Advice for 32gb 3600 kit
75 (0.05/day)
Italy
Processor AMD Ryzen 7 5800x
Motherboard Asus ROG B550 Strix E
Cooling Artic Cooling Liquid Freezer II 360 + 3x Noctua NF-A12x25 PWM
Memory Corsair Vengeance LPX 3200 MHz 2x16GB
Video Card(s) Asus ROG STRIX GTX 1080 Ti GAMING
Storage Samsung 970 EVO Plus 512GB + Samsung 860 QVO 4TB
Display(s) BenQ PD2500Q
Case Be Quiet Silent Base 802
Power Supply Seasonic Prime Ultra Titanium 650w
Optimal for 3200c16 loose timing although 1.4v isn't it's rated for 1.35v
I did not get that.. shall i set slower timings? what value should I put as FLCK? Half the ram frequency?
3600 C16 or 3200 C14 are best for Ryzen.
Thank you but why 4x8 gb and not the 16x2 gbkit?
9,340 (5.15/day)
Louisiana
Keyboard G710+x3
No 3200c16 is so limited it is what it is even if it's b-die it's a very poor bin and probably being read wrong
If you get the 3600c16 either 4x8gb kit or 2x16gb kit those timings would be 16-16-16-36 typical of good bin samsung b-die.
B-Die Finder
75 (0.05/day)
Italy
what about those?
Crucial Ballistix BL2K16G36C16U4B 16-18-18-38 3600 @1,35 volt those are cheaper than gskill.
What about flck? Should it be half the ram speed?
9,340 (5.15/day)
Louisiana
Keyboard G710+x3
what about those?
Loose but says amd compatible
65 (0.04/day)
System Name Editing Build
Processor Ryzen 9 3900x
Motherboard MSI X470 Gaming Plus Max
Cooling Noctua D15S
Memory G.Skill Trident Z RGB 2x16GB 3200C14 @ 3733mhz 16-15-15-30
Video Card(s) Evga 2060 Super
Storage Crucial 500 Nvme + 500 HDD
Display(s) 24" 1080p Dell
Case Lian Li Lancool II
Power Supply 750w
Software Rendering and Structural Analysis
Benchmark Scores CB R20=8014 CB R15=3581
I have same ram Ripjaws F4-3600C16D-32GVKC.
Stable. Have run also Aida64 for almost 3 hours and 37 cycle in Memtest64.
I'm currently running at 3733mhz @1.37v due to my cpu can't boot fclk 1900.
Others in newegg review easily running 3800 16-19-19-38.
Pretty cheap: https://www.newegg.com/global/qa-en/g-skill-32gb-288-pin-ddr4-sdram/p/N82E16820232907?Description=gvkc 32gb&cm_re=gvkc_32gb-_-20-232-907-_-Product
3,789 (1.91/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 200W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.3037), upgraded from Win10 to Win11 on Jan 2024
I set dram voltage at 1.4, left docp and tried setting 3600, 3400, 3333 and 3266. The latest is the only value the boots.
Not sure this is optimal...
Do you have a screenshot of ZenTimings when you booted on 3266?
75 (0.05/day)
Italy
no what you want to check?
834 (0.45/day)
Maryland, USA
Processor Ryzen 5 5600X
Motherboard MSI MPG X570S Carbon Max Wifi
Cooling CPU: bequiet! Dark Rock 4. Case fans: 2x bequiet Silent Wings 3 140s, 2x Silent Wings 3 120s
Memory 2 x 8 GB Patriot Viper Steel DDR4-4400 C19
Video Card(s) Sapphire NITRO+ RX 5700 XT
Storage 2TB Mushkin Pilot-E M.2, 1 TB SK Hynix P31 M.2, 1 TB Inland Professional, 500 GB Samsung 860 Evo
Display(s) MSI Optix MAG271CQR 1440p 144Hz, MSI Optix MAG241C 1080p 144Hz
Case Lian Li Lancool III
Audio Device(s) Philips SHP9500, V-Moda BoomPro, Sybasonic Better Connectivity USB DAC/Amp
Power Supply EVGA SuperNOVA G3 80+ Gold 750W
Mouse Glorious Model D Wireless
Keyboard Custom Qwertykeys Navy QK80: Sarokeys Strawberry Wine switches, GMK CYL DMG3 keycaps
While the title only mentions 2x8 kits, Buildzoid does delve into talking about what to buy for 32GB as well:
3,789 (1.91/day)
75 (0.05/day)
Italy
3,789 (1.91/day)
I juat wanted to see it in the general. See if anything changed, other than speed and tRFC. The settings on auto I mean.
