Advice for 32gb 3600 kit
75 (0.05/day)
Italy
Processor AMD Ryzen 7 5800x
Motherboard Asus ROG B550 Strix E
Cooling Artic Cooling Liquid Freezer II 360 + 3x Noctua NF-A12x25 PWM
Memory Corsair Vengeance LPX 3200 MHz 2x16GB
Video Card(s) Asus ROG STRIX GTX 1080 Ti GAMING
Storage Samsung 970 EVO Plus 512GB + Samsung 860 QVO 4TB
Display(s) BenQ PD2500Q
Case Be Quiet Silent Base 802
Power Supply Seasonic Prime Ultra Titanium 650w
If you dont want RGB and BIOS has the option to disable them then its the optimal way to do it. I have my share (and others too) of bad luck with this kind of software that must run all times to control RGB, even to keep them off. I have board RGB disabled by BIOS. I dont have RAM sticks with lights so I dont really know whats what there. My GPU also has a MSI dragon logo. I did install MSI's DragonCenter but quicly disable it because it kept messing with GPU drivers for my custom settings and also was keeping CPU from entering idle/low power stages. So I left the GPU logo on.
I read that Gskill RGB should be compatible with asus aura and other vendor RGB systems. For this reason turning off RGB in the bios for the motherboard should turn off the RGB for ram too.
Adhyaksa17 kindly confirmed that for asus. I hope it's the same with other brands.
About the MSI graphic card you can disable led by disconnecting their plug. If you look the PCB you should find a 4 wire connector which is for the gpu fans and 1 or more 2 pin connector for RGB. I detatched them as I hate rgb and I hate even more the messy blotware that cames with rgb and motherboard
tabascosauz
8,023 (2.37/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
That's patently false. Disabling Aura in Asus BIOS has no effect on the RGB Tridents. If you want to control them beyond their default dynamic RGB scheme, you need to use G.skill's utility or another like OpenRGB. Even so, the sticks revert to default on every boot until you login to Windows and your service/application of choice starts.
Maybe if you use Aura software and control them Windows. The BIOS dropdown certainly doesn't work for RAM, and that's why otherwise excellent Trident RGB is so frustrating. B550M TUF Plus here.
If you use Windows fast startup (essentially only ever hibernating and never shutting down) or only sleeping your computer, I can see the RGB control persisting. Otherwise, resets on a proper reboot. In any case, never properly rebooting is a terrible practice when you're overclocking or troubleshooting/testing DRAM.
Furthermore, Asus BIOS Aura control doesn't control shit aside from on/off. If you want to do anything with your RGBs if has to be done through Aura software. This isn't Gigabyte, where you can control your RGBs without bloatware. Even if you choose to use OpenRGB, it still only takes effect at login.
And I don't know who it was that suggested the -GTZNC RGB kit could do 3600 16-18-18. It's CJR or DJR and most definitely cannot, because CJR does not scale below 19 on tRCD/tRP at 3600+, period. At safe daily voltages for CJR, at least (1.45V).
31 (0.02/day)
Indonesia
System Name ADHYAKSA-PC
Processor Ryzen 3 3300X @4.3Ghz 1.256v
Motherboard Asus TUF B450M-Plus Gaming
Cooling ID-Cooling Frostflow X 360mm with Noctua IPPC 3000rpm fan
Memory Trident Z RGB 4000Mhz CL17-18-18-38 1.4v @3800 CL16-16-16-32 1T 1.4v or @3800 CL14-15-12-21 1T 1.48v
Video Card(s) ASUS GeForce GTX 1650 Super TUF Gaming OC, extreme under volt @1.4Ghz 0.7v Memory 14Gbps OC
Storage Adata SX8200 Pro 512GB, WD Blue 2TB HDD
Display(s) Asus VG249Q, HP 24MH
Case Cooler Master Masterbox MB530P
Audio Device(s) Logitech z313, Headset Logitech G633s
Power Supply Cooler Master MWE 650W V2 80+ Bronze
Mouse Logitech G Pro Gaming Mouse
Keyboard Logitech G Pro Gaming Keyboard
Software Windows 10 Pro 64bit (v2004)
I have been installed the armoury crate with aura sync before to control my tridentZ rgb. Then, I turn off my rgb by bios and all of them are turn off. I don't know if the scene you don't installed armoury crate before it will turn off or not. Still, when I truned off my rgb by bios, all CPU usage which control the rgb to be 0%, so this is fine, your pc performance doesn't decrease because of rgb software
65 (0.04/day)
System Name Editing Build
Processor Ryzen 9 3900x
Motherboard MSI X470 Gaming Plus Max
Cooling Noctua D15S
Memory G.Skill Trident Z RGB 2x16GB 3200C14 @ 3733mhz 16-15-15-30
Video Card(s) Evga 2060 Super
Storage Crucial 500 Nvme + 500 HDD
Display(s) 24" 1080p Dell
Case Lian Li Lancool II
Power Supply 750w
Software Rendering and Structural Analysis
Benchmark Scores CB R20=8014 CB R15=3581
Hi, for Hynix C/DJR, the trick to run at 3600 or above changes your tRRDC and tRTP in-range value of 20-21. This IC isn't scaling with voltage. Try it with loose tRRDC or tRTP
Hi, I didn't notice your reply to this. What do you mean tRRDC/tRTP? Do you mean tRCDRD and tRP?
