- Jul 25, 2006
- 14,208 (2.05/day)
- Nebraska, USA
System Name | Brightworks Systems BWS-6 E-IV |
Processor | Intel Core i5-6600 @ 3.9GHz |
Motherboard | Gigabyte GA-Z170-HD3 Rev 1.0 |
Cooling | Quality Fractal Design Define R4 case, 2 x FD 140mm fans, CM Hyper 212 EVO HSF |
Memory | 32GB (4 x 8GB) DDR4 3000 Corsair Vengeance |
Video Card(s) | EVGA GEForce GTX 1050Ti 4Gb GDDR5 |
Storage | Samsung 850 Pro 256GB SSD, Samsung 860 Evo 500GB SSD |
Display(s) | Samsung S24E650BW LED x 2 |
Case | Fractal Design Define R4 |
Power Supply | EVGA Supernova 550W G2 Gold |
Mouse | Logitech M190 |
Keyboard | Microsoft Wireless Comfort 5050 |
Software | W10 Pro 64-bit |
This is true. Plus, printers just are not critical enough to have on the battery side. Most bigger UPS have outlets that are not supported by the battery - it is fine to put an ink jet printer there. Never a laser because the power required to heat up the fuser (heating element) is too high.I believe you should not have a printer on a ups or at least a laser one.
30 minutes? No way! And frankly, if the playstation and the computer just happen to be maxing out demands at the same time, it could be too much for the UPS.Playstation 5, 55" OLED tv, 6700 XT computer, all plugged in to it and running at the same time, both the console and pc playing a game?
I would get a separate UPS for the TV. If you have a cable box and DVD/Blu-ray player too, they can go on the UPS with the TV.
It is important to remember the primary purpose for a good UPS is the AVR - automatic voltage regulation. It is this feature that protects your connected components from surges and spikes, as well as from low voltage events like dips (opposite of spikes), sags (opposite of surges) or brownouts (long duration sags).
Note that surge and spike protectors do absolutely nothing for dips, sags or brownouts. And for excessive surges and spikes, they simply cut power (“IF” working properly), crashing your computer - never good. And of course, surge and spike protectors wear out. This is why it is recommended surge and spike protectors be replaced every 2 years. If worn out or damaged, they typically provide little to no protection at all.
The battery backup feature of a good UPS is just a minor bonus feature.
Also, a UPS should not be used so you can keep playing your game if the power goes out. The purpose of the UPS is to provide enough battery run time so you "gracefully" save your work, exit your running programs, shutdown Windows, then power off your equipment until power is restored.
Also, don't forget that destructive anomalies don't have to originate on the "grid". A malfunctioning high wattage appliance, or damaged 1500W $15 hair dryer from foreign lands can introduce damaging surges or spikes on the circuit too. Point being, don't assume a stable power grid negates the need for a good UPS with AVR. It doesn't.
