How many are using 24h2? Problems still?
Did you update to 24h2? How did it go?
  • Total voters
    50
  • Poll closed .
29,632 (6.94/day)
Below is the comparison between Windows 10 22h2 vs Windows 11 24h2. Same environment, same settings, same drivers. Bloatware removed.
VIDEOS
Can't figure this one out. For me is just Windows 11 which has this BUG with frame-times.
This might deserve it's own thread, but I'm thinking it more a driver issue than a Windows version issue.
2,609 (0.53/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Case Corsair 275R
Mouse Logitech G Pro (Hero)
Article date: October 24, 2021
We are almost in 2025 - those tests are obsolete now because many updates have been released.
Also those are only on Intel CPU's. For Intel the difference in performance is not significant, for Ryzen is a different story.
In 2021, 11 was reportedly broken for Ryzen. 21H2 required multiple updates for the Ryzen issue to get solved, so I didn't upgrade to 11 until April, 2022.
1,024 (1.39/day)
Processor 14700KF/12100
Motherboard Gigabyte B760 Aorus Elite Ax DDR5
Cooling ARCTIC Liquid Freezer II 240 + P12 Max Fans
Memory 32GB Kingston Fury Beast @ 6000
Video Card(s) Asus Tuf 4090 24GB
Storage 4TB sn850x, 2TB sn850x, 2TB Netac Nv7000 + 2TB p5 plus, 4TB MX500 * 2 = 18TB. Plus dvd burner.
Display(s) Dell 23.5" 1440P IPS panel
Case Lian Li LANCOOL II MESH Performance Mid-Tower
Audio Device(s) Logitech Z623
Power Supply Gigabyte ud850gm pg5
Keyboard msi gk30
No... not yet. It wasn't available the last time I checked and since I'm on intel I have less to gain, and I'm kind of hesitant to be making changes with all the damn issues some of my hardware has ( like the 14700kf... is it safe long term... who knows?) Had to turn off c-state 8 and 10 to get my computer to not reset on idle and light load, and I've met quite a few other people with the same issue on other gigabyte boards (I'm talking dozens of people, its a big issue, its not like the psu or the ram or anything trust me), and its happened all up and down the lineup. High end boards. Low end boards. And everything in between. I am hoping its a bios problem but the longer it lingers the more I start to wonder if gigabyte cut some corner they shouldn't have, and now they have trouble delivering low voltages consistently. So I gotta stay at .7 rather than .2. wish there was a middle option or something. And yeah I sent a perfectly fine cpu in for rma thanks to gigabyte, but my fault too for jumping to conclusions. Though to give gigabyte some credit, when I asked for the beta bios taken off their website, they did end up giving it to me, but for some reason, vid limits dont work with it, probably bios and intel firmware not playing nice or something.
Anyway, all that to say, this whole headache came after the 0x12b update so I'm not exactly in the mood for fixing things that aint broke right now.
8,286 (1.30/day)
Mouse Logitech G604s
I think I can honestly say that Ive never really had any issues with anything breaking. Ive been using Win11 since it dropped.
595 (0.47/day)
Processor Ryzen 7 9700x
Motherboard Asrock B650E PG Riptide WiFi
Cooling Underfloor CPU cooling
Memory 2x32GB 6200MT/s
Video Card(s) ASUS Prime Radeon RX 9070 XT OC Edition
Storage Kingston Fury Renegade 1TB, Seagate Exos 12TB
Display(s) MSI Optix MAG301RF 2560x1080@200Hz
Case Phanteks Enthoo Pro
Power Supply NZXT C850 850W Gold
Mouse Bloody W95 Max Naraka
Look at my Windows 11 issue here... this is something unexplainable for me, same drivers, same settings, bloatware removed, all chipset drivers up-to date and drivers in general, bloatware removed.
This is micro-stuttering in CS2 on Windows 11 24h2. On Windows 10 22h2 everything is smooth...
It may be a problem with the sound driver, you can try reinstalling it.
Otherwise you can try a profile like this.
If you have MSI Afterburner, clock your card, close it and with CapFrameX make a recording to check if there is the same problem, the check interval of both programs should be 1000 ms or more.
