Have you tried clean tails, for example using Driver Fussion?I can't install any executable that's inside the folders, it's strange because it hasn't happened to me before with any driver.... Windows simply refuses to run it.
This is just strange, the installers are the same in both versions.I can correctly install the driver XFTI_PCDRV_L11_2_40_0019.
I don't use antivirus o antimalware... Testing with the executables, when I go to the Audio\Setup folder and run setup.exe, Windows detects that the program may not have been installed correctly... could it be some kind of incompatibility with the installshield version?This is just strange, the installers are the same in both versions.
Don't have a third-party antivirus? Maybe he blocked him.
Well, let's try another version of the driver... even better than 2.17.0008. Let's see how she behaves. But to install it, you must disable driver signature verification. This is a driver from an Auzentech card and has a driver architecture similar to Ti HD, but without using THX technology and has the same CMSS3D. And also has no problems with EAX in older games.I don't use antivirus o antimalware... Testing with the executables, when I go to the Audio\Setup folder and run setup.exe, Windows detects that the program may not have been installed correctly... could it be some kind of incompatibility with the installshield version?
Thank you! The first thing I did was put Windows in safe mode and uninstalled the creative driver through DDU. Then I disabled Disable driver signature enforcement and installed your new v2.20 driver; The first time Windows started (with the driver installed) I had no audio but when I restarted it worked as it should. Now I am testing the quality and stability, since my computer is on 365 days a year and with other drivers I have noticed sound anomalies such as cracks or noises when not restarting Windows for days.Well, let's try another version of the driver... even better than 2.17.0008. Let's see how she behaves. But to install it, you must disable driver signature verification. This is a driver from an Auzentech card and has a driver architecture similar to Ti HD, but without using THX technology and has the same CMSS3D. And also has no problems with EAX in older games.
XFTI_PCDRV_L11_2_20_0000_driver pack
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.www.mediafire.com
Yes, I gave you a trial test version. I’ll fix all these nuances now and re-upload the driver. Saving via sleep mode cannot be fixed.EDIT: With this driver the maximum frequency is 24/192 and the microphone effects are not present, so it is not possible to remove ambient noise.
Thank you very much for your time and effort!. The Creative drivers (for X-Fi) were never 100% stable and with each new version they broke things (Codemasters Rulz!). Regarding not being able to save changes in the traditional way, I don't see a big issue.Yes, I gave you a trial test version. I’ll fix all these nuances now and re-upload the driver. Saving via sleep mode cannot be fixed.
Great, but I want to note that the settings are saved through sleep mode. That is, we fully configured the card and saved the settings by entering and exiting sleep mode
I fixed everything and re-uploaded the driver.Thank you very much for your time and effort!. The Creative drivers (for X-Fi) were never 100% stable and with each new version they broke things (Codemasters Rulz!). Regarding not being able to save changes in the traditional way, I don't see a big issue.
I tried these but having an issue with the pc not picking up the subwoofer from my 5.1 z5500. I tested the other channels and they all work apart from subwoofer.Try these drivers first:
It seems that the best version for titanium cards is 2.17.0008C but it does not install on my PC for some reason... saludos
Did you include bass redirect in the console launcher?I tried these but having an issue with the pc not picking up the subwoofer from my 5.1 z5500. I tested the other channels and they all work apart from subwoofer.
yesDid you include bass redirect in the console launcher?
i was using analog and 6 channel effect on z5500. prefer analog for music and games and use optical only for moviesIf version 2.40.0019 is installed, then this is the latest official driver. SB0880 is not very friendly with him. Is there no subwoofer sound from the analog output? What is the sound source?
i uninstalled the drivers and just used normal windows 5.1 configurator and tested it again and the subwoofer works. but with the driver installed im getting sound from the satellites properly but no subwoofer.If version 2.40.0019 is installed, then this is the latest official driver. SB0880 is not very friendly with him. Is there no subwoofer sound from the analog output? What is the sound source?
