hole cut into the shroud and a piece of cardboard as an air dam to help guide the air.
View attachment 339991View attachment 339989
Here's how it performs @ 220W without an undervolt (thanks to AMD's janky software I accidentally removed the undervolt while setting the fan speed higher).
Certainly hot, but that's totally normal for Vega. I normally run at 170W undervolted which makes it settle around 75-80C with the fan only at 2000 RPM.
I also suggest using the WX 9100 or Vega FE PPTables so the HBM runs at 945MHz, the Vega 56/64 tables make it stay at or strongly favor 800MHz.
220w! It's amazing.
thank you very much.
I will try various things.
Ah, I think this is probably due to hot spot temperature.
I searched and found some information about it. Old posts about radeon vega hot spot temperature.
It seems that for some reason the hot spot temperature of some Radeon Vega can reach 105 degrees.
Does it depend on how you apply the grease or the gap between the heat sink and the chip?
I can't figure it out.
(I applied ZM-STC8 a little thicker. 8.3W/mK)
I rebuilt the shroud, but the temperature did not improve.
I had the fan running at 4500rpm+ and thought the exhaust power was sufficient, but the hot spot temperature reached 105 degrees.
Sorry for the many images.
That's to show vbios version etc.
wattman was also revived by whql-amd-software-adrenalin-edition-24.3.1-win10-win11-mar20-vega-polaris, "disableworkstation 1", and pptable.