MxPhenom 216
ASIC Engineer
13,058 (2.48/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" IPS 1440p
Mouse Razer Viper v2 Pro
what about those?
Loose timings are a big no for Ryzen. Ryzen has a lot of latency between the core, cache, and memory already. Don't add to that.
75 (0.05/day)
Italy
so what kit would you reccomend?
I watched almost all the video and It seems to me that dual rank modules are the best choice.
MxPhenom 216
ASIC Engineer
13,058 (2.48/day)
Loveland, CO
I literally linked 2 a bit ago.
Either 3200 14-14-14-34 or 3600 16-16-16-36
Samsung B-Dies
3,789 (1.91/day)
Haven’t watched that but be sure that his recommendations are suited for a Ryzen system.
yeah totally.
i just gained around 20-30 fps when going from 2666 to 3600 Mhz...
Your upgrade, makes sense but when you past the 3200MHz point on a Ryzen system the ROI (Return-Of-Investment) is minimal.
Under 3000-3200MHz of course the memory subsystem is crippled.
And you have an Intel system. Your case is irrelevant to the topic here.
Samsung B-Dies
Those 2 will perform about the same on a Ryzen system. And b-dies with that timings... How much they cost?
Actually I’m a little surprised that Intel system users are suggesting memory kits, without even having a Ryzen system to test and determine its behavior on different RAM configurations.
75 (0.05/day)
Italy
Samsung B-Dies
You are right, I am sorry.
The 3200 kit is not available but I found F4-3600C16Q-32GTZKK 16-16-16-36 at 250€
The crucial kit is 100€ less expensive with 16-18-18-38 timings.
Is the difference worth it?
3,789 (1.91/day)
MxPhenom 216
ASIC Engineer
13,058 (2.48/day)
Loveland, CO
You might as well just stick to what you have then if you don't get the G Skill kit.
3,789 (1.91/day)
Do I need to show you more?
Please stop trying waste people’s money... out of ignorance!
75 (0.05/day)
Italy
from all the videos it seems my corsair ram aren't that bad... maybe because they are dual rank
1,750 (0.87/day)
Processor 7800X3D 2x16GB CO
Motherboard Asrock B650m HDV
Cooling Peerless Assassin SE
Memory 2x16GB DR A-die@6000c30 tuned
Video Card(s) Asus 4070 dual OC 2610@915mv
Storage WD blue 1TB nvme
Case Corsair D4000 Airflow
Power Supply EVGA GQ 650W
Software Windows 10 home 64
Benchmark Scores Superposition 8k 5267 Aida64 58.5ns
what about those?
They are Micron rev E. It`s a bit slower than Samsung B-die, since you have to run a few timings slower. Use ryzen master and dram calc in windows. It`s quite easy to do that. 3733 fast preset will probably work straight away. Remember to chose 2 ranks and the correct MB and Zen2.
Your timings now on auto are terrible. Especially tFAW, tRC and tRFC are very loose and reduces performance.
75 (0.05/day)
Italy
I tried dram calculator after exporting html from thaiphoon.
The stick I am using are the corsair 3200 16gbx2 C16 kit
Does it make sense?
1,750 (0.87/day)
Does it make sense?
Do you know that your ram is B-die? If it is B-die I would aim for 3600 or even higher. 3200cl16 is very seldom B-die. If you are lucky it could be Micron rev E og Hynix CJR, they both can do 3600-3800 easy, but with slower timings than B-die. If it`s Hynix AFR, Samsung E-die etc you will probably max out at around 3466-3533, but with much better timings than you currently use.
3,789 (1.91/day)
Does it make sense?
Click the "Compare timings (ON/OFF)" button to the bottom to show your current timings.