51 (0.63/day)
System Name Dell Precision 3420
Processor Xeon E3-1245 v6
Motherboard Dell 02K9CR
Cooling NF-A8 + OEM CPU Heatsink/Fan
Memory 32GB
Video Card(s) Quadro P620
Storage 2TB Nvme + 2TB SSD
Case SFF
Audio Device(s) Sound Blaster Play! 4
Mouse Dell Silent Mouse
Keyboard Dell Silent keyboard
Sharing small update with my experience on 24H2. Over the holiday I did several different things to machine and had some unfavorable moments afterwards. I put in a new gpu with latest driver from last month. Could it be a gpu issue? Sometimes the monitor won't get the signal upon booting or waking from sleeping or screen off. I have not pin pointed what is causing it yet. I also connected a new wireless card usb briefly when I got back, it didn't do anything, so removed it and left my other one in that did work but I could not properly connect to my wifi and have internet anymore. sfc /scannow didn't resolve it. Ended up installing latest driver from manufacturer, restarted and it fixed it, but that was never a problem before... Generic always worked before. Dunno what the issue was. The delay between disabling and enabling wifi before the fix was abnormally long and buggy. Did inserting that other one mess with the existing one? I never experienced that before, but my biggest gripe is the display signal not returning back despite using mouse and keyboard to bring back activity to wake up leaving me to force a shutdown with power button -__- Everything else seems okay for now
595 (0.47/day)
67 (0.80/day)
You can use LatencyMon to check.
This Windows 11 mate...
"Also WhySoSlow and LatencyMon have trouble running on Windows 11 2024H2 edition. After starting the program, the main application window never shows up. A temporary fix has been published which will remain available until the next versions will be released. "
This is from LatencyMon site. Windows 11 is just such a mess... But i will try.
Robn2dogs
15 (0.02/day)
Why is the update for Win11 from Win10 on my machine 23H2 and not 24H2?
2,166 (0.33/day)
Metro Manila, Philippines
System Name Zangief (Reborn) 2.0 AM4 not dead yet!
Processor AMD Ryzen R7 5700X3D (tweaked PBO)
Motherboard Gigabyte GA-AX370 Gaming K7 Rev 1.0 BIOS F53d
Cooling Noctua NH-D15 Push / Push Config | 2x ML120 | 2x Phanteks 120 mm
Memory 2x16GB G.Skill Trident Z Neo RGB @ 3600mhz CL 18 -> running 3800mhz @ 1.37v
Video Card(s) Asus RTX 3080 Rog Strix Gaming OC
Storage 250 GB Samsung Evo 850 / 1tb WD Black / 4tb WD Blue / 512GB Adata XPG Pro SX8200
Display(s) Acer Predator XB271HU |Asus VX239H 23" AH-IPS Led
Case Phanteks Enthoo Pro M TG
Audio Device(s) On Board Realtek HD | Steelseries Arctis Nova Pro Wireless
Power Supply Seasonic Focus GX V4 850 Watts ATX 3.1
Mouse Logitech G903
Keyboard AKKO 5098N (Otemu Cocoa Brown Lubed) | Tecware Spectre 96 (Akko Lavander Purple V3 lubed)
Software Windows 11 Pro 24H2
Got updated to it after I swapped out from a 1700x to 5700x3d over the weekend. So far haven't noticed anything and working fine on my end.
Shuttlepro83
18 (0.25/day)
I've been working with computers three decades and I can wholeheartedly confirm that while 24H2 IS manageable, it is by far the buggiest microsoft OS since Vista, 8, and Millenium. It depends on what you are doing with it, it can be set just right to be workable, but little things have been creeping out. The cpuz blue screen hard error, alot more restarts, higher latency moments, framerate/frametime drops, etc.
Knowing what I know now, I'd prefer 23H2. I have that on my laptop it is smooth and works GREAT. 24H2 has potential but it is NOT there yet. I would revert back to 23H2 if I were you all and I may do so myself.
51 (0.63/day)
Memory 32GB
Case SFF
You most likely have to go to https://www.microsoft.com/en-us/software-download/windows11 to get it. I've only seen it in windows update via newer machines. There are many different reasons why it won't be offered through windows update. Just remember it will wipe everything installing with usb.. so back up everything you care about to an external drive or stay on 23H2 for now.
595 (0.47/day)
Yes, I read it, but do you have a problem running it?
It probably depends on the old software library that was removed in the clean install of Win 11 24H2.
I ask because I have no problem running it, so you can try.