This is my current settings. What do you think I'm missing if you think I can boot CL14?
31 (0.02/day)
Indonesia
Oh, I'm sorry, I forgot that tRCD has 2 value for AMD. Yes, I mean tRCDRD and tRP. Change the value around 20-21, because the value is not scaling with voltage. If you still can't boot, then stay with cl16 but tweak again your sub timing. How about set the GDM to enable? maybe you can boot with cl14 if GDM is enable
Hmm, your kits are a dual rank, right? I don't think that a dual rank hynix can do cl14. So, maybe you keep the setting but tweak your sub timing
You can change the value:
tRCDWR --> 8
tRRDS --> 4
tRRDL --> 6
tWR --> 12 or 14 or 16
tCWL --> 12 or 14
tWRRD --> 3 optimal for dual rank
If you have been stable with the secondary timing, go back to the tRAS and tRC
tRAS maybe you can change around 28-32 and tRC around 50-54
Or maybe you can try to 3800mhz, this article maybe can help you. Hynix DJR need changing the value of tRCDRD [21] tRC [58] @ 3800Mhz
3,424 (1.85/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 80C temp limit, CO -8~12
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (366W current) PowerLimit, 1060mV, Adrenalin v24.8.1
Case None... naked on desk
Power Supply Corsair HX750i, 80+ Platinum, 93% (250~700W), modular, single/dual rail (switch)
Software Windows 11 Home 64bit (v23H2, OSBuild 22631.4169), upgraded from Win10 to Win11 on Feb 2024
I would also skip the CL14 idea.
And probably wouldn’t try something below 17 for the rest for speeds more than 3600 and close to 3800.
examples:
16-17-17-17-34-51
16-17-17-17-36-53
16-18-18-18-36-54
16-18-18-18-38-56
Also tFAW should be x4~6 of tRRDS
If
tRRDS: 5
tFAW: 20/25/30
31 (0.02/day)
Indonesia
examples:
16-17-17-17-34-51
16-17-17-17-36-53
16-18-18-18-36-54
16-18-18-18-38-56
If
tRRDS: 5
tFAW: 20/25/30
I don't think that Hynix CJD or DJR dan stable with tRCDRD or tRP under 19. The chip is not rated the tRCDRD or tRP under 19 @3600mhz or above
65 (0.04/day)
Cooling Noctua D15S
Power Supply 750w
tRCDWR --> 8
tRRDS --> 4
tRRDL --> 6
tCWL --> 12 or 14
Thanks.
Yes this is dual rank.
I can actually boot 3800mhz but not with fclk 1900. Maybe my CPU can't or Mobo
I tried also GDM off and even at loose timings like 16-21-21-21-42 for CL14 but cant boot.
RCDWR --> 8 (I will try this)
tRRDS/tRRDL --> 4-6 (5-5) actually give me better result than 4-6 or 4-5
tWR --> 12 or 14 or 16 (can do until 14 but 18 give me better bandwidth)
tCWL --> 12 or 14 (my bios doesn't not allow me to put 14, don't know why, It keeps coming back to 16)
tWRRD --> 3 optimal for dual rank (I will try this)
examples:
16-17-17-17-34-51
16-17-17-17-36-53
16-18-18-18-36-54
16-18-18-18-38-56
If
tRRDS: 5
tFAW: 20/25/30
Thanks.
