Advice for 32gb 3600 kit
75 (0.05/day)
Italy
Processor AMD Ryzen 7 5800x
Motherboard Asus ROG B550 Strix E
Cooling Artic Cooling Liquid Freezer II 360 + 3x Noctua NF-A12x25 PWM
Memory Corsair Vengeance LPX 3200 MHz 2x16GB
Video Card(s) Asus ROG STRIX GTX 1080 Ti GAMING
Storage Samsung 970 EVO Plus 512GB + Samsung 860 QVO 4TB
Display(s) BenQ PD2500Q
Case Be Quiet Silent Base 802
Power Supply Seasonic Prime Ultra Titanium 650w
this is with compare
I know it says b die but somene said this is a bad quality b die... let'see
1,734 (0.87/day)
Processor 7800X3D 2x16GB CO
Motherboard Asrock B650m HDV
Cooling Peerless Assassin SE
Memory 2x16GB DR A-die@6000c30 tuned
Video Card(s) Asus 4070 dual OC 2610@915mv
Storage WD blue 1TB nvme
Case Corsair D4000 Airflow
Power Supply EVGA GQ 650W
Software Windows 10 home 64
Benchmark Scores Superposition 8k 5267 Aida64 58.5ns
I would try 3200 fast preset first, not manual as it sets some really weird timings. If 3200 fast works tryk working your way up. If it`s really B-die you will probably get 3733 fast to work without problems even if the bin is poor. Thaiphoon sometimes reports wrong die, but usually it is correct.
75 (0.05/day)
Italy
The screenshot is for safe what you mean with manual?
I tried changed the frequency in the ryzen calculator but it raise the timing to 16-19-18 and so already at 3400
1,734 (0.87/day)
You set PCB rev to manual. Try A2 og A0. It will give better timings and will probably work unless bin is terrible.
3,772 (1.91/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 200W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.2605), upgraded from Win10 to Win11 on Jan 2024
If you check the "DRAM PCB revision" on the left you will see 4 choises. Yours (and mine) are the A0 as stated by Thaiphoon. A2/A3/B2 may be the best. Ours is not, and they are not totally bad either.
Look dont mind too much about the primary timings. Probably these sticks cant do much about it. You should focus on increasing speed and low the tRC and tRFC first.
I'm running this with DRAM 1.46V stable without memory errors.
This is my sticks. A little different at delay times (ns), speed rated (3466) and single ranked as they are 2x8GB.
Safe:
Fast:
75 (0.05/day)
Italy
but Zach your kit is a 16gb 3466, mine is a 32gb 3200.
Maybe I can start trying the safe settings at 3200 and see gains and stability
3,772 (1.91/day)
Yes, so I said so when mentioned the Dual vs Single rank, but the thing is that the chips are capable of more speed and tighter timings. The thing is that b-dies need volts to work higher/faster, unlike other Hynix dies. Also b-dies past 1.44~1.45V its better to have adequate cooling. With extra cooling (a fan) its safe even at 1.5V
Do you have AIDA software? Its a paid one but you can use the memory benchmark for free with some info hidden.
I dont expect the dual ranked sticks to get too high as they put double the stress to the CPU memory controller but should try.
65 (0.04/day)
System Name Editing Build
Processor Ryzen 9 3900x
Motherboard MSI X470 Gaming Plus Max
Cooling Noctua D15S
Memory G.Skill Trident Z RGB 2x16GB 3200C14 @ 3733mhz 16-15-15-30
Video Card(s) Evga 2060 Super
Storage Crucial 500 Nvme + 500 HDD
Display(s) 24" 1080p Dell
Case Lian Li Lancool II
Power Supply 750w
Software Rendering and Structural Analysis
Benchmark Scores CB R20=8014 CB R15=3581
You can verify if it's real B-Die in Thaiphoon Burner, Read and click Report >> find for "Module Speed Grade"
If its written downbin, probably a bad bin or C-Die
75 (0.05/day)
Italy
Here it is:
Physical & Logical Attributes
Fundamental Memory Class:DDR4 SDRAM
Module Speed Grade:DDR4-2133P downbin
Base Module Type:UDIMM (133,35 mm)
Module Capacity:16 GB
Reference Raw Card:B0 (8 layers)
JEDEC Raw Card Designer:Micron Technology
Module Nominal Height:31 < H <= 32 mm
Module Thickness Maximum, Front:1 < T <= 2 mm
Module Thickness Maximum, Back:1 < T <= 2 mm
Number of DIMM Ranks:2
Address Mapping from Edge Connector to DRAM:Mirrored
65 (0.04/day)
Cooling Noctua D15S
Power Supply 750w
"MaurizioC, post: 4369579, member: 202047"]
Here it is:
So you can't do any better.
Zach_01 has probably real B-Die as his tRFC is very low 373.