123 (0.02/day)
southern ontario
System Name AboutTime
Processor AMD 9800X3d
Motherboard AS Rock Taiichi Lite X870E
Cooling Be Quiet 360mm Light Loop.
Memory TeamGroup T-FORCE DELTA RGB 32GB (2x16GB) DDR5 6400MHz
Video Card(s) PNY GeForce RTX 4070 Ti Super 16GB OC TF GDDR6X
Storage Crucial T700 NvMe 4 TB
Display(s) 24" Benq FP241W
Case Be Quiet Shadow Base 800 FX
Audio Device(s) On board audio. Speakers Edifier R200DB
Power Supply FSP Hydro Ti pro 1000 watt
Mouse Corsair M65 pro
Keyboard SteelSeries Apex 3
Software W11 64 bit Pro
I didn't do a update but a clean install. So far so good Found it a bit confusing for finding some of the settings but google helped a lot Now I'm much better with it after a few days The only issue i seem to be having is with Bluetooth. It doesn't seem to want to connect to my phone but other then that It works well enough. BTW I'm using windows 11 24H2 .
67 (0.80/day)
Thank you! So i'm not the only one observing these things.
Examples here in CS2 - micro-stutters / mini-freezes while playing... not happening in Windows 10 22h2:
VIDEOS
2,609 (0.53/day)
System Name KHR-1
Case Corsair 275R
Upgrade installs are more likely to have bizarre slowness, even when this does not always occur. (When not doing a clean install)
For people with 23H2 doing upgrade installs to 24H2, with dedicated graphics especially, that issue is the most likely to occur. Problems are the most likely to occur with AMD graphics users using Adrenalin or Pro graphics software. Including, but not limited to abnormal slowness
I still have 23H2 on my daily-driver.
67 (0.80/day)
Found this channel - looks legit. Also it confirms my suspicions. Windows 11 24h2 has stuttering / frame-time issues, at least on Ryzen CPU's.
Note the 1% and 0.1% lows in 24h2.
Screenshot from CS2 which again confirms that the game runs like shit on 24H2:
2,609 (0.53/day)
System Name KHR-1
Case Corsair 275R
For Cyberpunk 2077, I see GPU and CPU under-utilization. Something's wrong, looks like it's throttling on 11 24H2 when it's not on 10 22H2!
(But not thermal-throttling)
If this is happening with Vermeer, then I would be worried even more! Then it may be like the very-early 11 21H2 days all over again!
Looks like a bug fix needed.
11,049 (1.75/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
this is on all CPUs -- I lost massive amounts of performance on my 13700K as well. Also POE2 will randomly crash on loading screens unless it's set to Realtime Priority with SMT disabled. 24h2 is an actual nightmare.
2,609 (0.53/day)
System Name KHR-1
Case Corsair 275R
Sounds like a broken scheduler.
Don't like 11? Then you must use a group policy, if you have Pro or Enterprise to stay on 10. You also must use a group policy, to stay with 23H2 on 11.
29,632 (6.94/day)
Those are interesting results. We can't know the Windows config that tester is using. However there is an much interesting aspect to consider. What you glossed over was that in the second half of that very same video the tester does what they called "Real World Scenario" runs and what do you know? Little to no difference whatsoever..
As I've said before, context is important. Unless we know the configurations used in each example, a meritful conclusion can not be made.
What do you mean?
No it isn't. I install 24H2 daily on systems I build and there are no issues at all. If you're having the problems you just stated you should try a fresh install. The update for 24H2 is known to have issues. A fresh install is known to be problem free.
11,049 (1.75/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
What do you mean?
No it isn't. I install 24H2 daily on system I build and there are no issues at all. If you're having the problems you just stated you should try a fresh install. The update for 24H2 is known to have issues. A fresh install is known to be problem free.
I just did a fresh install on both machines, and yes - raptor lake, alder lake lose massively in the lows compared to 10 and early W11. High power plan and locked cores... Try it for yourself. Bench an early version of 11 or 10 vs 24h2 and see for yourself if you don't believe the countless posts on the internet.
2,609 (0.53/day)
System Name KHR-1
Case Corsair 275R
What do you mean?
Yes, there's a group policy option to disable updating to 24H2 on 11 and likely update to 11 from 10. Windows could update to 24H2 without warning, especially on 11. Also nags on 10.