16-17-17-17-34-51 (tried and can boot but not stable even at higher voltage)
16-17-17-17-36-53 same above
16-18-18-18-36-54 same above
16-18-18-18-38-56 same above
I'm familiar with x4~6 of tRRDS, but at x4, I lose bandwidth while same latency.
Tried 16, 20, 24, 30. I prefer even numbers and 24 gives me better bandwith.
It does not actually necessary to be exact multiple as long as within x4-6 range.
31 (0.02/day)
Indonesia
Thanks.
Thanks.
Yeah, you know well your memory. It is a massive copy bandwidth with 3733cl16. Since it is dual rank, the latency slightly worse, maybe you will get about 64 ns with a single rank
I think you got your limit at your memory and me too haha
Maybe we must buy a kits memory again to OC other memories, especially with other IC like micron rev E maybe or J-die :v
65 (0.04/day)
Cooling Noctua D15S
Power Supply 750w
I guess so its alread at limit.
I retry again all your recommendation and Zach_01. So far no gains
You're one already so fast :). I'm planning now to buy same your kit timing but at 32GB Dual.
31 (0.02/day)
Indonesia
View attachment 172716View attachment 172717
Yeah, hope you get a good IC and PCB. Some articles say that 4 x SR (single rank) is better than 2 x DR (dual rank). So, if you wanna buy, maybe better to pick 4x8gb kit, but it is just an article said, I don't know the truth. Still IC and PCB are a lottery, good luck.
65 (0.04/day)
Cooling Noctua D15S
Power Supply 750w
I'm aiming for future 64GB when I upgrade for mobo that's why I need 16gb/kit. For now just using for hobby not real work.
Just waiting for better time like MaurizioC
Your right still lottery plays :) .
75 (0.05/day)
Italy
I registered on gskill fourm and after searching I have read that now the only way to control RGB is by windows software. So all rgb stick are not existing anymore for me
65 (0.04/day)
Cooling Noctua D15S
Power Supply 750w
You can still grab some non-RGB G.Skill with 3200 14-14-14-34 or 4000mhz 17-18-18-38, it will perform almost same i think.
3200mhz 14-14-14-34
4000mhz 17-18-18-38
31 (0.02/day)
Indonesia
3200mhz 14-14-14-34
4000mhz 17-18-18-38
Yes, maybe they have almost a same performance if the IC and PCB are the same
Hi, I have an issue with thaiphoon burner when detected my kits. Previously, thaiphoon detect my module is A1 10 layer. However, If I check manually, my stick have a A2 PCB not A1 like the thaiphoon burner said. Maybe you can check manually if you wanna buy a kits. Thaiphoon burner is not 100% true.
Some articles say that A1 or A2 are not difference if you running under 4000mhz, but if you want to run 4000Mhz or above, A2 is better
75 (0.05/day)
Italy
I would like a kit running at 3600 with low timings + 1T + dual rank
F4-3600C16D-32GVKC would be fine but it's slower than the crucial and appears to BE 2T
The 4000 kit is not available yet in Italy but I believe it will cost double the 3600..
31 (0.02/day)
Indonesia
Nope, I think F4-3600C16D-32GVKC is pretty good choice. Good luck, hope you get a good IC and PCB
65 (0.04/day)
Cooling Noctua D15S
Power Supply 750w
This is what I'm using.
Which is Disabled GDM at 1T.
75 (0.05/day)
Italy
65 (0.04/day)
Cooling Noctua D15S
Power Supply 750w
Here are some statistics from excel I seen somewhere but forgot where, I just copied the sheet.
I filter for you only 2x16 GB Dual Rank.
Gear Down Mode, some rams can hardly disabled GDM especially in tighter timings.
Sometimes required higher vDram/procODT/CadBus or trade some timings.
By disabling GDM you can gain instant 0.5 less latency.
I traded my GDM disabled by increasing tRP +1 while no additional voltage/procODT/Cadbus .
75 (0.05/day)
Italy
I checked and I have GDM enabled. Can I try disabled it? Shall I raise voltage to do so?
Can you link that excel for me to study?
65 (0.04/day)
Cooling Noctua D15S
Power Supply 750w
When you disable, try not to raise anything and check if it boots and stable.
Otherwise add some procODT/CadBus(60-20-24-24) or Dram voltage.
someone share this, forgot who. Edit: I rembered it was examen1996
this one forgot also where I collected from.
75 (0.05/day)
Italy