75 (0.05/day)
Italy
shall I try the safe preset?
I assume that even if my ram is not that good still the gainings from a better kit would not be worth the expense?
65 (0.04/day)
Cooling Noctua D15S
Power Supply 750w
You can try while you decide. It's a good start for overclocking. Just limit your SOC, Proc, CLDO_VDDG/VDDP.
Otherwise it's not worth it to go higher voltages to gain small performance.
Real B-Die is double price
For example Zach_01 16GB (134$) is far more expensive than your 32GB (110$).
So i suggest you proceed with your initial plan F4-3600C16D-32GVKC which is cheap and Hynix DJR.
Atleast you can still hit Bandwith of 59-60GB/s and Latency of 65s with 32GB with same price as Zach_01 16GB.
And some user running 64GB 3800 3800 16-19-19-19-36 with F4-3600C16D-32GVKC.
3,772 (1.91/day)
I think we both have b-dies but different speed and grade (2133P downbin vs 2666U).
Here is the latest:
DRAM 1.47V with cooling (case fan 800rpm).
Most of timings are manually configured and some tighter than DRAMcalc suggests including tRFC. Other looser. If I had tRFC auto it would be like 665. On XMP profile (3466) was 607.
Yes but as it has been proven by some gaming/software benchmarks earlier this is not worth the money. Its different if he had no RAM at all and wanted to buy now. But he already paid for pair and investing for another one, wont get back the return.
75 (0.05/day)
Italy
so for the moment I would just test the performance of tuning the timing of my current kit without touching the frequency.
Any advice? Do I just need to set those timings in the bios? Do I need to modify the voltage (how to read the voltage block?)
3,772 (1.91/day)
Lets say, you are modifing some timings and you're back in windows. How would you know if the new settings are better or not? Gaming? You wont see anything there.
You need a memory bencmark score as a baseline for stock. A starting point. I use AIDA64. You can use it as freeware, but not all the functions it has.
9,340 (5.18/day)
Louisiana
Keyboard G710+x3
Quick easy test is open command prompt as administrator
Type
winsat mem
Hit the enter key.
Repeat 2-3 times should give you a quick idea.
Here's a crazy one lol
65 (0.04/day)
Cooling Noctua D15S
Power Supply 750w
He can actually sell it, same as I did, same amount I used to buy, from 4x8gb corsair lpx 3600c18 downbin to 2x16gb g.skill ripjaws.
And I see he is wanting to change so he has some money :).
If he can boot 3200 CL14 then its good.
Can you try this? Don't set XMP/DOCP while doing manual.
See if it boots.
75 (0.05/day)
Italy
so the safe preset did not work, I left the voltages at auto is it correct?
If I disable XMP/DOCP the only other options is auto
3,772 (1.91/day)
If you disable XMP/DOCP then you must dial other settings manually.
For example:
1. DRAM speed: 3466MHz (or x34.66)
2. DRAM voltage: 1.38V
3. Primary timings (first 6): 16-18-18-18-36-54
4. tRRDS: 7
5. tFAW: 28
6. GearDownMode: Enabled
7. PowerDownMode: Disabled
8. procODT: 48
9. tRFC: 494
10. CAD_BUS Block Ω: 30 - 20 - 24 - 24 (from top to bottom)
Everything else on Auto.
65 (0.04/day)
Cooling Noctua D15S
Power Supply 750w
You are asking for advice but still you are sticking with Dram Calculator 3200mhz safe preset :rolleyes:
We are advising you to go more than 3200. I don't think you will boot CL14.
75 (0.05/day)
Italy
I just wanted to try the safe 3200 too but each try takes time.
I now tried your advice too for which I thank you but still no boot.
65 (0.04/day)
Cooling Noctua D15S
Power Supply 750w
You can take photo of you bios how you set voltages and dram timings :)
9,340 (5.18/day)
Louisiana
Keyboard G710+x3
On a c16 set of 3200, c14 is not a safe bet
If the set was capable of doing c14 it would of been rated for that cl.
If you had 3600c16 it could do c14 timings easily.
3,772 (1.91/day)
You can take sceenshots of BIOS by pressing F12 and have a usb flashdrive plugged in on FAT32.
75 (0.05/day)
Italy
Ok I managed to take BIOS screenshots thanks to Zack advice
Thank you for checking this
While the title only mentions 2x8 kits, Buildzoid does delve into talking about what to buy for 32GB as well:
A part from trying settings again and taking screenshots, I watched this video again.
He says that b-die ram kits are for overclock and unless you do not want to overclock hard you can avoid paying big money for them.
It also seems to me that dual rank configuration are superior than single rank configuration
and this articole from tomshardware seems to recomend dual rank memory too:
In first place I bought my 3200 c16 kit because of this article since my kit is dual rank and 1T
so mayve there are less expensive options to consider?
